Question about Microsoft Windows 98 for PC
Enabled the boot options in boot manu but unable to boot the linu
I enabled ist boot second boot to cd drive but unanble to enter by using original xp version cd / linux is present o/s
  • 37 Answers
IT DOSENT MATTER WHICH O/S U R USING. THE CD MUST BE BOOTED FROM THE CD DRIVE. JUST CHECK YOUR CD DRIVER. IT MUST BE NOT WORKING PROPERLY.
PERIODICALLY EVERY CD DRIVERS NEEDS SERVICE, LIKE LANCE CLEANUP AND BELT SETTINGS.
JUST SERVICE YOUR CD DRIVER OR CHANGE IT WITH A NEW ONE.
NICE DAY.
KETAN1190
Posted on Feb 17, 2009
Blue creen with blinking cursor
you can do a clean install from your usb. i use this setup for all my flash drive boots.
WinSetupFromUSB - Install Windows XP from USB Flash Drive
This guide will show you, how to use WinSetupFromUSB to create a bootable USB Flash Drive including all Windows source files, plus the following installation of Windows XP. Compare to the different USB_Multiboot versions, WinSetupFromUSB comes with a Graphical User Interface (GUI) and is in my opinion easier to use.
Here you can get the latest version of the program and you will also find many detailed informations about WinSetupFromUSB.
I've tested this guide with a 32-bit version of Windows XP and a 64-bit version of Windows Vista and it worked flawlessly.
Prerequisites:
All you need is:
a USB Flash Drive with at least 1GB of storage
the original Windows XP Setup CD
WinSetupFromUSB
If you use nLite to slim down your version of Windows XP, please keep the following in mind:
DO NOT remove "Manual Install and Upgrade"
under Operating System Options!
I also recommend to integrate Service Pack 3 into your Windows XP source files.
1. Preparations
Download and install WinSetupFromUSB. Default installation path is C:\WinSetupFromUSB.
Create a new folder with the name WINXPCD in the root directory of drive C:\ and copy all files from your Windows XP Setup CD into this folder. Depending on your version of Windows XP, the content of C:\WINXPCD should look approximately like this:
Content of WINXPCD
The following files will show you, which Service Pack is already integrated into your CD:
WIN51IC.SP1, Sevice Pack 1
WIN51IC.SP2, Sevice Pack 2
WIN51IC.SP3, Sevice Pack 3
2. Start WinSetupFromUSB
Connect the USB Flash Drive to your PC and start WinSetupFromUSB. It should show up under USB Disk Selection :
WinSetupFromUSB - main window
3. Select your Source Path
Click on Browse under Windows 2000/XP/2003 Source and navigate to the folder with your Windows XP Source Files. It should be C:\WINXPCD:
Browse to Folder
Click OK and C:\WINXPCD should show up under Windows 2000/XP/2003 Source :
WinSetupFromUSB - source path
4. Format USB Flash Drive
PeToUSB or HP Format Tool are used to format the USB Flash Drive. There is no need to download these programs seperately as they are already included in WinSetupFromUSB.
USB Flash Drives up to 2GB should be formatted with PeToUSB in FAT16, USB Flash Drives with 4GB or more with HP Format Tool in FAT32.
I will use PeToUSB to format my Kingston Data Traveler with 2GB.
In the main window of WinSetupFromUSB click PeToUSB under Format target using to start the program. The USB Flash Drive should show up under Destination Drive. Check USB Removable, Enable Disk Format and Quick Format. Uncheck Enable File Copy under File Copy Options :
PeToUSB
Click Start and answer the following two questions "Continue?" with Yes.
All existing volumes and data will be lost!
If everything goes well, the message "Operation Completed Successfully!" should appear. Click OK and close PeToUSB.
The process with HP Format Tool is similar.
5. Copy Windows XP Source Files
To start the process of copying the Windows XP source files to the USB Flash Drive, click GO in the main window of WinSetupFromUSB. Depending on the write speed of your USB Flash drive it may take a while to copy all files.
WinSetupFromUSB - file copy
At the end the following notice about the Windows installation process should be displayed:
WinSetupFromUSB - notice
Click OK and close WinSetupFromUSB with EXIT.
6. Windows Installation - Part 1
Connect the USB Flash Drive to your PC and turn on the computer. Press ESC at the boot screen and you will be able to select the USB Flash Drive as your boot device from the boot menu.
The ESC key is used by ASUS for the Eee PC series.
Other manufacturers may use other keys, e.g. F8 or F12.
After booting from USB Flash Drive, the following menu should be displayed:
Windows XP/2000/2003 Setup - First and Second parts
Press Enter or wait 10 seconds to get to the next menu:
First part of Windows XP Home Edition setup
Second part of XP Home Edition setup+Start Windows for first time
First part of Windows XP Home Edition setup is already selected. Press Enter or wait 10 seconds to start the Text mode part of setup. During this part you can create, delete and format partitions and finally the setup files are copied to your hard disk. At the end the system will restart automatically.
7. Windows Installation - Part 2
After restart, boot the PC again from your USB Flash Drive. The same menu should be displayed:
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to start the GUI mode part of setup. During this part you will be asked for your product key, timezone, usernames and other necessary informations. At the end the system will restart automatically.
8. Windows Installation - Part 3
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to Start Windows for the first time. The Windows installation process will be finished and finally the Windows Desktop will appear.
