Question about Canon PIXMA MP160 All-In-One InkJet Printer
Paper jam I have removed the paper and yet it is still flashing 3E or E3 and the alarm is lit up I have tried pressing the tool button but that does nothing I have tried uninsating and re instaling but every time I try to install it tell's me that I already have latest softwear and it stops loading
  • 29 Answers
I think you still have a piece of paper in the printer. Probably a small corner stuck under a feed roller. I expect you will need a pair of long nosed pliers to pull it out. Will be very hard to see and possibly even harder to remove.
I had this problem with a lazerjet.
Posted on Feb 17, 2009
Alarm light blinking and it keep showing E3,when i want to print,it keep asking me to remove the jammed paper,but i've checked 101 times!! no jammed paper
If the paper out tray is closed or not fully opened, then open it fully.
If that doesn't fix it, then the printer may believe that paper is jammed. You've already checked for jammed paper, so reload the paper supply and press the BLACK or COLOR button.
If that doesn't work, then disconnect the power for a few minutes and reconnect.
If that still doesn't work, there is probably a bad paper sensor or controller board.
Is your printer still under warranty?
Jul 13, 2014 | Canon PIXMA MP190 All-In-One InkJet...
Washing machine saying 3e starts a cycle then it stops and flashs 3e
The "E3" error indicates that a washer's motor is not running properly. The cycle can usually be restarted by pressing the "Start/Pause" button. However, if the error code appears again, you should contact an authorized service technician.
A 3e error is a possible drain clog,Remove drain line and check for any clogs.
Apr 25, 2011 | Washing Machines
Wont print ready light and alarm light flashing
When the printer "Ready" and "Alarm" LEDs flash as shown, please check the following points:
1.Paper Jam: Clear the paper jam referring to "How do I clear paper jams?"
If the printer does not automatically resume printing, press the control panel button.
2.No Paper/ Misfeed:
-The paper cassette may be out of paper or not properly installed.
-If it is empty, load a new stack of paper into the paper cassette.
-If there is paper in the paper cassette, make sure it is straight.
-If the paper is curled, straighten it before printing. Sometimes it is helpful to remove the paper, turn the stack over and put it back in the paper cassette.
-Reduce the amount of paper in the paper cassette, and then try again.
-Make sure you use paper that meets Brother's recommended paper specifications.
-Reinstall the paper properly, and then press the control panel button. The printer will start printing again.
Dec 06, 2010 | Brother HL 1430 Laser Printer
Canon Pixma MP160 shows errors E3 and won't print
Error E3 : Check if the paper has jammed in the machine, reload the paper in the machine correctly and then press [Black] or [Color].
Paper Jams :
Cause : Paper jams in the paper output slot/ Auto Sheet Feeder.
Landscape Credit Card sized paper jams inside the machine.
Action : Remove the paper according to the following procedure.
1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the paper output slot, whichever is easier.
* If the paper tears and a piece remains inside the machine, open the Scanning Unit and remove it. Be careful not to touch the components inside the machine at this time. After removing the paper, close the Scanning Unit, turn the machine OFF and turn it back ON.
* If you cannot pull the paper out, turn the machine OFF and turn it back ON. The paper will eject automatically.
2) Reload the paper into the machine and press [Black] or [Color].
* If you have turned OFF the machine in step , you will need to retry printing, because this operation cancels any print jobs in progress.
If you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after removing the paper, contact a Canon service representative.
Important : You cannot load Credit Card sized paper in the landscape orientation.
Hope this helps.
Have a good day.
Dec 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Error code E3 with no paper jam
it is problem your printer can not feed paper properly or problem paper feed sensor please try to resum button press when occard this E3 signal or clean sensor or claugth
Nov 21, 2009 | Computers & Internet
Canon pixma mp 145 e3
e3 means paper jam ..look for any jammed paper inside ...then try to reset..
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Jul 04, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Brother printer problem
Manual Feed Command.
1. Press the Job Cancel button to cancel the print job. Delete the print
job in the print queue on the computer. You can quickly access the print queue by double clicking the Printer icon in the task
tray or dock.
2. Turn the printer power switch OFF on the right side of the printer.
Check that the front cover is closed.
3. Turn the printer power switch ON while holding down the GO button
until the Toner, Drum, and Paper LEDs are lit.
4. Release the GO button. All LEDs will be off.
5. Press the GO button 8 times. The green Status LED will flash briefly
while the printer is reset. After the printer is reset the Status LED
will be lit green.
6. Print the Print Settings by pressing the GO button three times. If
the Print Settings pages do not print and the Paper LED is on again skip
to the next section - No Paper in the Paper Cassette.
If the Print Settings pages print, the problem is isolated to printing
from your computer. The Paper Source of the Brother printer driver or
program you are printing from may be set to MP Tray or Manual, instead
of Auto Select, Tray 1, or Tray 2 (if the optional paper tray is
installed). To check the Paper Source setting of most programs, click
File and Page Setup or Page Layout. You may need to click the Paper
Source tab or Paper tab depending on your software application. Verify
that in the Paper Source section does not list MP Tray or Manual. Choose
Auto Select, or another relevant source such as Tray 1. Click OK. Try printing the document again.
No paper in the paper cassette.
1. Pull the paper tray completely out of the printer.
2. Insert the letter or legal size paper into the paper tray with the
top edge of the paper first and the print side down. Make sure that the
paper is flat in the tray and below the maximum paper mark. If using a
paper size other than letter or legal, the paper should be loaded in the
MP Tray. The MP Tray can print on paper from 2.75 in. by 4.57 in. up to8.5 in. by 16 in.
3. While pressing the blue paper-guide release lever, slide the paper
guides to fit the paper size. Make sure that the guides are firmly in
the slots. For legal size paper, press the lever located at the back of
the tray and pull out of the back of the open tray.
4. ReinstalI the paper cassette back into the printer. Press the GO
button. If the alarm clears, no further troubleshooting is needed. If
the alarm continues, follow the steps below.
Paper Jam at Paper Pick-up.
1. Turn the printer power switch OFF on the right side of the printer.
2. Remove the paper cassette from the printer.
3. Elevate the front of the printer slightly to locate the jammed
paper.
4. Gently remove the jammed paper.
5. ReinstalI the paper cassette back into the printer.
6. Turn the printer power switch ON. If the alarm clears, no further
Oct 02, 2008 | Brother HL-2040 Laser Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
47 people viewed this question
old marine
old marine
