Question about ASUS S478 VIA P4V533-MX Motherboard
No display my processor ram and other componets are ok if the board on the processor must be heat up but my processor is still cool after computer on
  • 530 Answers
Hi im josh in cebu phils. friend one of the reason of the computer that will not display is the video devices. if you used video card.it is not compatible like if you use lower memory vdeo it will occure.try to use higher memory video 256 or above. or if the video is built in on the board try to go to bios setup then change.choose higher bit in the displasy settings. hope i helped you. good luck
Posted on Feb 17, 2009
My mercury motherboard pentium3 display not show
fast check monitor unplug & see massage in monitor screen - no signal so it's ok then check ram.if it ok so *********** board graphic problem change *********** board.
May 30, 2012 | Intel Pentium III, 800MHz (229725001)
Asus Mother Board(P5GV-MX) display off, Boot time sound also off, The ram is OK. Processor can't check. Please give me solution.
Oct 18, 2010 | ASUS P5GV-MX Motherboard
No Display on Mother Board
Have you try troubleshoot with working monitor, display card or your matherboard and processor,
Usually no display problem occur becouse of one hardware between monitor, ram, motherboard, displaycard and can be your processor problems.
You can try troubleshooting one by one of your computer hardware to get problem occur
Jul 21, 2010 | Intel Desktop Board D845WN Motherboard
My d845 mother board dont display
Its probably caused by the RAM, have it checked. If you can do it yourself, clean the RAM as shown in the image below:
Install it back to the computer and turn it on. If problems persist try another RAM, it may already need replacement.
In case your computer has 2 RAMS installed, clean them both. To test if there is a busted one, install the one then turn on the PC, if it works shut down the PC. Then try the other one, if it works too then it just needs some cleaning. But if not, one of them needs replacement. You can still use your computer with 1 RAM, just don't expect the same performance as having two RAM. Resetting the CMOS may also help you in the process.
Please reply if this has helped you. Thanks.
Oct 26, 2009 | Compaq Evo D310M 845G P4 Motherboard
Display problem
Problems can be more than we almost can list here.
Check the cpu that it will work in another board.
Check the ram modules that they will work in another board.
When checking the board, remove all cards and try with the cpu and ram installed. Make sure you have the right ram in the right slots. This can make a diff. in some boards.
If your processor and ram are okay, then a problem is existing with the board.
Sep 08, 2009 | Asrock P4I45GV R5 Motherboard
Lga motherboard no display, processor doesn't heat
if your processor does not heat up it's probably dead.. try running it without the fan and see if the heat sink still doesn't heat up
Sep 07, 2009 | ASUS P5V800-MX Motherboard
Mother board problem@ monitor & ram is ok but no display in monitor
check whether the cable is write if it is ok then press del key while the system is booting
Jul 31, 2009 | Intel Pentium 4 1.7G, 1.7 GHz...
Intel d845gvsr
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
108
Jul 08, 2008 | Intel D845GVSR Motherboard
Intel d845 gvfn display problem.
sir i have a problemmy mother board intell d845 epi/d845gvsr my mother board is cannot desplayed or display is not come but if i remove rame the mother board is give error beaps if i attach ram board is not displayed
Apr 25, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
I can not open my bios
Dom you see anything when you turn on the computer? Like the Whattype of board and as soon as you turn on nthe computer you should be rapidly pressing the f1, f2, or the delete button over and over, depending on what the bios key is? It should tell you this too at start up.. If you dont see anything replace the board, as it maybe a fault of the componets on the board and not the bios. Oh and make sure the Microprocessor is plugged in correctly too i seen that problem once before. good luck
Jul 17, 2006 | Intel D850MV Motherboard
ASUS S478 VIA P4V533-MX Motherboard Logo
81 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
