Question about Apple iPod nano
Apple ipod nano does not turn on
Last night it was working good now it is not turning on and not powering.it is not even getting charged
  • Anonymous Feb 18, 2009
    i tried to take it back but they had a 90 return day policy so  i could not get a new one
    Problem Solver:
  • 10 Answers
This is a critical error, and if it won't charge trough computer or trough charger then you have to bring it back to were you bought it.
I'm sure you will get a new one back, or in the worst case they will send it into fixing and you have to wait for like 2-3 weeks before you get it back, fine as a new one.
Hope this helps you, problems like the one you have can only be fixed manually from the inside of the iPod, and theres not much you can do exept what I've suggested for you.
Posted on Feb 17, 2009
Have a new ipod nano 6th gen 16 GB...and it seems like the battery goes empty really fast. It also doesn't seem like you can really shut it off like my old ipod nano.
first you should let it charge when not in use, apple makes there batteries cheaply and the more it hold a charge the longer the battery will last, secondly you can't shut off your ipod nano, sorry, lots of people complained about this, when you press the button it goes into standby mode and still draws power it will turn off after 36 hours of non use. so i recommend that when your ipod is not in use it is plugged in charging. good luck
Feb 15, 2011 | Apple Audio Players & Recorders
My Itouch will not turn on even though it turned on after I fully charged it. I turned it off and a couple hours later it will not turn on anymore. My iPod will not turn on either! I tried holding the...
on your itouch, press and hold the home and the power button until the apple appears and it reboots.
do you have more than one item here?
the ipod press and hold the Menu button and the action/center button untill it reboots.
if neither work your charger is toast. get an a/c charger and charge them real good and you will be fine.
Good luck
Mar 21, 2009 | Apple iPod touch
Apple iPod Nano 3rd gen won't turn on nor charge
If you guys still have this issue, I would strongly recommend going to the following web site:
http://fixyouripod.weebly.com/
There is an instructional video on your exact issue. :) good luck. I hope it's not too late for your iPod's
Mar 17, 2009 | Apple iPod nano 3rd Generation
Ipod nano won't charge or turn on
My friend has the same problem, and same with my brothers ipod nano. My friend took it to the Apple Store, and they said it was do to overheating, caused by leaving it on the charger to long. They could not fix her ipod, but have you left it on the charger?
Mar 07, 2009 | Apple iPod nano
Turning my ipod nano on
Hi, If you are using a desktop computer, try charging your ipod by connecting it to the USB ports at the rear of the computer.. and charge it for atleast for 5 to 8 hrs...
Then you can try using your Ipod..
Feb 03, 2009 | Apple iPod nano
Ipod nano frozen
there are 2 basic ways the harder one is:
leave it on all night until it runs out of power then charge it and it should work
The easy way:
hold the menu and select button down for a while until the apple logo apears, if it dosnt work follow the harder way
Nov 28, 2008 | Apple iPod nano 3rd Generation
The new ipod nano
How old is it? if it's under warranty apple may fix it.
Simply, if you charge your iPod through you computer then the battery could be damaged. USB ports only put out 5 volts. If you have an AC charger that puts out 9.5 volts then consider charging it with that. Some AC adapters only put out 5 volts for the purpose matching the USB standard, but it's not good for the ipod.
Check out VaxTex @ http://www.vaxtex.com
hope this helps
Jun 27, 2008 | Apple iPod nano 3rd Generation
Ipod Nano won't hold a charge
Hello oob5491,
The battery may be going bad. The internal battery in the ipod has a limited lifespan and will eventually fail. When this happens the amount of operating time you get between charges will gradually decrease unti eventually the unit will not stay charged. It sounds like this is what you are experiencing.
You will want to contact Apple about the unit to get more informaiton on getting battery refresh service,
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 26, 2008 | Apple iPod nano
My ipod doesnt powre on
The 5 Rs: Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with iPod nano. Try
these steps one at a time until your issue is resolved. If one of the following doesn’t
help, read on for solutions to specific problems.
â Reset iPod nano. See “General Suggestions,” below.
â Retry with a different USB port if you cannot see iPod nano in iTunes.
â Restart your computer, and make sure you have the latest software updates
installed.
â Reinstall iTunes software from the latest version on the web.
â Restore iPod nano. See “Updating and Restoring iPod nano Software” on page 50.
Jun 16, 2008 | Apple iPod nano
Ipod nano 4gb pink
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore http://www.apple.com/support/ipod.five_rs/
If you need more asistance, let me know. Good luck.
Jan 12, 2008 | Apple iPod nano
Apple iPod nano Logo
43 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