DO NOT disconnect the USB Flash Drive too early!
At next startup you can boot into Windows from your hard disk.
Notes:
After successsful installation, the following boot menu will always be displayed during startup:
Please select the operating system to start:
Microsoft Windows XP Home Edition
USB Repair NOT to Start Microsoft Windows XP Home Edition
If you don't plan to use the repair option and want to boot directly into windows, you have to do the following:
Open the file boot.ini in the root directory of drive C:\ with Notepad:
[Boot Loader]timeout=30
Default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS
[Operating Systems]
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(1)partition(1)WINDOWS="USB Repair NOT to Start Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
Delete the following line:
DO NOT delete the wrong line!
Your computer may not boot the next time!
Save changes to the file.
At next startup the boot menu will not be displayed.
If you want to keep the repair option, you can reduce the time to display the operating system options from 30 to 5 seconds:
[Boot Loader]
timeout=5
At next startup the boot menu will be displayed only 5 seconds.
gd luck
Mar 09, 2014 | Computers & Internet
Trying to reinstall windows XP on Dell Dimension 8300....cant' start up using the CD drive...
Inpect the computers preexisting operating systems to ascertain compartibility to windows XP. Only XP computers would recognise XP operatign systems. Attemptign to install windows XP onto alternate system either windows 98, 2000, mellanuim or Vista XP or 7 is least achieveable unless the old system were erased or new empty storage disk drive were acquired and replaced.
Feb 03, 2011 | Compaq Presario 5000 PC Desktop
I try to format my pc 1st time its operating system is windows xp i have inserted a xp cd ..... and click reboot but no change occur and i am also unable to format all other drives which donot have os...
First of all does the cd boot into the xp installer. If not the the setting in the Bios would be to boot from HardDisk first. Get into bios by the appropriate key on boot and change the boot order to cd/dvd first and then hdd. Now save settings and restart the system and the xp cd should boot up and you will be able to install xp. Be careful as you may delete all data on the hdd.
Some bios use the del or f2 key to enter, see press __ to enter setting's or bios.In that goto the boot order and change appropriately.
If xp is already installed then if other drives are not acessing saying not formatted then the easy fix would be to right click on non formatted drive and click on format. Then you will be able to access it. Do same for all other drives.
Jan 15, 2011 | Computers & Internet
Unable to install XP OS to MSI lap top
insert a bootable xp cd into the cd drive and hit enter continuosly...it ll ask to hit any key to continue from cd...hit any screen and follow the onscreen instructions...
if it doesnt works, try this....
u can log in to the setup by pressing del key or F2(depends upon make and model) and change the drive booting order...change the first booting device as CD/DVD and second booting device to HDD...
now it ll prompt you to hit any key to start from CD/DVD....
Make sure you have inserted a bootable XP CD in CD drive....Bootable XP CD's can be created only from another bootable XP cd by taking an image from that cd and writing it back to the cd...you can use NERO Copy disc option for this purpose...it ll create an iso image and you can use only this to write into the disc...
Mar 29, 2010 | MSI Crystal M677 Notebook
Unable to formate window 7 ultimate
You need to boot the PC with the XP CD and you will get an option to delete and format partition before new install. If you dont have the option to boot from CD at startup you will have to enter setup / bios and enable CD as first boot device. Cheers from Scott
Mar 17, 2010 | Computers & Internet
UNABLE TO BOOT FROM WINDOWS XP
First Make sure your cd/dvd rom detected in bios.
For that First open cpu cabinet refix power cable and ide cable to harddisk.
Then check your bootable recovery disk and cd/dvd rom working fine.
When you power up the computer press F1 or F2 or "del" key to enter in bios .
Then go to boot option and set first boot device as your cd/dvd rom then save settings and exit.
Then it boot with disk .
If still not boot then there may be some issue with cd/dvd rom or bootable disk.
Let me know if you need more assistance.
Thanks.
Oct 13, 2009 | Computers & Internet
Dell Dimension 8300 - Can't Boot from XP Disk
When in doubt do without, that is remove the new hard drive cable and power, remove the DVD drive and try loading booting the XP from just this CD device. Enter the BIOS and check if the system sees the device. If it's not found in the BIOS then you'll never boot anything. Address it as the Primary device on the cable (I don't use CS) and see if the BIOS sees it.
If you get CD device seen in the BIOS then try to boot the CD in it. If it boots then power off and connect up your 40gb drive (optioned as Primary) on the other cable. Now power on as check the BIOS for the drive and the DVD device. If both are seen then boot the cd and try to load XP. After it's up and running install the other CD device as a Slave on one of the cables.
May 28, 2009 | Dell Dimension 8300 PC Desktop
Need to Rewrite/Reboot Dell Desktop 2400 series and cant
Press Delete at start up, change the first boot device to your cd drive, then F10 to save settings and restart. Put your Windows XP disc in the drive and press any key when prompted to boot from the cd.
Jan 01, 2009 | Dell Dimension 2400 PC Desktop
PXE-E53 and 1962 No operating system found error messages
Install Windows XP and then Ubuntu
Any Linux Using GRUB (preferably) Or LILO will automatically fix all "No Operating System found etc. Problems"
Sep 11, 2008 | IBM NetVista PC Desktop
Microsoft Windows 98 for PC Logo
56 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
