Question about SanDisk 2GB microSD Memory Card
Micro SD not reading
My 2GB micro SD card is not reading in cell n PC too....how do i make it work without the loss of datas?
  • 1 more comment
  • TSTT Feb 20, 2009
    ok well i had my micro sd card in my jacket pocket and when i put it back into my phone it wasnt reading it then i tried putting it into a sd card reader on the computer and still NADA......i noticed it was kinda bent too but i want to know if there is any way of getting the infomation on the card or if its just my luck.......
  • TSTT Feb 20, 2009
    sd card not detected by my phone
  • TSTT May 11, 2010
    my phone is not reading my sd any advice on wat to do?
  • 629 Answers
If you are unable to access/view the contents of the card, chances are, it needs to be reformatted for it to work again, which means, data will be loss. You may, however, try to search the web for a data recovery program which you can first try to use before reformatting the drive.
Posted on Feb 17, 2009
My 2gb sandisk micro SD card reduce the size after formatting
Possible micro SD bad sectors. To check your micro SD bad sector or not, you use the HD Tune software. To restore the capacity micro SD, which is done is Low Level Format. You can use the software HDD Low Level Format Tool.
How to use HD Tune and HDD Low Level Format, you can see here
Transcend Repair Bad sectors
How to repair micro SD, you can see in here
MMC Repair Without Losing Data Video 2
Oct 12, 2011 | SanDisk 2GB microSD Memory Card
I have locked my memory card and forgotten the password. Format card also requires password and my laptop cannot read it. Please help.
All you have to do is:
Step One:
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process of removing the micro SD password
Step Two:
The first alternative - use the software HP Drive Key Boot Utility
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
Oct 11, 2011 | SanDisk 2GB microSD Memory Card
When I enter my memord card in nokia 311 it say the operation is failed and the memory card is not formatted.how to remove virus from my memory card and replace my music and Image.
Step One (save data)
When do the data recovery process, you can find the cause of damage to the micro SD.
Cause of the damage the virus infected (solutions: see method 1)
When saving data, be careful, do not recover the virus file. You must choose the proper file for the recovery.
Cause of the damage bad sectors (solutions: see method 2)
Damage to the partition table (solutions: see method 1)
Micro SD write protect. Characteristics: (solutions: see method 3)
1. Micro SD can be opened, the data can not copy and paste (from the micro SD into a computer, or from computer to the micro SD). When the format, the message "Removable media write protect".
2. Micro SD can not be opened, and when the format of the message "Removable media write protect".
Step two (repair micro SD)
Method
Using the HP Drive Key Boot Utility, the first way
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extract.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
Method 2
Method 3
To write protect a micro SD cases, 40% probability of success.
Using the HP Drive Key Boot Utility, a second way
1. Open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - select Backup / Restore - click Restore - From filename, click Browse - Look In. Find the file initrd.img
2. If you are using Win XP, the location of the file in C: \ Program Files \ Compaq \ hpdkbu \ flash \ initrd.img - Next
3. If you are using Win Vista or Seven, the location of the file in the folder where you extract the files cp006049.exe. After the file is found, press Next
4. This process, will take a very long time, so you wait. This way you do for a capacity of 2GB. This involves when, the first way did not work. If the process runs smoothly, the chances of success, but if the process is running very slow, the possibility of failure and immediately stop the process. If you are unsure, or afraid to make mistakes, you should not do it this way.
5. After the process is complete, remove the micro SD card from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Oct 02, 2011 | SanDisk 2GB microSD Memory Card
My lg t300 isn't reading my micro-sd card, so what should i do to fix it?
Try checking locky micro SD card on hand just in case locked. Next do an anti virus scan on your PC, usually data files have Headen infected due to virus, or did the format but not before first copy the existing data and save it on your PC. Next copy and paste data on the micro SD card. nex on a micro SD card input, and open menu phonsel phonsel, next select memory. if still not read, error mean micro SD card, and replace with a new
Aug 22, 2011 | Gomadic Car Cup Holder for the LG T300 -...
How do I use the Micro SD port?
hi.
sd port is use for read yr sd card.. put yr sd card in sd port then yr can read it from clisk my computer icon and ten yr card will be locaten in g/h/f or try click 1 by 1 memory stick drive
regards
Feb 21, 2011 | eMachines Desktop / AMD Athlon Processor /...
Hi..how do I transfer phone contacts to sd card?
hey you cannot transfer contact in sd card, unlike the picture images etc. but phone contacts you cannot,
Nov 15, 2009 | Samsung SCH-i760 Smartphone
The SD m2 2gb Micro does not work on my phone
the card shows sign of a rom ic being lost its firmware
Sep 05, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
Unlock 1 GB micro sd memory card of Kingston Made
code to unlock the micro memory card 1GB of nokia 6300
Jun 23, 2008 | Nokia N95 Cellular Phone
try mo yung appliction na memorypaswordfinder
May 10, 2008 | Nokia 6300 Cellular Phone
SanDisk 2GB microSD Memory Card Logo
789 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
