Question about LG LSC091PMA Split System Air Conditioner
One head freezes
I have a LG ac split with two indoor heads, only one head which runs most of the time (located in a computer room)is freezing, the other head( in a regular office) runs fine,what can be the problem? when the filters are clean and the fan runs good.
  • luke bussenschutt May 11, 2010
    to test try running the freezing head by its self, if it runs fine with out freezing the problem is low gas charge.
  • Felizardo Erilla
    Felizardo Erilla May 11, 2010
    Which one have the longest piping? And how many feet?
  • 400 Answers
You are short of refrigerant, the evaporators (heads) run in series and if you run short of refrigerant one of them will have reduced or no cooling depending on the amount of refrigerant left in the system. You should make sure that a leak in the system is found before just recharging the system or you will have to do it again in the near future.
Posted on Mar 04, 2009
My LG split Ac is running some times but some times not working and showing error code CH09
Split = Outdoor unit fan problem. Check Outdoor fan motor is plugged in, Electrically & Mechanically sound, if not replace motor, otherwise replace PCB.
Multi V= Indoor unit EEPROM error - Replace the indoor unit PCB, and then make sure to do Auto addressing and input the address of central control.
Jun 06, 2015 | LG Heating & Cooling
Mini split problems
One check your indoor fan is correctly running ( blowing a good quantity of air. Two look for oily residue around flare connectors indoor and outdoor usually indoor first. This indicates a leak. Thus why the ice . Good luck
Nov 27, 2013 | Heating & Cooling
Have a LG Split Room AC Model LSN2665 DMO and its freezing from the inside what should we do?
Split a/c freezing. Reasons; Indoor coil and air filter blocked- clean it. 2.Less rpm of blower motor-Replace capacitor.3. short of gas-find leak,arrest and do gas charging.
Jan 04, 2011 | Heating & Cooling
Ice fallingfrom split ac
Try turning off the ac unit for about an hour.(Your might have too small of ac unit or just have the ac set too low..Causing the coils to freeze.
May 27, 2010 | LG Art Cool LA121CNP wall/window Air...
Water flowing inside the room thru indoor unit
blocked drain
low gas charge
cracked drain pan in head unit
Apr 21, 2010 | LG LS-K1830CL Cool Mini Split Air...
What is the function of dry mode in ac, when to use dry mode, and when to use cool mode and what about heat mode.
Dry Mode in AC is to dehumidify the room the fan cycles on and off and the indoor unit temperature drops below freezing which causes condensate to collect on the coil and as a result the humidity level of the indoor air is reduced
Jul 13, 2009 | LG L1204R Air Conditioner
LG Split Ac-Sprinkles water in roomafter a while of cooling
first check to make sure that the indoor unit is very slightly off level sloped to the drain area also turn off power and inspect the indoor coil with a flash light to make sure all the fin area is open the drain pan has two possible drain connections if they are both hooked up then the primary "lowest"
could be stoped up a blast of water or air to the drain line should clear out slime also make sure their is a trap in the drain line or the water will only drain dwhen unit is off hope this solves your problem thanks
May 15, 2009 | Heating & Cooling
Split ac not cooling
cak split in door unit 1st watar lavel and in sait watar tra blok paip.
Apr 07, 2009 | LG Heating & Cooling
Lg split indoor fan runs non stop
Hello Hamid,
The unit is designed to run the indoor fanmotors continuously when in cooling mode on both indoor units (evaporators). The reason is that this circulates the air and the temperature thermistor or sensor is able to sense return air temperature and in turn start or stop the outdoor unit and compressor as required according to the setpoint temperature. The reason for either unit not reaching setpoint temperature can be a couple of reasons. A) Incorrect design - the unit may be too small for the application. You can calculate this roughly at 650BTU per square meter of room in a relatively warm ambient climate. Or secondly B) The outdoor unit has leaked and is short of refrigerant. You can check this when the outdoor unit is running by feeling the thicker copper tube on the right hand side of the unit. This should be cool to cold. If no temperature difference is felt, it is short of refrigerant. Hope this helps you. Goodbye
Aug 11, 2008 | LG LS-L1210CL Mini Split Air Conditioner
LG LSC091PMA Split System Air Conditioner Logo
145 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
