Question about HP iPAQ h6315/h6365 Pocket PC
HOW TO CHANGE OR CHARGE THE BACKUP BATTERY?
My hp6365 keeps telling me that i my backup battery is low..i keep charging my phone but the only the main battery is charging..how do i charge or change the backup battery?
Y hp6365 keeps telling me that i my backup battery is low..i keep charging my phone but the only the main battery is charging..how do i charge or change the backup battery?
Posted on Jun 13, 2010
Where can i get portable backup charge for mobilty scooter?
most scooter batteries take 5 to 8 hours to charge correctly the only backup methods are the following
if you have a detachable battery box .pride gogo ect a spare battery box can be purchased and kept charged.
there is no quick way emergency charge if you run out of power
just charge it evrey time you use it and for a min of 8 hours to keep your batteries in top condition,have them tested if you think low range.
Dec 06, 2014 | Health & Beauty
The power wents off and the batery got completly discharged , then i turn it on and run the self test and replace icon staid illminate but in the next self test didn't, i hace to replace the battery?
First tell how old is your UPS ?
if its older by two to three years may be the Battery eeds a replacement .Try charging the battery externally with a good battery chargers but before charging externally please take out the battery outside.
Then if the battery shows very low voltage even after charging for some 8 hours then you have one alternative that is replace with new battery.and promptly keep it under charge with out fail.
Aug 16, 2014 | Tripp Lite G1000U Intelligent LCD 1000VA...
Apc hi800sq
follow this steps and fix it. God bless you
Plug the battery backup into a working electrical outlet. If the battery backup turns on when the power button is pressed, then the problem may be that the previous electrical outlet is faulty. Proceed to step three. If the battery backup doesn't turn on, proceed to step two.
  • 2 Reset the circuit breaker on the battery backup. APC battery backups have a labeled circuit breaker button located on the unit near the phone line, fax line, USB, network and coaxial cable inputs. Press the button to reset the circuit breaker. Power on the battery backup by pressing the power button. If the battery backup powers on, proceed to step three. If the battery backup doesn't turn on, proceed to step six.
  • Read more: http://www.ehow.com/how_7266444_troubleshoot-apc-battery-backup.html#ixzz2lwOvPO75
  • 3 Determine if the battery backup is charged and providing battery power. With the battery backup on and plugged into a working electrical outlet, plug a computer monitor into one of the battery backup outlets labeled "battery backup plus surge protection" on the battery backup. (APC power supplies have some outlets that provide only surge protection while the other outlets provide surge protection plus battery backup.) Turn the monitor on. Unplug the battery backup power cord from the wall outlet. If the monitor remains on, the battery is holding a charge, supplying electrical power and the battery backup is working properly. If the monitor goes off, proceed to step four.
  • 4 Charge the battery. Plug the battery backup into an electrical outlet and allow the battery to charge for 16 hours. This will fully charge the battery.
  • 5 Test battery charge. Once the battery is fully charged, repeat step three. If the monitor stays on when power is interrupted to the battery backup, the issue is solved and the problem resulted from an incompletely charged battery. If the monitor turns off when power is interrupted, the battery within the battery backup is faulty and needs to be replaced.
  • 6 Replace the battery backup unit. The unit itself is faulty. If the battery backup is under warranty, contact APC to request a replacement.
  • Nov 28, 2013 | Computers & Internet
    Battery not getting charged
    you must check the power cord of your ac adaptor too then check if it has a fuse. you can change the fuse or change the power cord.
    Sep 28, 2009 | Computers & Internet
    Backup battery discharging
    hi thanks for using fixya!
    You have to bring your Dell Axim X5 PPC to a service center, to check further the back up battery if needs to change it.
    If you need further assistance, let me know.
    May 28, 2009 | Dell Axim X5 Pocket PC
    The phone is not recognizing the backup battery. can someone please help me on how to charge or replace the backup. battery
    The backup battery is located inside the phone and canno be replaced by normal methods. the phone needs be disassembled and the battery are solded on the board.
    the lifetime of these bateries are very high, maybe 5 or more years, and the charge occurs every time when you charge the phone.
    Try to leave your phone charging for more than 3 hours, and if the battery dont charge, try a master reset on it.
    If ater all, the battery dont charge, maybe you make some mistake or shorted some circuit. Take apart your phone again and re-check all the steps to reassembly.
    Good luck
    May 23, 2009 | i-mate JAM Pocket PC
    Main Battery Power
    It cannot switched the batteries. The backup one is a small internal battery just to keep the CMOS with data. That's it.
    If you main battery is not charging or when unplugged won't power on, the is likely the main battery is defective, or the charging circuitry of it is failing.
    Best regards,
    Jul 01, 2008 | HP iPAQ RX3115 Pocket PC
    Backup battery
    The backup battery exists to protect your data when the main battery dies. It only has enough power to keep the internal memory 'alive' so you dont lose your files, settings etc.
    When the backup battery dies it should be replaced as soon as possible, as the main battery will power the internal memory only while it has charge. Should the main battery die it would be like performing a hard reset.
    Jun 16, 2008 | HP iPAQ hw6515 Pocket PC
    Low Battery DATA Lose - HP iPAQ Model h5450 Packet PC
    The h5450 comes with what HP calls a backup battery. It is built into the device and not accessible by the user. However, the backup battery has only enough juice to power the Pocket PC for a few minutes while you change main batteries. Don't expect it to keep your RAM data alive if the main battery runs out.
    Mar 12, 2008 | RIM BlackBerry Pearl 8100
    HP iPAQ h6315/h6365 Pocket PC Logo
    1,293 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
