Question about Toshiba Satellite A100-S8111TD Notebook
How to remove laptop key board from toshiba satellite A100
  • gilles_levei May 11, 2010
    How do you remove the light grey cover plate to access the screws to remove the keyboard.
    Sergeant:
  • 183 Answers
Please visit following websites for all instructions whith snapshots.
click here
or
for individually keys:
Click here
Good Luck and rate all answers.
Posted on Feb 17, 2009
    Scholar:
  • 52 Answers
There is a video even posted about how to do it, I am sure that will be even better than text describing. A guy poured cola on his Toshiba Satellite A100 and had to clean the keyboard, for which he had to take it out. So here is the link:
http://www.youtube.com/watch?v=-TrTtNZcf44
If this helped, please rate me:)
3 Suggested Answers
  • 72 Answers
SOURCE: toshiba laptop satellite A100 main board power problem
If you have to wiggle th cord to make it work the power pin is damaged. It can be fixed. Lots of places fix them or you could (if you are mechanically inclined) do it yourself. Parts are under $ 10.
Once you get it fixed, get one of these.
Posted on Apr 01, 2008
  • 909 Answers
SOURCE: audio driver for tos satellite a100
you should be able to get it from realtek.com.
you need the high def driver.
or you could download driver max and it will update all your drivers for free.
Posted on Aug 11, 2009
Where do I find the part number for the motherboard
Look near the memory slots. You will see labels. Also look all inside the board for labels. Write down the numbers you see on your motherboard. Then get on Ebay and look for motherboards for your laptop. The board on ebay will have model numbers on them, look for a number that matches what you wrote down.
Below is a link to the motherboards I found on eBay for Toshiba Satellite A100.
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=Toshiba+Satellite+A100+motherboard&_sacat=See-All-Categories
Below is a link for the A105 motherboards
http://www.ebay.com/sch/i.html?_nkw=Toshiba+Satellite+A105+motherboard&_sacat=0&_odkw=Toshiba+Satellite+A100+motherboard&_osacat=0&_from=R40
May 13, 2012 | Toshiba Satellite A100 A105 Series Laptop...
What did toschiba satelite 8100 lap top model number psaane/03j02gen transpose to
The Model Name and Model Number is Satellite A100-033.
It's one of the Satellite A100 series of Notebook PC's.
http://icecat.com.ua/en/p/toshiba/psaane-03j02gen/notebooks-laptops-satellite-a100-033-796649.html
1) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
2) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
3) Free Service Manual for the Toshiba Satellite A100 series of Notebook PC's,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Go down to the line that starts with Satellite A10. Scroll across, and click on A100.
This is a PDF file.
It may take up to 30 seconds before the first page comes up. It may also take additional time to fully download
{Service Manual for your daughter's laptop. I gave a solution to another one of your posted problems}
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 17, 2011 | Toshiba Computers & Internet
How do I remove and replace the keyboard on my satelite A 120 laptop. Can I have some instructions please.
Step one: Remove the two screws from the bottom of the computer that are holding down the Toshiba Satellite A100-S8111TD Keyboard bezel. The bezel is the bar that sits right above all the function keys.
Step two: Turn the computer over, open the cover and insert the credit card or guitar pick between the bezel and the laptop screen. The bezel has pegs that sit in holes, you need to slowly pry up the bezel. It will make a bit of a popping noise as it is removed.
Step three: Now hold on to the laptop keyboard from the end closest to the screen and gently pull it away from the touch-pad end and flip it over. You will see the ribbon attached to the underside of the Toshiba Satellite A100-S8111TD Keyboard. There is a little plastic connector holding the ribbon to the computer. To unlock it, carefully pull up on the two tabs; one located on each corner of the connector. Be very gentle when you do this as this is the one part that gets broken the most often when changing a keyboard. The ribbon cable will now be released.
Step four: Carefully pull the ribbon out of the connector and remove it along with the entire Toshiba Laptop Keyboard.
Final step: To insert the new Toshiba Satellite A100-S8111TD Keyboard, place the board face down so you have easy access to the ribbon. Make sure the keyboard is lined up so when you flip it back over the keys are in the correct position. Keep the ribbon straight at all times; twisting it could damage it. Place the ribbon in the connector; it only goes in one way. Once in place, push down on the connector tabs to lock it. Now flip the keyboard over and slide it down toward the touch pad and take the bezel and line the pegs up with the holes and push it in place. Then turn the computer over and replace the two screws you removed from the bottom. You can now power on your computer and see if the Toshiba Satellite A100-S8111TD Keyboard works. If it is not working, more than likely the ribbon was not inserted properly.
