Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Craftsman air compressor 15gals 1.5hp holds at 80psi instead of 150psi with the motor still running
  • Anonymous Mar 14, 2009
    mine , when turned on it holds at 80 or 100 and just keeps running. Im afraid to let keep running or it might blow up! It is also 15 gallon.
    Scholar:
  • 89 Answers
REGULATOR NEEDS TO BE TURNED UP. SOUNDS LIKE THE LOW PRESSURE SIDE IS WORKING. MAYBE THE HIGH PRESSURE VALVES ARE NOT WORKING CORRECTLY IN THE HEAD. MARK THE CORNER OF THE HEAD AND VALVE PLATE AND REMOVE - MAKE SURE THEY ARE NOT BROKEN AND THEY ARE OPENING & CLOSING ALL THE WAY. MARK "UP" ON PLATE SO YOU DONT FLIP IT ACCIDENTLY. HIGH PRESSURE PISTON ROD IS BROKEN AND NOT GOING UP AND DOWN.
Posted on Mar 14, 2009
  • 74 Answers
Check the oil level of the cranckcase first
Posted on Mar 13, 2009
Sears craftsman air compressor model 919.153160 will pump to 150psi but is leaking when it is pumping it will shut off at 150psi but then struggles to restart (tries several times before it does start).
Loosing line a little bit going into tank and see it the pressure continues to come out if so, you might want to consider replacing the check valve. It is designed to keep the pressures in the tank and when they leak off it causes back pressure on the motor making it hard to restart...hope that helps.
Jan 20, 2015 | Craftsman Air Tools & Compressors
Porter cable compressor electrical smell won't run
wow
Check motor and pressure switch for erosion, electrical strikes in plastic
Replace if bad
Dec 31, 2012 | Porter Cable Cable 4.5 Gallons 150PSI Job...
Compressor motor keeps running and the tank relief valve opens and pressure is released. why will the motor not stop when pressure reaches 150psi
The pressure switch has gone bad....there is a switch that is to stop it and then restart it on pressure...either the switch is bad or the tube is plugged...going to the switch.
heatman101
Sep 14, 2010 | Dewalt 2 Hp 4 GAL Air Compressor
Job boss compressor wont run
have you checked the motor reset
will be on the motor
May 10, 2010 | Porter Cable Cable 4.5 Gallons 150PSI Job...
My air compressor wont shut off when its full like it use to.
Hello
Could be a bad pressure control switch.
Depending on the size of the compressor it should shut down on high pressure via a pressure switch.Some will shut down at 150psi.
Also there should be a relief valve,make sure this is also working.
Apr 06, 2010 | Craftsman Air Tools & Compressors
Air compressor won't go over 40 psi?
my ace air compressor which is 26 gallon 5 hp will not get over 60psi what is wrong with it please?
Feb 14, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
Craftsman 6hp 150psi 30gal won't keep running
It sounds like the internal circuit breaker in the motor is heating up and then the breaker trips to shut down the motor. This is the protection so you don't have a fire if the motor burns up. The smell you have is the coils in the motor. Sorry to say that you will need a new motor for this unit. I hope this helps out.
Jan 17, 2009 | Air Tools & Compressors
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
206 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
