A mouse died in the powder dispenser of my samsung J845
It fell down the dispensing hole. How am I going to get it out.
  • fiona_lintor Feb 17, 2009
    Hi Mike the mouse fell down the intake into the bowl of the machine. i've tried removing the bottom water filter and flushing. bits of fir are coming out but not the main body. I have a samsung J845 front loading washing machine.
  • Michael Anderson May 11, 2010
    Please send your model number and I will tell you how to remove it.
    Mike Anderson
  • 15,935 Answers
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
How do I repair a samsung french door refrigerator rf 265,266 with interior water dispenser that parts fell into cabinet?
The parts are readily available for your repair, however, you should contact a qualified Samsung technician. If the dispenser is not assembled correctly, the water flow may not shut off. The resulting water damage could be very expensive compared to a service bill of $150.
May 01, 2014 | Samsung RF265AA Bottom Freezer French Door...
Kenmore HE 4t Elite Front Loader Washing Machine
Inside the dispenser drawer, at the bottom there is a tab that you can push down to remove the dispenser drawer. Remove the drawer and check if the dispenser holes are clogged, this is a common cause.
Mar 22, 2008 | Kenmore Elite 45986 Front Load Washer
Water leaking out of soap dispenser?
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.If helped, click.
Mar 17, 2013 | Washing Machines
I had a problem with my f8086ldpwashing machine...when i turned on the machine the clothes are being washed but it is not taking the detergent powder from the case that is provided..that is why the washing...
there are little holes in the dispenser that are clogged pull the dispenser drawer out & the roof of dispenser is where the holes are blocked unblock the holes with a pin and you should be right. this only usually happens when you are using to much powder. you only need a quarter of a scoop these days the powder is so strong everyone is wrecking there machines because there using to much powder.
Jan 10, 2011 | LG Washing Machines
My whirlpool dishwasher soap dispenser is apparently not opening during cleaning. I find dirty dishes and clumps of soap in the hopper. Whirlpool quiet partner II
I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
Apr 17, 2009 | Dishwashers
ZANUSSI ZWF1421 NOT TAKING CONDITIONER
You have a blockage in the soap dispenser
Remove the dispenser completely from the m/c, and wash and thoroughly clean every piece of it
Get a stiff piece of wire, make a hook at one end, and poke it into all the holes you can see at the top of the soap dispenser housing.
This is to clear any blockage here, which can prevent the water taking down the conditioner.
Dec 16, 2008 | Zanussi ZWF1420W Front Load Washer
Washing m/c does not take softener during washing cycle.
Hi. Assuming the washer has completed the rinse sequence, there is a possibility the dispenser part of the valve could be faulty. I assume that you have put the conditioner in the right compartment of the dispenser.. If all else seems to be o/k, I recmmomend thay you once again thouroughly strip and clean the dispenser..
The other possibility is that the hole where the water comes in at the top of the dispenser is blocked.
You need a stiff piece of wire with a hook on the end and poke each hole that you can see in the top of the dispenser compartment
This should solve the problem
Please leave feeed back.
Thanks
Dec 03, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Dishwasher problem
Symptoms:
Dispenser lid is open. Caked powder at (what would be during normal operation) bottom edge of soap dispenser or caked powder fallen onto dishes or dishwasher bottom. There may be loose powder in rest of dispenser or spilled down inside door or onto dishes underneath dispenser.
Solution:
Keep the area around the soap dispenser lid clear when loading the top tray.
Explanation:
The soap dispenser needs to swing open during the wash cycle. In many dishwashers the top tray has an indentation as wide as the lid of the dispenser. This allows the top tray to be as large deep as possible while still allowing space for the dispenser lid to open. People often pack their dishwasher with things overhanging this gap.
During the wash cycle the catch will release but the overhanging cutlery or crockery prevents the lid from opening all but a few degrees. Some water will splash in but not enough to wash out the soap powder. The soap powder at the bottom of the dispenser will then cake.
When the front door is opened the spring loaded lid, which is partly open, will of course swing fully open and you'll be convinced that the lid opened normally during operation. If this is the problem then if you're very careful and open the door very slowly you can actually hear the lid flip open. Also, depending on when the lid opens, how far it opened during operation and how fast you open the door you may find soap powder spilled down to cover the dishes at the front or down the inside of the door. This happens when you first open the door and obviously there couldn't be loose powder there if the powder had emerged while there was water washing around. Seeing the lid open as you open the door is a lot harder but can be done on some machines.
Oct 24, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwasher
If you are you using a liquid soap or packets that will be the main problem.If your unit fills with water circulates the water and drains the water,and also heaters are working then you probally need to change to cascade powder soap.The film on the dishes is soap.The unit has so much build up in it that when it gets to the rinse cycle it is rinsing dishes with soapy water.You need to get 2 medium bowls fill both 2/3 up with white vinager,place one in upper rack and one in lower rack and run unit on longest cycle letting the vinager splash out during wash.do this with no soap and no dishes.Having soft water will allow you to use less soap.
Apr 23, 2008 | Dishwashers
GE Monogram DIshwasher
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way. A.
Apr 21, 2007 | GE 24 in. Monogram ZBD6880KSS Stainless...
Washing Machines Logo
78 people viewed this question
Top Washing Machines Experts