Regards,
G33k
May 09, 2011 | Toshiba Satellite A100-S8111TD Notebook
I need to replace my fan for my toshiba laptop, nad need to know how to disassemble the laptop to get to the fan.
Toshiba Portege A100 http://www.irisvista.com/tech/laptops/Toshiba-Portege-A100/remove-systemboard-replace-fan-1.htm Toshiba Portege A600 or A605 http://www.irisvista.com/tech/laptops/Toshiba-Portege-A600-A605/disassemble-laptop-1.htm Toshiba Portege M700 http://www.irisvista.com/tech/laptops/Toshiba-Portege-M700/take-apart-tablet-pc-1.htm Toshiba Qosimo F40 or F45 http://www.irisvista.com/tech/laptops/Toshiba-Qosmio-F40-F45/laptop-disassembly-1.htm Toshiba Qosimo G25 or G20 http://www.irisvista.com/tech/laptops/toshiba-qosmio-g25/replace-cooling-fans-1.htm Toshiba Qosimo X305 http://www.irisvista.com/tech/laptops/Toshiba-Qosmio-X305/laptop-disassembly-1.htm Toshiba Satellite 1955-S805 http://sites.google.com/site/electrochain/toshibafan Toshiba Satellite 2410 http://mardou.dyndns.org/Privat/homepage_cms.ns5/content/homepage_tutorials_toshiba_satellite_2410_-_luefter_tauschen.html?Open&lang= Toshiba Satellite A35extlink.png http://www.irisvista.com/tech/laptops/ToshibaA35/Satellite-A35-fixing-overheating.htm Toshiba Satellite A60extlink.png http://tech.icrontic.com/articles/clean_laptop_heatsink Toshiba Satellite A105extlink.png http://www.paulstravelpictures.com/Toshiba-Satellite-A105-Laptop-Overheating-Dust-Removal-Guide/index.html Toshiba Satellite P10extlink.png http://loblog.wordpress.com/2006/03/08/toshiba-p10-schaltet-sich-ab/ Toshiba Satellite P305Dextlink.png http://www.insidemylaptop.com/clean-cooling-fan-toshiba-satellite-p305d/ Toshiba Satellite X205extlink.png http://www.irisvista.com/tech/laptops/Toshiba-Satellite-X205/take-apart-laptop-1.htm List of a lot of pc fan repair guides:http://repair4laptop.org/notebook_fan.html
May 09, 2011 | Computers & Internet
KEYS 9, O, L, AND . CANNOT BE PRESSED IN LOWER CASE.HOW TO REPAIR?
This sounds like a problem with the keyboard itself. Laptop keyboards are somewhat difficult to repair. However, fortunately they're usually easy to replace.
I found a new keyboard for your pc on ebay at the following address:
http://shop.ebay.com/i.html?_nkw=Toshiba+Satellite+A100-S2311TD+keyboard&_sacat=0&_odkw=Toshiba+Satellite+A100-S2311TD+PC+Notebook+keyboard&_osacat=0&_trksid=p3286.c0.m270.l1313
Generally laptop keyboards can be swapped out by prying off the plastic trim at the top of the keyboard. It's usually just snapped into place. This will typically reveal several screws holding down the keyboard. Remove these screws and carefully lift out the old keyboard. You'll see a ribbon cable coming off the back of the keyboard and plugging into a socket. Remove this cable. Sometime this is done by just pulling up on the connector and sometimes there
Sep 28, 2010 | Toshiba Satellite A100-S2311TD Notebook
Hi , This is Venkat, i need Mother board driver for my Toshiba satellite A100 laptop.
Hi, just click or copy paste the toshiba website drivers download link A100 series .
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
Feel free to ask whatever the result. Hope it may helps.
Regards;
VOTIT
Jul 08, 2010 | Toshiba Satellite A100-S8111TD Notebook
Reset toshiba satellite A100-TA2 to factory settings
try this link, at appears as if u can download the disks here
http://www.user-guides.co.uk/toshiba/toshibarecovery/toshiba.asp?keywords=toshiba+satellite+a100+ta2+recovery+discs+downloads&recor=121
Mar 18, 2010 | Toshiba Satellite A100-S8111TD Notebook
PCI device drivers for Toshiba Satellite A100
Here's a link to Toshiba's driver download site. You'll need to choose the exact A100 model (there are several), then choose XP sp2 from the drop down on the next page, and it will give you the list of drivers for your machine.
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modSel.jsp
Jul 23, 2008 | Computers & Internet
Toshiba satellite A100 Monitor problem
LCD issue it needs repair..call tosh if your laptop is still in warranty
Feb 01, 2008 | Toshiba Satellite A100-ST3211 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
76 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
