Question about Acer Aspire 5520-5908 Notebook
Wi fi connection
I can't connect to internet wireless, because some problems with Atheros AR5007EG Wireless Network Adapter -Vista drivers , after installing driver everything stop and the monitor is with lines and points
  • 4 more comments
  • paul ereng Feb 17, 2009
    hi
    my acer aspire 5520- 5912 cannot connect via wireless or et hernet cable, any body with answer to solve this problem.
    Thanks
    Hi
    Mu acer5520-5912 cannot connect to the internet via wireless or ethernet cable.please help
    Thanks
  • Anonymous Feb 27, 2009
    acer 5315
    same problem- on ethernet & wireless
    its funny that no on has posted any solutions at all.
    and kind of REALLY sucks
  • Anonymous Mar 01, 2009
    Acer Aspire 5520
  • Anonymous Mar 04, 2009
    I updated my bios to a newer version and when I restarted windows, the wireless stopped working. I tried to install new drivers for the Atheros AR5007EG / chipsets / realtek audio / network adapters but nothing works.
  • custom42 Mar 29, 2009
    Network adapter is unable to connect. I believe because I accidentally changed the passphrase. I have no idea what the original passphrase was and the new passphrase is not working. Suggestions how to correct this?
    I have:
    tried to reinstall the modem- didnt work
    creating new connection/network- didnt work
    system restore- didnt work
    the atheros driver is blocked.
    However, I can take the laptop to work and wireless works fine there- so the problem is here within the home. Would calling the service provider to change IP work?
Try to check on the device manager if the wireless adapter and the ethernet adapters were installed properly. If it appears with a questionmark, uninstall it and try reinstalling it without the ethernet cable connected.
If you are using Vista system, after installing the adapters, go to the network connections and just click on tcp/ip then click on properties. Exit from the window by clicking ok until all windows will be closed for the network connections. Reboot your pc and try if you can obtain a connection.
Posted on Mar 11, 2009
  • john Jan 26, 2012
    thnks for the help but ive tried all that. spent hours on fone to talktalk. and they seem to think its a driver for my wireless card that out of date.
D link router connection Hi I have recently bought a D link Dir 615 router and cannot connect to internet on my vista laptop. I have set up wireless on another laptop, PS3 and blackberry phone and they...
Everything looks normal:
Description . . . . . . . . . . . : Atheros AR5007EG Wireless Network Adapter
Physical Address. . . . . . . . . : 00-1D-D9-44-F8-15
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::1c05:824a:4808:dd81%14(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.102(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 21 February 2011 13:48:48
At the command-line prompt, try: ping www.ucla.edu
If it responds, then you *DO* have a good Internet connection.
Feb 21, 2011 | D-Link Computers & Internet
I have a compaq presario F756nr with an Atheros wireless wi-fi card in it. Can I replace the wi-fi card with a Broadcom 802.11 b/g wireless LAN card?
no you cannot replace the built-in wi-fi card...
if you try to change the drivers for atheros wi-fi to Broadcam driver, your wi-fi card will not function anymore.... but you can always install another WI-FI card in your laptop... you can buy a USB Adapter or a Cardbus(PCMCIA) adapter for this purpose...if you want your wi-fi signal strenth and range to be higher, you can opt to buy an adapter which comes under N standard....N standard wi-fi adapters are capable of connecting at a speed of more than 300mbps(practically) to any N standard device like router....
Mar 29, 2010 | HP Compaq Presario F756NR Notebook
Problem with on or two network adapter
First make sure that wi fi switch of your laptop is turn on.
Then check that wi fi netowkr adapter driver is installed perfect and enable.
Go to device manager and enable wi fi adapter.
For check device manager right click on my computer icon then click on property then hardware ->device manager.
Then you see all driver list.
Then enable wi fi .
Also right click on my computer places icon then go to proeprty then you can see your network adapter right click on wi fi adapter then click on "view available wi fi networks."
then connect your wi fi .
Let me know if you need more assistance.Thanks.
Oct 01, 2009 | Acer Aspire 4720 Notebook
I have an Acer aspire 5610z Just acquired a Verizon MIFI2200 53CF Secure Ability to network 5 wireless computers Was able to configure below not problem IBM T60 Compaq Presario Not the case with...
This method will hard reset the wireless drivers back to default settings, but before you perform this remove power from the modem and router for 2 minutes reconnect power and wait another 2 minutes for them to settle down.
Go to your laptop, right click "computer" select "manage" and then "device manager", a list will populate, then click on the + sign next to "network adapters" and right click on the wireless adapter and "uninstall" the device, reboot the PC and wait for windows to detect the wireless card and install the drivers for it, this will appear in the system tray (bottom right hand side) when its done try to connect again.
Good luck
Aug 03, 2009 | Acer Computers & Internet
Connect Additional Computers to my network
ok
first install your wi fi network adapter driver in computer also if you have laptop then there is switch for wi fi on it.
Then go to my ntwork polaces there you see your wi fi network.
Also check your wi fi enabled in router .
Let me know
Jun 23, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Netopia 2247 NWG can't find Atheros AR5007EG WLAN
ok heres the solution.
goto start,control panel,performance and maintainance,administrative tools,services.
Scroll down to bottom to WIRELESS ZERO CONFIG,double click and click start.
now exit and wait a minute and your limited or no connectivity should change to connected,
let me know if this helps,
Patrick.
Aug 02, 2008 | Netopia 2247NWG-VGx Wireless Router...
Connect to the internet
i look for driver Atheros AR5007EG wireless network adapter for acer aspire 5315
Jul 09, 2008 | Computers & Internet
Acer Aspire 5520-5908 Notebook Logo
714 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
