Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
Red and double screen
I have a 48" 1080i Samsung projection tv. I have tried auto and manually using the convergence but the middle of the screen is still red and it has a double picture. Can anyone suggest anything. If anyone has had this problem and had it fixed what was the estimated cost. Thanks
  • steveherq Feb 17, 2009
    model# HCL473W
    HCL473WBX / XAC
  • 4,234 Answers
It is likely that either the connections on the convrgence ICs are poor or the ICs are defective. Please post the model number so I can give you more specifics.
Thanks,
Dan
Posted on Feb 17, 2009
MY SAMSUNG TV :MODEL SP4R1HL1XSHI Version SV01 was working alright until we moved to a new location. Now I have the visuals in the top quarter of the screen presenting double image and a small red 'crest'....
Tv have problems known as a convergencce problems.Check ur remote go into tv menu.Go to convergence adjustment,try auto convergence.The auto convergence din't fix ur problems.Than the tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.Try the website like Tvrepairworld.com to buy a whole rebuild convergence board for the replacement.The Akai/Samsung DLP tvs used the same convergence board.
Sep 08, 2010 | Samsung Televison & Video
My red wont line up left to right , picture is good in the middle of the screen but not on the sides
The R,G,B colors alignment wouldn't line.That mean ur tv have a problems known as a convergence problems,it dead.The tv convergence board require the 2 STK convergence ICS and some or all it resisrors to be replaced,to solved the convergence problems.The shop will cost $300-350 for parts and labors.
Jul 06, 2010 | Hitachi 46F500 46" Rear Projection...
Red, green and blue colors don't match up on screen.
Please replace convergence out ICs (usually two) in TV.
If it is Hitachi 43UWX10B then its convergence out ICs are available in Part Store
Thanks.
Aug 24, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Words are doubled red borders???
Just to clarify, it sounds like what you are saying is that the image appears to duplicate in either red or blue along the edges of the image (especially white lettering and probably increasing along the boarder of the TV). This is resolved by converging your TV. Convergence will drift normally on large screen projection TV's over time or through moving them. The Hitachi 57f500a has a feature called "Magic Focus" (pg 36 in your manual) which will auto converge the image. If the auto converge feature doesn't work, on page 37 in your manual, it explains how to converge manually. If you do not have the manual, I have the image of the pages below. If for some reason this doesn't work, please provide additional info and detailed prior to rating the help.
Apr 20, 2009 | Hitachi 57F500 57" Rear Projection...
Seeing double on my samsung rear pro
The convergence IC's are definitely bad. They are not a plug-in device, they solder in so this is a big job.
Mar 30, 2009 | Samsung PCN5425R 54" Rear Projection...
RED AND GREEN DOUBLE AND BLUR PICTURE HELP PLEASE
You have a convergence problem. Components are shorted out and must be replaced. Unless you're a technician, there's really nothing you can do at this point.
C-Dog
Feb 03, 2008 | JVC AV-56WP74 56" Rear Projection...
Red Convergence on JVC AV- 65WP74
convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | JVC AV-65WP74 Rear Projection Television
Samsung HCL4715W 47 in. Rear projectio
IF YOU HAVE DOUBLE IMAGES YOU CAN GO IN THE MENU AND TRY TO ADJUST THE CONVERGENCE, OR US THE AUTO JUST. ON SOME SETS IT IS ON THE FRONT. IF IT DOESN'T CORRECT THE PROBLEM THEN IT IS CONVERGENCE. I REPAIR 2-3 A WEEK. WE DO IT IN THE HOUSE, NO NEED TO TAKE THE SET OUT. MAKE SURE THEY REPLACE BOTH CHIP'S AND THAT THEY USE ORIGINAL PARTS, THE GENERICS DON'T HOLD UP. THEY USUALLY LAST 3-5 YEARS DEPENDING ON THE USAGE OF THE SET.
DON..
Jan 27, 2008 | Samsung HCL4715W 47" Rear Projection...
HCM4215W Green convergence problem
Hi Greg,
Sounds like you have a bad convergence chip in the convergence board. Unfortunatly, about 80% of the rear projection sets I work on have this similar problem. I suggest that you change both chips ( there are 2 of the same ) and remember to use heat sink compound as this is why you not have the problem ( excessive heat destoys electronic components). Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 19, 2007 | Samsung HCM4215W 42" Rear Projection...
Convergence Problem
I'm not a 100% positive this would fix your TV, but I found the convergence board on PartStore.com for about $80. Hope this helps.
Nov 16, 2007 | Akai PT5598HD 55" Rear Projection...
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
157 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
