Question about Linksys SPA-2102 NA Analog VoIP Adapter (2) FXS, (2) RJ45 (SPA2102-NA)
Linksys VOIP phone adopter is not working properly
I am having Voip voice internet phone adopter Model No. pap2t in my adopter it working some times and it is doesn’t working some times when I reset the power supply it works fine and I can make a call. After 15 to 20 min automatically the two phone will be disconnected and the dial tone is will not coming later on again after 20-30 min it automatically works fine the two phone which I have connected to them gets dial tone and works fine. I am not able to understand either the problem is in the settings or the device.
2 Suggested Answers
SOURCE: Clearwire VOIP ph adapter + Can only connect 1 phone downstairs
I disconnected my incoming phone line and connected my VOIP line 1 to my R11 wall phone jack. This feeds the signal to all phone jacks in the house.
I also use the VoIP to fax and send data using my PC modem.
For Fax
Use *99 as a prefix for any number you are faxing or dialing to.
Dial-up
1. Configured area code dialing rule in Phone
Posted on Sep 11, 2010
I cant configure my ata phon adopter
Yes you can but you may need a SIP accoount along with SIP settings from your service provider.
May 03, 2012 | Linksys SPA-2102 NA Analog VoIP Adapter...
Pap2t can not connect to voip.ms i try to make a call in the line busy Login to Linsys web configuration: Registration State: Can't connect to login server. How can I made regis with voip server
got to start menu then write in search cmd then a dialogue box will appear then after it appears start typing 192.168.0.1 if the ip reply from your ping.you have a good connection with your touter.i its not try to check you LAN cables if it is coonected in your computer.. :)
Mar 19, 2011 | Linksys PAP2T
Hi, I need to connect my comSwitch 5500 to the Cable/internet/VOIP. Command Communications ComSwitch 5500 is a Telephone Line Sharing system- (automatic phone/Fax Switch) sold under the following...
I'm not one hundred percent sure on this, but it does look like you need a separate phone line since VOIP revolves around using your internet as a gateway for making phone calls. And since majority of VOIP uses ethernet connections, or wireless, there is no phone line to use.
Feb 28, 2011 | Computers & Internet
Hi i have linksys pap2 voip router and am unable to programme it .......can you help
goto ip address 192.168.5.1
or config manual with phone with #* to enter config bia analog
Feb 18, 2010 | Linksys PAP2T
Linsys voip internet phone adepter PAP2T ip address
pulg phone pin in pap2 device phone1 pin then give internet connection to pap2 then dial from the phone *110# then u can here ip from pap2
Nov 11, 2009 | Linksys Computers & Internet
How would fax run on VOIP? what requirment it needs?
typically faxing doesn't work on VOIP. i tried many times and sometimes it would go through although it said it didn't. other times it didn't work at all. VOIP has a limited bandwidth and the fax needs to send more info over the line than VOIP makes room for.
to have the best luck, stop all downloads and other network traffic while attempting to fax, so that there are no other programs or devices using the internet. the fax will have its best chance of working that way, although it probably still won't
here are some very good tips as well:
http://chris.pirillo.com/how-to-fax-over-voip-on-the-internet/
Feb 18, 2009 | Lexmark X4270 All-In-One InkJet Printer
Can't access voice tab on WRP400
If your wireless VoIP router was provided by your VoIP provider they will usually lock this option on the router since they have pre-configured the voice settings(sip server, phone number, password, codecs) before they deliver the device to your location. if you have a working internet connection already you can give your VoIP proiver a call so that they can remotely check the voice settings on their end to verify if it's working or not.
Nov 24, 2008 | Linksys Wireless-G WRP200 Router
Not able to connect my voip adapter to internet
hello sir iam working for voip and iam a tech?
and u r using linksys pap2 which is not a router its just a phone adapter so it will work through a router so try this first
is ur modem is a modem router and u have 4 ether net port on it and u can able to access inter net through hard wired and connect this pap 2 adapter through one of the ether net jack on the modem router (ut starcom)>an dit has a fire wall which block ur voice signals so u need to open some ports on it try this link to open all ports and u need to try this with a pc which connected through hard wired on the modem router go to through this link
http://www.portforward.com/english/routers/port_forwarding/UTStarcom/UT-300R2U/Vonage.htm
and also disable the fire wall on the router screen and reboot the linksys pap2 and ur ut star com modem router also and connect ur phone directly to phone jack 1 on the pap 2 device if u have any issues let me know
and rate me solved if its helps thx
Dec 04, 2007 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Linksys SPA-2102 NA Analog VoIP Adapter (2) FXS, (2) RJ45 (SPA2102-NA) Logo
300 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
