Question about Makita 10" Miter Saw LS1030N
Replacing the blade on a Makita 255mm miter saw
I have an Irwin replacement blade plus the 3 washers that come in the pack to go on a Makita 255 miter saw that was bladeless when I got it.
Where and in what order do the washers go?
Do I place 1 of the 2 'narrow' washers, with the slight burr around the edge, within the centre hole of the blade itself, place the new blade in position over the centre drive, add the wider washer and then apply the centre bolt?
Appreciate your assistance
  • watson_gn Feb 19, 2009
    Thanks very much.
    I needed a washer to fit in the arbor. Once that was done the blade fitted in to place comfortably, the flange went on top and then the bolt. Snug fit, just the tiniest amount of 'play' in the blade.
  • 2,176 Answers
I take it you have both flanges and the washer that is behind the innner flange, if not stop there and you need to get them. As far as the blade goes it depends on what size arbor it has. You would need to use the washer that goes on the spindle with no play (movement) and put the blade on the washer I would not use a washer that is thicker than the blade. Put the outer flange on making sure of the direction and then the blade bolt LH thread. Let me know if you have any problems before starting the saw PLEASE and I will help more.
Posted on Feb 17, 2009
Instructions on replacing a 10 inch makita 2400b miter saw with an irwin replacement blade - comes with spacers but not sure what goes where
the spacers are used to make the hole in the blade fit snugly on the shaft
replace the blade in the same way that it was taken off
all you have to do is mount the blade with the arrow facing the direction of rotation
Jun 17, 2017 | Makita Saws
Makita LS 1000 miter bed does not turn freely; probably jammed up with saw dust. What is the best approach to cleaning the rotating bed?
PDF]TECHNICAL INFORMATION - Makita
www.makita.nl/images/files/onderdelen/nl/LS1020-TE.pdf MAKITA 255mm(10") Miter saw. Models No. Description. New Tool ... Optional accessories. The main specifications are common with #LS1000. Saw blade:.Missing: bed
Jul 22, 2015 | Makita Saws
How do I replace the blade guard on my 10" Makita
If you want to replace the plastic cover there is a screw towards the front of the saw that must be removed and then the bolt at the back loosened and the guard will pull off. If you need more info get back to me with the other questions and I will try and help
Jul 10, 2011 | Makita 10" Miter Saw LS1030N
The spring in the blade guard came out while replacing the blade
Hello. Here is the link to the Parts Breakdown of your unit. It should show what you need to know to reassemble your saw. If not, use the contact information to speak to customer service and they should be able to assist you. If this is helpful, please rate it a four-thumbs up, Thank You.
http://www.makita.com/en-us/Modules/Tools/ToolSupport.aspx?ID=370
Dec 14, 2010 | Makita 10" Miter Saw LS1030N
Can't release the trigger lock on the makita 255mm
do you mean you can't depresss the trigger lock to activate the switch or it won't return to lock the switch, let me know which it is and I will try and help, also you can look at the breakdown for this tool at Makitatools.com by typing in your model number so you know what the parts look like and the assembly.
Jan 19, 2010 | Makita 10" Miter Saw LS1030N
Makita 10 inch slide miter saw problem
Is this it? If not, go to Makita site & download image of your saw. Hope this helps:http://www.makita.com/en-us/Assets/images/Products/_PartsBreakdowns/PB_LS1214FL.pdf
Jul 06, 2009 | Makita 10" Dual Bevel Sliding Compound...
Electric brake Fault. Blade Runs On.
some of my ls1040 repairs i replaced the switch and it seemed to correct the problem...
sometimes replacing the armature worked ...but like you did i always started with replacing the brushes
how does the condition of the armatures commutator look?
Jun 05, 2009 | Makita 10" Compound Miter Saw LS1040
Makita 10" Miter Saw LS1030N Logo
360 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
