Question about KitchenAid KSM5PS Heavy Duty Stand Mixer
Bmw 325i engine number
Where do i find the engine number located for a 1993 325i bmw
  • 8,197 Answers
The serial number is located on the lower left side of the block, toward the front.
Posted on Feb 17, 2009
Beaters for sunbeam mixer 03116
Remove the battery from the mixer and locate the number on it, go to eBay and input that number.
Dec 19, 2016 | Sunbeam Food Mixers
Age of a Hobart Stand Mixer by Serial No.
the ML or spec number would be trackable from the resource site.
Enter the model number and check the date of the corresponding build number.
https://my.hobartcorp.com/resourcecenter/Pages/FilterByModel.aspx
If it does not have a safety cage fitted, there are some areas of the countyr where it can not be used commercially, untill one is fitted. Depending on the model, that would be a thousand dollars or more.
Mar 23, 2014 | Food Mixers
Where do you find the serial number for a 5 quart glas bowl for the Artisan mixer
The serial number for all KitchenAid mixers is located under the base of the mixer. You will need to carefully tilt the mixer over, and underneath the mixer you will find a label with the model number and serial number.
Feb 16, 2013 | Kitchenaid 5 Quart Glass Bowl Artisan...
Model g kitchenaide manual is hard to locate. Please help
Locate your model number and then try searching on this site:
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KA_EN_CA
If you can not locate your model number, for a hand mixer it should be on the bottom of the mixer adjacent to the mixer attachment holders.
Thank you for using FixYa!
Aug 26, 2011 | KitchenAid Food Mixers
K45ss mixer works fine except when whipping cream there are small black specs appearing in the bowl that probably have gone unnoticed with darker mixtures. I suspect some type of oil leak
Yes this is probably a oil leak. it can come from two possible location one of which can come from the transmission gasket that goes around the mixers center seem, if this is broken, worn or improperly seated it will need replacement. part number for the transmission gasket is 4162324. another possible location is around the cirrcular mixing gear at the front of the machine. if the seal inside the unit are damaged or worn this can cause oil to leak striaght down into the very food you are preparing. part number for the seals are 3180163. there are 4 of them, and they would require taking apart the whole unit. hope this helps.
Thanks
Sep 27, 2009 | KitchenAid K45SS Classic Stand Mixer
I need a contact number for a hobart600 parts,thanks
www.hobartservice.com click on "locate an office" enter your zip and it will bring up your local Hobart office.
Sep 20, 2009 | Food Mixers
BMW door seal?
make sure you have the new one on hand also the glue you can pick up the glue at a local autoparts store. Now lay the new door seal out in the sun while you are taking the out one off so that its warm and stretches easy, once the old one is off clean the railing that holds the gasket with rubbing alcohol on a rag, then apply the glue as you put on the gasket
May 30, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Bmw 325i
Your battery is located in the trunk on the passenger side of the vehicle. To disconnect and remove the battery first remove the black plastic cover which houses the battery. Then disconnect the negative lead (black) followed by the red (positive) lead. Make sure the leads do not touch the battery while removing the battery. There is a small bracket located at the bottom of the battery box. This bracket holds the battery in place and can be removed by unbolting the 10mm bolt which holds it in place. Once this bolt is removed you can remove the metal bracket and lift the battery out of the bin. Installation is the exact reversal of this process.
Dec 17, 2007 | KitchenAid KSM5PS Heavy Duty Stand Mixer
KitchenAid KSM5PS Heavy Duty Stand Mixer Logo
436 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
