Question about Konica Minolta Dimage Scan Dual IV Film Scanner
Cleaning Minolta Dimage Scan Dual
I have just bought a second hand Minolta Scan Dual 35mm negative and slide scanner. Looking through the slot where the film carrier goes, there is accumulation of dust. I am sure some of this dust must also be on the light source and the pickup sensor. I wonder how easy or difficult it is to clean the pickup sensor and the light source and to lubricate the mechanism for moving the slide/film carrier. I wonder if someone out there has done this successfully.
  • 14 Answers
SOURCE: Minolta DiMage Scan Dual IV
1) Install all of the usual Minolta software in Vista.
2) Create a new folder somewhere
3) Create a new txt file named minolta.inf and paste this into it:
; scanners.inf -- Test Vista Minolta Film Drivers
; To remove this driver and install the original
; manufacturer's driver, go into Device Manager,
; open Imaging devices, then click on the scanner name
; with the right mouse button and choose Uninstall.
[Version]
Signature="$CHICAGO$"
Class=Image
ClassGUID={6bdd1fc6-810f-11d0-bec7-08002be2092f}
Provider=%Provider%
DriverVer=3/12/2009,2.0
[Manufacturer]
%Mfg%=Models,ntamd64
[Models]
; USB scanners
"Minolta Scan Dual II" = USBScanner,USB\Vid_0638&Pid_026a
"Minolta Scan Dual III" = USBScanner,USB\Vid_0686&Pid_400d
"Minolta Scan Dual IV" = USBScanner,USB\Vid_132b&Pid_000a
"Minolta Scan Elite 5400 2" = USBScanner,USB\Vid_132b&Pid_0012
"Minolta Scan Elite 5400" = USBScanner,USB\Vid_0686&Pid_400e
"Minolta Scan Elite II" = USBScanner,USB\Vid_0686&Pid_4004
"Minolta SC-110" = USBScanner,USB\Vid_0638&Pid_0a15
"Minolta SC-215" = USBScanner,USB\Vid_0638&Pid_0a16
;---------------- Duplicated from [Models]
[Models.ntamd64]
; USB scanners
;---------------- USBScanner -------------------------
[USBScanner]
Include=sti.inf
Needs=STI.USBSection
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
[USBScanner.Services]
Include=sti.inf
Needs=STI.USBSection.Services
[Strings]
Provider="Konica Minolta"
Mfg="Konica Minolta"
4. Save file. Turn on scanner and go into device manager and update the old minolta driver with this driver. You may have to manually update it.
5. All the normal Minolta programs now work just fine. Enjoy!
Posted on Mar 12, 2009
SOURCE: Konica Minolta DiMAGE Scan Dual IV Film Scanner driver in an IMac
DS Dual 4 even works with SnowLeopard on a CoreDuo MBP. But it doesn not support Autofocus when used under USB2. You have to use a USB1.1 Port, if you want to use autofocus function. Every time the software crashes, because you tried e.g. to use autofocus with USB2, you will have to close the application, go to the folder User/Library/Preferences/DS Dual4/... and look whether there is a file name something like "MFSlib...." and pull it to the trash bin. You can start the application again. PS.: Your keyboard USB port is a USB 1.1 port!
Posted on Jan 06, 2010
SOURCE: cleaning dust off of mirror inside Konica minolta
www.rangefinderforum.com/forums/archive/.../t-5895.html
Posted on Aug 02, 2010
fanaudi
  • 1381 Answers
SOURCE: Konica Minolta Dimage scan dual
It's possible there are no drivers running under W 7 for this remarkable unit and it's a shame .
If you have the W XP install disc , you could install a virtual version of W XP on your HDD .
You could also partition your HDD and install W XP on the new one .
Otherwise ... trashbin . Yes , life is hard .
Regards .
Posted on Jan 02, 2011
fanaudi
  • 1381 Answers
SOURCE: Waar kan ik de software
Hi ,
Er zijn geen Windows 7 versies meer .
Bent u in bezit van de W XP install disc , dan kunt u :
ofwel een virtuële versie van XP op uw schijf installeren : http://download.cnet.com/VMware-Player/3000-2094_4-10470784.html
ofwel uw schijf partitioneren en XP op de nieuwe partitie installeren : http://download.cnet.com/Partition-Wizard-Home-Edition/3000-2094_4-10962200.html
Beide zijn gratis , safe en heeeeel gebruiksvriendelijk .
Beste groeten .
Posted on Jan 24, 2011
I'm missing the slide tray for my Dimage Scan Dual IIl Would like to find one to buy.
I have the slide tray to a Dimage Scan Dual II and am looking for negative tray.
I would be perfectly willing to swap it with you or buy it off you...
Jan 23, 2011 | Minolta Dimage Scan Dual II Film Scanner
I have been using the Konica Minolta Dimage Scan Dual IV for the last 2 months and i've scanned about 350 slides, so i know it works. however sense yesterday afternoon it hasn't been working for me. I am...
I do not have an answer for you, unfortunately, as my Dual Scan IV is doing almost the same thing....my unit will not load the 35mm film slider - when it tries to load, it makes a fairly loud clicking or ratchetting sound. This occurs each time I push the film into the unit. Have you had any replies or have you found a solution to the problem. Thanks and good luck.
Dec 09, 2009 | Konica Minolta Dimage Scan Dual IV Film...
Konica minolta dimage scan dual IV
Are you doing index scans or prescans? Sometimes the software gets funky - try doing at index scan if you are doing prescans, and vice versa. Also try CHTL+SHIFT+I which is a recalibration (don't that will do anything but it can't hurt). The best thing might be to just remove Dimage totally (you may have to delete the main folder if you've created any Jobs) and then reload the software. Before you do that, update your virus software, do a system check, and maybe some maintenace like a Defrag - then reboot, remove the software, reboot again and reload software.
Oct 18, 2008 | Konica Minolta Dimage Scan Dual IV Film...
Konica Minolta Dimage Scan Dual IV won't scan slides properly
Forget about the Minolta software. It's buggy at best. Use VueScan instead. A free trial is available so you can test it before you commit to buying it. Available for Windows including Vista.
http://www.hamrick.com
Jul 08, 2008 | Konica Minolta Dimage Scan Dual IV Film...
Dimage dual scan 4
Use VueScan instead of the Minolta software. A free trial is available so you can test it before you commit to buying it. Available for Windows Vista.
Mar 29, 2008 | Konica Minolta Dimage Scan Dual IV Film...
[Version]
Class=Image
Provider=%Provider%
[Manufacturer]
[Models]
; USB scanners
[Models.ntamd64]
; USB scanners
[USBScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[Strings]
Jan 27, 2008 | Konica Minolta Dimage Scan Dual IV Film...
Scanning problems
The scanner will only do what it is made to do thats its biggest.
Apr 20, 2007 | Minolta Dimage Scan Elite II Film Scanner
Konica Minolta Dimage Scan Dual IV Film Scanner Logo
423 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
