Question about Toshiba Satellite A135 Notebook
My 4 usb ports of toshiba A130 donot recognize flash disks
I have a Toshiba Satellite A130 laptop. it was working fine for 18 months since i bought it. last week my brother inserted an iPod, and a pop up screen come which says "one of the USB devices connected to this computer is malfunctioned. and Windows failed to recognize." after unplugging the iPod, i tried my camera, my usb flash disks, the same message is appearing.
Does any one have a solution for this problem, and reactivate my usb ports.
thank you in advance for your help.
Hi segidom
Sure let me try.........
I would request you to try with the following steps:
If u are using Windows XP as ur operating sysyem please perform with the folowing steps:
1.Right click on My Computers
2. click on Manage
3. click on Device manager
4. In the right side u find all options of the hardware components installed in ur notebook
5. Find for the option Universal serial Bus controllers
6. Find whether any yellow mark is there on that option or sub options of that menu especially on USB Root hubs.
7. Right click on the USB Root hub (all) present in that menu and click on disabe option and then wait for some time
8. After few minutes Right click on the USB Root hub (all) present in that menu and click on enable option and then wait for some time
9. Now Restart the note book and check
If u think that an yellow mark is present on any of the option then please right click on the particular option and click on update drivers and follow the steps as per mentioned in that particular window.
Posted on Feb 17, 2009
Usb port won't recognize mouse
the usb port may be damaged or bad solder connections, do a system restore taking the it back before the problem occured. "long shot"
Mar 19, 2012 | Toshiba satellite c660
My Toshiba Satellite 2805 S301 USB 1 port, does not recognize my Passport external Hard disk drive. What can I do to solve this problem ? Thank you, very much for your assistance.
Hi
assuming that the external hard disk is usb
i would try this
plug in the external hard drive
then go to device manager
then hover your mouse at the top of the box
and look for a icon that says scan for new hardware
then hit the scan icon
your laptop may or maynot recognize the external hard drive at this stage
now leaving it plugged in restart the laptop
and with any luck windows will now recognize it
good luck
hope you get sorted with it
Mar 20, 2011 | Toshiba Satellite 2805-S301 Notebook
I have a toshiba satellite laptop A135 series and it won't recognize my toshiba external hard drive. However, the drive works fine with my HP
This can be an issue with the USB port, or the drivers.
Is the hard drive a Power HDD ? that means it has 2 usb chords one for power and one for data transfer? coz those might not work with laptops, also has it ever worked with the laptop ?
Thanks
If this was helpful, then kindly rate me.
Nov 10, 2010 | Toshiba Satellite A45-S121 Notebook
One of two USB drives wont recognize anything
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Dec 13, 2009 | Toshiba Satellite A205-S5804 PC Notebook
Toshiba satellite memory stick problem
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Oct 09, 2009 | Toshiba Satellite A135-S4527 Notebook
My usb flashdrive is not recognized on any of my usb ports on my Toshiba satellite m35x-s163, can you help?
Test usb port with another device,
check in my computer for the drive,
Test usb flash in another Pc,
Manufacturers website for a possible driver.
if still not working then it's faulty,
Regards
Rpf
Apr 14, 2009 | Toshiba Satellite M35X-S163 Notebook
I have a toshiba satellite a135 s2276. The usb ports are all enabled but it won't recognize any device plugged in Also when i boot up the screen is kinda pinkish in color then goes black. Everything works...
The problem is with your harware. Either there is some problem with your USB ports( Mother Board) or its due to conflicting drives. Reinstall all your USB port drivers.
Mar 24, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshiba satellite a135-2326 usb not recognized
its a driver issue most likly down to vista (as always) have you tried the latest updates from the microsoft website yet?
Aug 11, 2008 | Toshiba Satellite A135-S2386 Notebook
Usb device not recognized
If your laptop is running Windows ME, 2000, XP or above, it should automatically do the New Hardware thing, and mount the drive. If using Windows 98se, you can probably get the drivers from the vendors web site.
Sometimes a usb port will not provide enough power for a specific device. Does the thumbdrive work in other computers? And do other USB devices work when connected to the laptop?
Feb 06, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135 Notebook Logo
162 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
