Question about Dell Latitude D610 Notebook
D610 DST Short Status Test Fail
I have Dell Latitude D610. All of sudden every thing froze on the computer due to which I had to switch my computer off. On turning it on I got a message the my computer failed to read the hard disk. I did the diagnostic test. It failed on DST Short Status Test. The two error codes that I got were 1000-0146 and 1000-0141.
1000-0146
Msg: Unit 0:IDE Status Failed. Status bytes 64 Control Code = 1. Msg = No additional sense information
1000-0141
Msg: No drive dtected
On running diagnostic test from the diagnostics and utilities CD provided along with the computer I performed Express Test. Got the following Errors
Error Code 4EOF:1344
Msg: Block 342932: Oncorrectable data error or media is write protected.
got the above message for many blocks before I aborted the test.
Error Code 4EOF:0650
Msg: IDE Device Failed" The self test failed the read portion of the test.
Can you please help me on what I should do to rectify the problem.
How can I retreive the data on my hard disk.
Thanks.
  • Anonymous Mar 08, 2009
    DST test failed.
  • Dell Master
  • 32,281 Answers
It appears your hard disk has died and it may not be possible for you to retrieve your data.
Remove your hard drive from the laptop and insert it into an USB harddrive adapter, (they are not expensive and you can use it later as a external hard drive). Then plug it into the USB port of a working computer. The computer should/may see it as an external drive, if you are lucky you will be able to copy your data, if not, you are out of luck.
There are companies that can recover data from faulty hard drives, but it will cost you an arm and a leg for their service.
Posted on Feb 17, 2009
  • Chris Hingee
    Chris Hingee Feb 18, 2009
    One more thing you can try (it is an old trick).
    Place your hard drive in an air tight bad and place it in the freezer for one hour. Then connect it to the USB adapter case and connect it to a working computer.
    If you are lucky, you may be able to copy your data before it stops working again.
    Good luck.
Dst short test fail error code 1000-0146
DST stands for Drive Self Test, if it fails the test it means your drive is failing or has failed. replace hard drive
Jun 02, 2014 | Dell Latitude 100L Notebook
Dell Latitude wil a DST short test fail. error
you are correct, time to replace the hard disk drive.
Jan 28, 2010 | Dell Inspiron 6000 Notebook
Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Jan 27, 2010 | Dell Inspiron 6000 Notebook
Dell latitude d610 DST Short Status Test 1000-0146 and 1000-014
you might have jarred the memory loose. take it to a local technician to have them check it out.
Oct 10, 2009 | Dell Latitude D610 Notebook
DST Short Status Test. Error Code 1000-0146
sounds like your hard drive my need changing
Aug 16, 2009 | Dell Latitude D610 Notebook
Computer froze
You will need a new hard drive. Its a DST fail "Drive Self Test". If you have the original Windows CD you could boot to the recovery console and backup what you need before swapping out hard drives.
Jun 23, 2009 | Dell Latitude D610 Notebook
It wont power on.With a diagnostic fail of 1000-0146
DST stands for Drive Self Test, bunnydawg is correct in the drive is failing
Mar 08, 2009 | Dell Latitude D600 Notebook
DST result fails
I would say this is the memory. You said that you checked the memory, and it passed, but did you download a cd called 'memtest x86' ? This will definately make sure your RAM isn't cooked. You boot off of this disc and let it go for a couple hours, it will tell you if it finds errors. Also, if it's the harddrive, you can just replace the harddrive, and then hook it up via USB and retrieve your information.
Feb 05, 2009 | Dell Latitude D610 Notebook PC
Dell Latitude D610 Notebook Logo
9,614 people viewed this question
Alun Cox
