Question about Intel D945GCZ Motherboard
Error msg "The system chassis was opened" how to continue booting
I've bought an NEC computer that after installing extra RAM has displayed a messgae stating that "The sytem chassis was opened" and my documentation and their website does not tell me how to continue booting... I get no further than this screen and have tried all sorts of key combinations etc and rebooting but to no avail.. HELP PLEASE!!
  • 1 more comment
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    Hey, there may be another item:
    "Clear all DMI event logs upon rebooting".
    Select Yes before you save and exit.
  • Wayne Mineard
    Michael,
    Try to get into the BIOS (F2) as it begins to boot.
    If there is an Advanced Menu, look for "Hardware Monitor" and change it to "Disabled".
    Save and Exit the BIOS.
  • Wayne Mineard
    What model number is the computer. It no doubt has a Chassis Intrusion detection and it needs to be reset.
    NEC has some limited support, but if you give the model number, I may help.
  • 31 Answers
Firstly, you have to close the side panel after install any component. if the message show you again, try to find and short connect the jump (2 pins, signed Chassis) on your mainboard.
Posted on Feb 17, 2009
I have installed extra RAM im my vgc-m1. But it does not boot up, just keeps going to boot up normally with windows. I have checked bios setup and it recognises the extra ram, I have also got latest bios...
Hi crobinsona
The extraRam is not compatible with your system or the manufacturer's product isn't neither . Check in the Bios to see what exact type of Ram is supported . Download and install Sandra from http://download.cnet.com/SiSoftware-Sandra/3000-2086_4-10556571.html . It will give you detailed description of the existing RAM and allow you to compare with the stuff you' ve purchased .
Here are a few reliable manufacturers : Crucial , Corsair , Kingston .
Here is a reliable address for purchasing on the net : www.upgradecomputermemory.com
Similar products vary in quality from one source to another and it often happends that low price products simply don't run in different machines .
Best regards ,
fanaudi .
Jul 30, 2011 | Sony VAIO M1 (VGCM1) PC Desktop
I have just installed a 478 socket MSI MS-6526 ver 3 motherboard to my computer and all it dose is bleeps when i turn it on any help would be apricated
check for the error beep if you hear continues beep it means issue with the memory. check the RAM if it is properly inserted to the slots and if it is compatible to the motherboard. if you hear 2 or 3 beeps it means issue with the video. your video card maybe not compatible or not properly inserted to the slot. your motherboard has a built in VGA/Video card try using that first. try connecting the main components memory/RAM, power supply, KB and mouse, VGA card(optional you have a built-in) then check if there is a display or if it booted. then one by one add your other components you want to add. just to trace the problem.
May 19, 2011 | Intel Motherboard
I jst bought used IBM 8183 Thinkcentre every time
You will need to install Windows. If you have an install disk, insert the disk into the optical drive and restart the computer. Go into BIOS and select "Boot from CD/DVD". Follow the install instructions on screen.
Apr 12, 2011 | IBM Computers & Internet
My pc powers up but never starts the monitor or run through a full boot up. all fans operate. changed monitor, same error. any ideas?
To Solve your problem kindly let me know
1. if you made any recent hardware changes. 2. Do you get any beep error msg or just one beep for clock check. 3. Have you tried removing RAM from its slot cleaning the slots and RAM and re-inserting. If not kindly do. 4. Have you tried booting through CD. Put your OS CD in CD drive and boot through CD.
Thankyou for using fixya free utility. Kindly rate my solution once your pc starts.
Jun 26, 2009 | NEC PowerMate ML4 PC Desktop
Error beep codes NEC VersaPro NX SERIES
Long beeps is normally a sign of bad ram. So its not a show stopper. Turn it over and normally the RAM is under the smallest plate. If you can try taking one stick out at a time you may be able to tell if only one is bad or both, if you have more than one. But regardless, buy some new ram, install and all will be good again.
Apr 02, 2009 | Computers & Internet
Stop Error (Blue Screen) XP/7000 VE/AGP
sounds like might be a bad card,
alternatively your system ram might be giving you grief, i had major BSOD issues with my computer and ram tested fine, upon switching sockets that the ram was in i found that it was actually good ram, bad ram socket.
Mar 05, 2009 | ATI RADEON VE (32 MB) Graphic Card
Extra RAM in emachines 5220
I think you are mixing ram.... Use the same make and module for your ram... when you mix ram, the problem is other ram can be difernt Voltage. some 1.9V, 1.8V, 2.0V, 2.2V to operate. If you have 1.8V and 2.0V the computer won't boot. Hope this helps.
Dec 23, 2008 | Computers & Internet
XP won't boot with NEC SD-V2-5U USB card installed
Have you tried moving the card to a different slot? The motherboard BIOS and/or the operating system may be trying to assign an interrupt that cannot be shared--especially if you have the card installed in the slot next to the video card (or shared with the onboard video).
Nov 06, 2007 | NEC SD-V2-5U (SDV25U) Serial Adapter
Intel D945GCZ Motherboard Logo
1,389 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
