Question about HP Computers & Internet
About harddisk while installing xp ,message is there that installation can not continue because no harddisk drive is installed on your computer or no harddisk drive connected to computer.
  • 3,940 Answers
If this is a newer system, this issue is the XP CD you are using doesn't have the needed hard drive controller driver it needs to see the Hard Drive.
Because this is Windows XP, you have only 2 options to resolve the issue. XP will only load a controller driver during install from one of 2 locations. Either a floppy diskette drive or from the XP Cd itself. XP has controller drivers for most systems available at the time the CD was burned, but newer systems, especially ones with SATA hard drives do not have supported drivers in XP CD images. You options are as follows:
  1. Connect a USB Floppy Diskette drive to the system, download the needed driver (If one is available) copy the extracted driver files to the root directory of a floppy diskette and put the diskette in the Floppy drive, then boot the XP CD again. The driver should load automatically if the floppy is in A: Drive when you boot to the CD.
  2. The second option requires slipstreaming the driver (Same one downloaded to a floppy in 1) into the XP image. (This takes a good bit of knowledge in bootable cd creation)
If all this seems to be quite the hassle, then install Vista,
Posted on Feb 17, 2009
XP Installation and win32k.sys
this problem is occured due to corrupt or scratched disk.
u need to install XP with new bootable disk.
Sep 18, 2009 | Microsoft Windows XP Professional for PC
Computer will not boot up
This is because of either the system has shutdown while it was processing a windows file. sometimes repairing the OS or running a CHKDSK /R in the recovery console will fix this problem. if that doesnt help i recommend you change your HDD
Sep 16, 2009 | Dell Optiplex 740 Desktop Desktop Computer...
Windows XP Blue Screen
change your ide cable or sata.
Reset your bios settings pull cmos cell from motherbord for minute so all settings are defaults.
Also boot your computer with winxp disk then if you able to enter in setup then go to recovery console mode and run "chkdsk /r' command .
Also check your harddisk is master set jumper in master position .
Aug 18, 2009 | Computers & Internet
Windows XP won't start
for that you need winxp bootabler disk.
Tehn boot your computer with tht and go to recoverry console.
Then type in command prompt "chkdsk /r"
then press "y"
then it fixc error on harddisk.
Then after completing it restart your computer and boot with harddisk then it ok.
Jun 20, 2009 | Computers & Internet
yes you'll have to format the drive before you put xp can use a boot disk with something like fdisk on can boot using a HIREN boot disk (which has FDISK on it) or Roadstarter which is a bootable CD with a whole host of utilities including FDISK.....
or boot with a windows XP disk and choose the repair with console option the command prompt type in FDISK and you will wipe all the data and partition tables you a raw data drive to install Win XP to
Dec 22, 2008 | HP Pavilion DV2500T 14.1" NOTEBOOK LAPTOP...
What is this
if you are doing a clean XP install the CD will ask if you if you want to change your partitions.Afterwards it will automatically format the hard drive.Some of the OS discs dont come with drivers you will have to hunt for them on the internet.If you are using a restore disc copyied from a working machine it should have generic drivers already loaded in the disc.
Mar 12, 2008 | Computers & Internet
You must disable the native mode for the SATA in setup mode.
***NOTE*** be sure that you have all of your drivers for the SATA and all drivers for windows xp before beginning.
Driver problem
you need to follow these instructions:
0. Download the XP Sata driver from the support page and create the driver floppy, attached usb floppy drive to laptop:
1. Power up, hit F10 to enter setup
2. DISABLE SATA native mode
3. Follow the installation instructions in the supplied readme.
If you DO NOT disable native mode for the sata drive, you will end up going around in circles with the XP setup informing you there is no hdd in the laptop, even though you specifically installed sata drivers off the floppy.
Once you get past the "Hit enter to install Windows", you can trash all the partitions on the drive, and recreate one big partition for XP :)
Mar 12, 2008 | HP Pavilion dv6000z Notebook
Seagate harddrive diskread error
go to bios and see there whether it is showing showing your hard disk or not if it is showing then re-install your XP again format your hard disk with the slow formating option,while re-installing it.
Nov 23, 2007 | Asrock GE PRO-M2 Motherboard
Computers & Internet Logo
69 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
