Question about GE WBSR3140DW Top Load Washer
Replacing the glass lid on a GE profile washer
my parents in law had their tempered glass lid on their GE Profile washer shatter, when they weren't even using it. GE coughed up a replacement lid, but didn't come to the party for the installation. Can someone please advise us on how we can safely install the new lid ourselves? We don't want to force it and risk shattering the replacement. Thank you very much.
  • chris_oneill Feb 17, 2009
    thought I should mention that I don't know the exact model of their washer, I am perhaps hoping that there is a generic method in installing the glass lids on all of GE's Profile washers. Thanks again.
  • Anonymous Apr 11, 2009
    Just had the EXACT same thing happen to me today! Very scary....I have the repair man coming after Easter on Monday.
5 Suggested Answers
  • 641 Answers
SOURCE: Ge Profile Harmony Washer doesn't drain properly.
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Good luck!
Posted on Aug 16, 2007
hiltonjug
  • 612 Answers
SOURCE: ge profile washer WPSR3100W1WW won't agitate
I see this pretty regular. You have a bad transmission. This is very common with the older GE's. To replace the transmission will run around $340 / $400. Not sure about your area. Just be glad you got this much use out of it, you are one of the very few that have. From 1998 till 2007 I owned my on repair company where I did GE's warranty work in my area for them. During that time period. When I found a GE washer under warranty doing what you are describing. GE would warranty the whole machine. They would have me destroy the machine after I would deliver the customer a band new one. GE knows they had a bad transmission and it cost them a lot of money. It was cheaper for them to replace the washer than have me repair it. The transmission list price was $298.00 back then. A word of advice, when you replace it. Buy a Whirlpool, Kenmore, Maytag. These brands hold up the best. I have the least service calls for Whirlpool and Kenmore. Both are made by the same people. Kenmore is made for Sears. Good Luck.
Please rate this solution if helpful. Thanks
Posted on Aug 21, 2009
SOURCE: GE Profile wpre6100gowt, wont agitate or spin
same problem
Posted on Sep 06, 2009
  • 3600 Answers
SOURCE: Brand new GE Profile leaves clothes soaking wet
It is under warrenty call the store where you bought it and have them look at it. If you mess with it it will void your warrenty, belt may not be working or transmisson may not be shifting. The house call will be at no charge.
Posted on Sep 10, 2009
Testimonial: "thankyou for the help, I thought I had just made a bad buy. They sent someone out right away and it turns out this particular machine had a bad part."
  • 327 Answers
SOURCE: GE Profile front loader washing machine is leaking
Hello, this is usually the door seal, most machine incorporate a one piece combined door seal and outer drum seal(often just called a DOOR GASKET), the door seal are put in on the front panel first in the factory, then the drum assembly is put in and the seal pushed over the outer drum. This means a lot of stripping down has to be done just to replace the drum to the door seal.
Thanks
Posted on Jun 14, 2010
I need to replace the glass lid
This is the cheapest lid that I've found online:
http://preview.tinyurl.com/washingmacinelid
I didn't find any part numbers for just the glass.
Good luck.
Aug 12, 2015 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Ge profile wpre6150k1wt washer does not complete cycle. washer stops with tub full of water. Will not start again. tried unpluging to reset. this worked a couple of times but not working now
Hi
First make sure to test the lid switch assembly, you can jump it to test it. If the lid switch and motor is also fine then the control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 29, 2011 | GE Profile WPRE6150K Top Load Washer
How do i remove the lid on a ge profile harmony washer?
Use a putty knife to remove the front panel first/
The putty knife will insert between thr top of the lid and the front panel about 2 inches in from each side.
The panel will pull forward then up to remove it.
Then remove the screws holding the lid down.
You may have to open the control console to remove the lid.
Apr 03, 2011 | GE Profile WPRE6100G Top Load Washer
GE Profile WPRE6100G Top Load Washer how do you bypass lid safety switch? Unit pumps but won't spin.
worst washer I ever owned how do you bypass water level so you can wash a comforter man I am so disappointed with this GE Profile energy saver if I can't move the water level up I'm going to put it out along the road a trash day and it's only 4 months old
Dec 19, 2010 | GE Profile WPRE6100G Top Load Washer
How do you remove the washer door
Thanks very much, but my husband found a way to remove the lid on the washing machine. There are 3 screws on each side of the lid that have to be unscrewed in order to remove the lid.
Jan 13, 2010 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
When the installer tested my newly purchased GE Profile washing machine, I saw him test the incoming water temperature with the lid open. How did he defeat the lid switch?
Hi, open lid , look carefully there's a slot where you can activate switch, use something none metalic, like pen and press to activate.
Aug 02, 2009 | GE Profile WPRE6150KWT Colossal Capacity...
GE Profile wont spin,why?
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wiring to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you replace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!! Thanks for using Fix-ya. A high rating would be appreciated for your free question :)
Jul 26, 2009 | GE Profile WPRE6100G Top Load Washer
The most likely cause of your problem is the lid switch.
Oct 27, 2008 | GE Profile WPRE6100G Top Load Washer
GE Profile WPRE6100G will not spin
hi thanks for the question. i think the problem is with the lid switch . lifting the lid 10 times wont help if the switch is faulty check the lid switch thanks the appliance doc
Sep 20, 2008 | GE Profile WPRE6100G Top Load Washer
GE WBSR3140DW Top Load Washer Logo
258 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
