Question about Texas Instruments TI-83 Plus Calculator
Can i do fractions
I can do fractions on this, it was given to me for my algabra class
  • mojowhitlock Feb 20, 2009
    Thank you for the help!!!
Yes, you can do fractions. If you have 1/2 or 0.5, you can put it in your calculator as 1 divided by 2.
Posted on Feb 20, 2009
I need help with improper fractions may you please help me thanks
An improper fraction is simply a fraction with the numerator being larger than the denominator.
To make it an improper fraction from the mixed number given, just multiply the whole number (2) by the denominator (3), then add the numerator (2). The result is the new numerator and the denominator remains the same.
In this case (2 2/3), it would be 2 * 3 + 2 for the numerator....or 8. So 8/3 would be the improper fraction.
Oct 11, 2017 | Miscellaneous
Where is mod on calculator
Sorry to disappoint you but this calculator does not perform modulo calculations. However you can use the fraction key [a b/c] to enter the numerator and denominator. If the result is given as an improper fraction a b/c, then a mod c=b.
If the result is given as an improper fraction (that would be you input) press [SHIFT][a b/c] to convert it.
On the display integer part, the numerator of the fraction part and its denominator are separated by a symbol as seen on the screen capture below.
Jan 24, 2014 | Canon F-502 Calculator
I WANT MY ANS IN FRACTIONS NOT DECMIALS
Set the Input Output Display mode to MathIO. In thsi mode answers are given in fraction-radical forms whenever possible. To toggle between Fraction/radical and decimal, press the S<=>D key.
To access the above screen press [SHIFT][MODE](SetUp).
Jan 20, 2014 | Casio fx-300ES Calculator
Equivalent fractions
Equivalent fractions are fractions that have the same value.
2/6 is equivalent to 4/12, 8/24, 16/48. From a given fraction you can generate an infinity of other equivalent fractions by multiplying the numerator and the denominator by the same integer.
All the equivalent fractions can be generated from a single one, namely the fraction that has the lowest numerator and denominator. This one is called the reduced fraction or the reduced form of the fraction.
When you have a fraction you can try to simplify it: You look for a common factor in the numerator and the denominator and you divide both by it. Keep doing so until you can no longer find common factors to cancel out. The last fraction whose numerator and denominator have no common factor is the reduced form of the family of equivalent fractions.
Now, what is you question??.
Apr 26, 2012 | Office Equipment & Supplies
Hello: I have a very simple T125 X Solar Hand-held
Sorry its not possible with this particular model.
What my teacher in 6th grade did was make it mandatory for all of us to buy ti-30. This may sound drastic but its very cheap (only 10 dollars) and has severed me well for almost 9 years. Its can convert decimals into fractions and do native fraction manipulations.
Feb 27, 2011 | Texas Instruments TI-83 Plus Calculator
I cant figure out how to be able to take a fraction and subtract it to another fraction on my TI-84 PLUS calculator
Given two fractions a over b and c over d, you can subtract the first from the second by entering
( c / d ) - ( a / b ) ENTER
The calculator will give you a decimal result, which you can (probably) convert back to a fraction by using the >Frac command. Press MATH 1 ENTER
Feb 02, 2011 | Texas Instruments TI-84 Plus Calculator
There are 40 pupils in a class.twenty five of them are boys.what is the ratio of boys to girls?
If there are 25 boy in a class of 40 pupils, there are 40 - 25 = 15 girls. The ratio of boys to girls hence is 25:15, or as reduced fraction 5:3 = 1.6666...
Jan 16, 2011 | Texas Instruments TI-30XA Calculator
What is the radius of a 30'' pipe
30" diameter? Radius is 15" (half of diameter).
30" circumference (distance around) is a little more complicated...
The number pi.gif is the ratio of the circumference of a circle to the diameter. The value of pi.gif is approximately 3.14159265358979323846...The diameter of a circle is twice the radius. Given the diameter or radius of a circle, we can find the circumference. We can also find the diameter (and radius) of a circle given the circumference. The formulas for diameter and circumference of a circle are listed below. We round pi.gif to 3.14 in order to simplify our calculations. diam_formula.gif circum_formula.gif
Nov 17, 2009 | Gateway FPD1975W 19" LCD Monitor
Problems with fractions on the Casio fx-115es
To convert fractions to decimals or decimals to fractions, you use the [S<->D] key. Each time you press the key the result is displayed in the other format.
Alternatively, If you multiply or divide two integer numbers put a decimal mark at the end of one of the numbers (any one). The result will be displayed in decimal format.
Hope it helps.
Jun 01, 2009 | Casio FX-115ES Scientific Calculator
Texas Instruments TI-83 Plus Calculator Logo
66 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
