Question about Noritz 6.3 Gallon Residential Tankless Water Heater - N-063S
Pressure fluctuating during its working water pressure goes up and within minuets it comes down to nearly zero
  • ali_kalkhora Feb 17, 2009
    water pressure in pump out put goes up and down.
    i mean when thermostat trigger the burner the pressure goes up and after openning water tap it goes down very fast.
  • 547 Answers
Add pump to main line thank you for useing fixya
Posted on Feb 17, 2009
  • 2 more comments
  • albert getty
    albert getty Feb 17, 2009
    oh change the pump if it's not that old get ahold of manufacture and have them replace whole unit.
  • albert getty
    i just looked more then 5 people have same problem get ahold of maker thank you
  • albert getty
    intake and output for water are backwards
  • albert getty
    albert getty Feb 21, 2009
    please let me know if your pipes are backwards thank you
Vailant ecotec plus 837 - Water pressure and temp is too high
Pressure inside the tank will rise along with the water temperature. As the water inside cools the pressure will wane until the heating element turns on and reheats the water with a subsequent rise in pressure. Running the hot water at the same time will draw heat energy from the boiler and lower the internal temp and pressure as well.
Jan 21, 2014 | Water Heaters
Water temperature fluctuates with tankless
Have you ever tried to pump water for a fountain... It is so tough and you need larger and larger pumps to get it to go 7 feet high to let's say 10 feet high. Having the on demand water heater in the attic dramatically drops it's pressure. It's best to feed it with a 1 inch or at least 3/4 inch pipe downstairs before it splits the hot and the cold to get the best pressure everywhere then the least pressure will be when it reaches the 2nd floor. but the heater won't cut out because the pressure it even greater downstairs.
Nov 30, 2013 | Rinnai Water Heaters
Hot water tank does not work when shower is on, it does however work when the faucet in bathroom is on. It quit working in the shower about a month ago.
    If inlet water temperature is over 70°F due to geographic location, water maybe very hot out of the tap. This requires a lot of cold water to be added with it in order to attain a useable hot water temperature. The addition of too much cold water will overpower hot water demand from the tankless water heater. This slows the flow within the tankless water heater, decreasing it below activation point, which shuts off the heater. The end result is nothing but cold water coming out of the outlet. See: TWH E2-04 Overcoming fluctuating temperatures [PDF].
    If the water pressure in the home is erratic and the water flow is not consistent while a tap is opened, then the temperature of hot water will fluctuate. The minimum water pressure for the home should be 30psi or greater. For people on well systems the minimum pressure range is 30-50psi. The use of a pressure reducing/regulating valve is an effective way to maintain constant water pressure to the water heater. Watts brand 25AUB- ¾" or N35B-¾" pressure reducing/regulating valves or equivalent is suggested.
    Major changes in flow rate can adversely affect the output water temperature of the heater. Increases from one major fixture running to multiple fixtures running at one time can cause the temperature to fluctuate. Stay within the heater's specifications. See: TWH E2-03 Outlet temperature vs. flow rate [PDF].
From the Bosch website.
Good Luck,
Dec 16, 2010 | Bosch PowerStar AE125 AE125 Whole House...
My Rhem Ruud G76-200 water heater leaking from below? Can this be repaired?
If it is actually leaking from the bottom of the heater, then it cannot be repaired. Have you looked to see exactly where the water is coming from? Sometimes a leak at the top of the heater, will then leak through the insulation and out the bottom. Another possible source could be from the temperature/pressure relief valve leaking and coming out of the down pipe that goes near the floor or drain. Try to find the source of the leak. It is not practical or safe to repair a tank that is leaking.
Oct 03, 2010 | Rheem Tank Water Heater G76-200, 76 Gallon
Water turns cold very quickly
I had the EXACT same problem (installed my tankless last winter and worked fine, now this summer it fluctuates, have to turn the shower completely off and then on again to get any hot water and then it only lasts for a couple of minutes!) Argh - it is frustrating!
Here's what I found: the demand for hot water is lower during the summer (hot) months because the "cold" water coming in is already quite warm. You don't need as much hot water to make the shower temp comfortable. SO, my tankless was shutting off due to low flow demand. I've removed the flow restrictor from my shower head and it helped alot but didn't completely solve the prob. Next step is what has been recommended to me by several people but is much more expensive - change the pressure valve on your shower to a temperature valve. Or just wait til winter and it should work ok again :)
Jul 06, 2010 | Bosch & Tankless LP Hot Water Heater
Fluctuating tempture during showers. how can this
if you have a low flow shower head this could be the problem have seen it many times before try removing the restrictor and try again
Feb 28, 2010 | Eemax EX380T2T2 Staged
The hot water will not come on intermitently. I
if your on a private well, it sounds as though your loosing enough water pressure to shut the heater off,.(which is right before the water pump comes on),....tankless heaters turn on by sensing water flow, and of course off when flo stops,......water pressure tanks often need to be re-charged with air for pressure to stay even,....does your water pressure fluctuate?
Jan 10, 2010 | Rheem EcoSense by 7.4 GPM Tankless Water...
Water Temperature Fluctuates
no the tub faucet is the only faucet that is wide open you might have to not run full blast on the faucet , your tankless water heater is under sized for the application, to many gallons per min going thru the unit, look at the rating chart for your unit, the r94 is only 9.4 gallons per min, and a tub faucet can be upto 5 gallons per min, depending on the faucet,,
Jan 16, 2009 | RTO American Heat Tankless Electric Water...
Noritz 6.3 Gallon Residential Tankless Water Heater - N-063S Logo
97 people viewed this question
Top Noritz Water Heaters Experts
Level 1 Expert
Mack Baxter
Are you a Noritz Water Heater Expert? Answer questions, earn points and help others
