I am trying to get my new used copier to turn on, Canon Image runner 3300i,but I continue to get the error code E000732-0001. I have disconnected, cleaned and reconnected all the leads on the photocopier and still the error code keeps appearing. The log book says it was last serviced in 2006 and had done 55,000 copies. any assistance in this matter would be greatly appreciated. Thanks!
  • themilnes Feb 17, 2009
    Thank you, I will try your suggestion, but as the Canon Image Runner is located 5 miles away in our local cummunity hall, may I have some other solutions to try at the same time, in an attempt to cut down on the running back and forth.
    Many Thanks, Peter.
  • 544 Answers
try to check the availabilty of your connection if it is workling properly and follow this.
here are some solution to your fax machine error you can try this instruction to follow..
L5000,5500,7000,8000: To enter service mode Data Registration, #, Ram Clear is under #8 clear
Faxphone 20 ram clear
Turn off the power switch
Turn off the memory protect switch (located on the bottom of the machine)
Turn the power on
Press function # 2 0 start
Turn the power switch off
Turn on the memory protect switch
Fax L770 fuser gear wears out easily under heavy usage. White gear with 2 sets of teeth.
Inkjet models such as the B160 will hold faxes in memory and refuse to print if excess ink has accumulated on the pad under the cartridge's nose. Remove the cartridge and wipe up excess ink with a cotton swab.
if it is still not work properly i suggest you to go or have a technician to fix it.
because if we do this stuff and not work the last problem that your fax machine is encountring are in the hardrive unlt technicians can open on it and hold the sensitive spare parts of the unit.
thanks,
Posted on Feb 17, 2009
  • Mark Milan silaran
    Mark Milan silaran Feb 18, 2009
    hello their again..
    if you follow all our instruction and still not work..
    i prefer to suggest to you that bring your unit to a computer shop and ask for a assistance of a technician.
    the problem is not in the software it is on the hardware already..
    thank you..
    hello their again..
    let us know if our instruction work to your unit.
    anyfurther question don't hesitate to ask again.
    please don't forget to rate..
    thanks,
  • 19,396 Answers
To start check the dial in the paper tray is set to the paper format loaded into the paper tray, that can also cause the problem.
The problem often happens because the plug in the back of the copier for the reader is unplugged or the cable is damaged.
Check the connector to the reader controller
    Guru:
  • 832 Answers
Hello there!!!
E732 error is a poor connection between the reader controller and the main controller.... so check cables and connections. I strictly suggest that if you had the last service 3 years ago? better call your nearest specialist regarding the problem. If you still have your warranty certificate that would be great. Or check this website for more info. http://www.usa.canon.com/html/download/imagerunner.html
  • Dennis Jambalos
    Dennis Jambalos Feb 17, 2009
    Hello there!!! thanks for using Fixya.com!!
    I suggest that you should call your technician to check it accurately and ofcourse with a wise concept of advise. I know, you got to pay something for him but instead of buying a new one right away. It is better to give it a shot and let him check thoroughly the machine.
    Cheers! don't forget to mark! thanks!
    http://www.usa.canon.com/html/download/i...
  • Dennis Jambalos
    Hello there again!!
    I suggest really that you should call your technician. This will save your time as well, coz it is very important for the machine to be checked up. I believed that you have tried to troubleshoot but unfortunately, nothing is positive. I guess, 5 miles is worth to try. Good luck! Don't forget to mark! thanks! cheers!
    Brigadier General:
  • 3,614 Answers
This means that the control board has a problem, at this time you need a service tech to go and check the unit/
    President:
  • 2,110 Answers
It is a communication error between the reader and main controller.
or try it
1, Power off the printer
2, Unplug the printer's power cord, wait 5 seconds then replug the power cord in.
3, Hold the Power button for 6 Beeps
4, Release the Power Button
This will reset the printer and should resolve incorrect cartridge detection problems
Canon ir 2202 error code e0141-0000
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Canon&model=iR2200
Jun 19, 2015 | Canon Image Runner 2022 Copier
Error code E002
I googled: canon imagerunner 2022 copier error code e002
This appears to be the best and most informative: http://www.fortwayneprinterrepair.com/wordpress/2014/08/12/canon-ir-2200-2800-reset-fuser-error/
If not, try some of the others from the above search.
May 07, 2015 | Canon Image Runner 2022 Copier
Have same prlm to carrte my canon image runner model No 2535 the is E000000 code error like that.. plz sir sent me to day Ans.. thank u so much..
Dear
do the following
CLEAR >ENGIN > ERR CLR; and then turn OFF and then ON the
power. or after entering the service mode FUNCTION>28>FUNCTION.
If not solved do check connection of the Connectors (Thermistor Connector and AC Connector).
Replace the Fixing Main Thermistor (Film Unit).
Replace the DC Controller PCB.
Thanks.
Jan 25, 2015 | Canon 2535i Copy Machines
I have problams with my canon ir2320 error e000007-0000
Oct 10, 2012 | Canon Image Runner 2022 Copier
I have a canon image runner 330 s, My question is. It is asking me to conact the finisher? What is a finisher and where is it located?
A finisher is a whole seperate piece that sits beside the copier or sometimes it sits partially in the copier. Its used for collating and stapline mostly. There are also other options you can get( hole punch, folding, etc.) If your machine is telling you to connect the finisher and you dont have one i would try restarting the whole machine. Turn the main power of the copier off and let it stay off for about a minute. Turn it back on and see if the message goes away. If that doesnt work let me know and ill look into it further.
Mar 13, 2011 | Canon Office Equipment & Supplies
The Screen on Canon Image Runner says E000 - can't make copies
Your Fuser just went , Call you Canon independent or Authrized dealer, he will need to go into the simulation to reset this error. Usually E000 is either a fuser or fuser web error. I'll need to look this up in the service manual. most likely you'll need a quailify technician to reset this error code.
Mar 04, 2009 | Office Equipment & Supplies
Error code e000007-0000 for a canon image runner 22006
You have a problem with the fixing film. It is not a case that you have to reset the machine and carry on. Replace faulty parts in fixing and then clear the code. Most probably you have a damaged fixing film.
Aug 22, 2008 | Office Equipment & Supplies
29 people viewed this question
k24674
