Question about Microtek Computers & Internet
Desperately need ethernet driver for xp
Evesham estyle pc mb NC5IG-S7
cant access net in windows xp ( but can running linux )
i think ethernet chip reads RTL820cl
  • 271 Answers
Download from following link.These are updated drivers.
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=6&PFid=6&Level=5&Conn=4&DownTypeID=3&GetDown=false#RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L)/RTL8139C(L)+/RTL8139D(L)/RTL8100(L)/RTL8130/RTL8139B(L)
Thanks
Posted on Feb 17, 2009
How install ethernet driver on 8086
you will need to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question / exclamation mark? ! or a red X right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc or you might download one if you dont have on a disk
Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals
look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled
hope this helps
Aug 17, 2012 | IBM Think Centre A50 P4 (841923u) Network...
How to install ethernet driver on 8086
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
click start control panel administration tools computer management device manager look for network adapters + expand Ethernet driver if you see a yellow question exclamation mark or a red X you will need to update/reinstall the driver for the device
make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals
look for SiS On Chip Pci Device press enter make sure its enabled
then recheck the driveri t should be there
k the driver it should be there
make sure its enabledPci device arrows key scroll to nstalled
if you computer came with a motherboard disk the driver could be on it
or this disk provided by your ISP provider Internet Service Provider
hope this helps
Change operating system
You can keep both Vista and XP. Below is the way to install XP, after Vista was already installed... creating a dual boot. First find the drivers for your network components, wireless card or nic, and save them to an external device such as a floppy disk or flash drive. Then you will need to go into the BIOS on your computer startup. Scroll to the System Configuration tab and go down to the SATA Native Support and change its setting to Disabled. Then hit F10 to Save and Exit. Next, insert your Windows XP CD and create the partition you wish to install XP on. After the installation is complete you should boot automatically into XP. Now you need to move some files. First, make sure you have set your folder options to see hidden files and to show protected operating system files. Then open Windows Explorer and go to the drive where Vista is installed. Copy the folder Boot, and the files bootmgr, boot.ini, NTDETECT.COM and ntldr and paste them to the root of your XP drive. Then download Vista Boot Pro and save it to your desktop or somewhere else that you can easily access. Unless you already have .Net Framework (v2.0 at least) it will redirect you to a Microsoft page where you can download this necessary component. Install and run Vista Boot Pro and open the "Bootloader" tab. Select "Reinstall the Vista bootloader" and press Apply. Then go to the Manage OS Entries tab and select "Add new operating system entry" and make sure you select "Windows Legacy". Give the new entry a name (ie: Windows XP) and select the drive letter you have XP on and then select Apply. You can also choose which entry you would like as the default the system will boot to. And now you should be able to dual boot between Vista and a previous OS. Thank you! Sabharish
Jun 15, 2009 | HP Thin Client - AMD Geode NX 1GHz - 256MB...
Network driver problem
You need to go on dell support site on another pc and download network and other drivers for this pc. get it here http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=58953
put on a cd of flash drive then install it on dell pc
Dec 07, 2008 | Computers & Internet
Ethernet card installation
what the make of your ether card,the manufacturer
May 18, 2008 | Computers & Internet
File Sharing between 2 PCs
Very simple.. if you don't have a hub or switch, you need a 'cross over cable' which is similar to a normal ethernet cable, but different pin configuration. With the cross over cable between the two pc's (plugged into the ethernet ports) you have to make sure the windows & any third part firewall is off.. change the IP address & subnet mask to the same subnet.. Eg. Click Start button, control panel, click on network connections, click on the local connection that is in connected state, select properties, find the (TCP/IP) option double click on that, select the 'use the following address' radio button (dot in the circle) then enter a new (ficticious) address like 10.0.0.8, then a subnet of 255.255.255.0 - Then do the same on the other PC.. except the IP address must be different Eg 10.0.0.7 - There are a number of other ways to do this, but this is probably the simplist. Remember to put the IP back to way you found it, otherwise your internet access may not work when you plug your normal internet cable back in. Remember o turn the firewall back on. Boot the pc's. Good Luck.
Apr 27, 2008 | Computers & Internet
Access to bios
you can use F10 while switching the system on. Alternatively you can also use Del key.
Feb 13, 2008 | Compaq EVO T30 Network Terminal
Upgrade 238622-001, Compaq Evo T30 Thin Client 300Mhz 32MB Flash/64MB/Win CE NET/IE 5.5 w/o
You need to replace the 2mbit bios chip used by the WinCE Evo with the 4mbit one used by the NTe and XPe Evo, then you need an add on flash module, since the onboard flash is too small. After that, just find the OS file and flash away. You can find the OS files and a utility to flash from the HP support site. You'll need a crossover ethernet cable, not a patch cable, to do the flash.
Jun 25, 2007 | Compaq EVO T30 Network Terminal
Computers & Internet Logo
1,079 people viewed this question
Top Microtek Computers & Internet Experts
William Miller
William Miller
Shelly
Level 1 Expert
Are you a Microtek Computer and Internet Expert? Answer questions, earn points and help others
