Question about Riso RZ220 Duplicator
Riso GR 3770 master make shadow on it how to fix it?
Hi
I have just recently broght the GR 3770 used copier and when i made the masters it make the shadoe which is not in the original
all the print also print with that shadow ,
is there any one know how to fix this problem please help me?
Jack
Adelaide
Australia
  • isurubgm Feb 17, 2009
    IT WAS EASY I JUST CLEAN MY GLAS AND SCANER DRAWER BARS . JUST TAKE OFFTHE GLAS AND CLEAN IT WITH CLEAN CLOTH.
    JACK
  • 77 Answers
Check the dust or any scar in scanner (glass).
Posted on Feb 18, 2009
  • Athula
    Athula May 16, 2014
    I have a same Probles byt 2nd or 3rd cut master shadow is gone I think valtege problem can you helpe me my email : athuladi@gmail.com
A risograph 3770 doesn't print when I say 'test print' and says there is a jam
Maybe it is just some dust at the sensor in the exit path! Clean the sensor in the small hole between the exit belts with a brush ...
Aug 23, 2012 | Riso RZ220 Duplicator
Hello we have a RISO GR 3770 - and the cloro drum is stuck in the machine. the green light is not on. how can we get the drum out?
Open front door. If you look at the metal housing below the drum you will see a plate mounteg with two screws. Get it off and you will see a small lever. Turn it right to loosen the drum. Be extremely careful when pulling out the drum. If the drum is not in zero-position it might be a bit difficult (e.g. have a look at the master clamp). Please note that it may be difficult to insert the drum again.
Apr 05, 2011 | Riso RZ390 Duplicator
We have a riso gr 3770 the drum tray will not
under the drum tray there is a rectangular hole, try to actuate the sensor by flat screw
May 10, 2010 | Riso RZ390 Duplicator
Diffrent picture between the original document and master picture
You have to go to your page setup and set for the size you are printing. Also you have to go to the machine and look at the size the paper setting is at.. they have to match.. You may be printing 11 x 17 when the paper setting on the machine are letter.. This will do this...cause the machine will auto adjust to fit onto the settings on the machine.
Jul 22, 2009 | Riso Office Equipment & Supplies
Riso gr 3770 error T14
how can i solve the Error T14 for Riso Gr 3770
Thanks
May 12, 2009 | Riso RZ220 Duplicator
Riso gr 3770
check sensor (photo) that point towards the drum from inside and clean use a flash light to locate good luck
Dec 02, 2008 | Office Equipment & Supplies
Error Code T14 on Riso GR3770
The machine is not alinged. I had that code this evening and the guy came here and in no time he fixed it. is your drum going in the machine? if so then turn off the machine and while pushing down the clear/reset button turn the machine on
Oct 16, 2008 | Riso RZ220 Duplicator
Riso gr 3770
- Please check if they have Master Roll Jam?
- Install properly the Master Roll.
Sep 18, 2008 | Office Equipment & Supplies
Ricoh Aficio 2015
Does your machine have a document feeder on it? If so, turn off and unplug the machine from the wall, and check in back of the machine to see if the feeder is plugged into the unit properly. Try reseating the document feeder plug to ensure good contact. Plug the machine back into the wall and turn it on. If it detects the document feeder, fax and scan functions should be restored.
Jun 16, 2008 | Ricoh Aficio 2015 Copier
203 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
