Question about Toshiba Satellite A215-S7437 Notebook
My Toshiba laptop freezes on using my recording device
When ever i try to get in my laptops recording device or run any programs that try to use my laptops recording device my laptop instantly freezes.
  • 3 Answers
Maybe your memory is not enough to run the device. If you memory more is high than 256 MB, please check if you are running too many program that use large memory to run. If the problem persist, it may cause of the device. Maybe it has get damage.
Posted on Feb 17, 2009
I have Toshiba Satellite proA200- EZ2204X lapotp. I have installed skype and Action VoIP on my laptop. But the far end people are not able to hear me weather I use inbuilt or External Microphone. Plz
You have to make sure there are drivers installed for the microphone device you want to use. You can check that in Control Panel, Sound, Recording tab. If you have a microphone installed all the settings you can set for it will be there.
Also, make sure that whatever program you are using is set to use the recording device you want. This is normally set to 'system default', but can also be accompanied by a drop-down list of all recording devices on the system.
You can test all installed recording devices from the Control Panel, Sound, Recording tab to ensure that they do work correctly. If they do work there, but not in the program you are using, then the problem is in the program settings.
Jul 04, 2012 | Computers & Internet
I have a Toshiba L300, when ever i connect the Adapter Chager, the laptop freezes and it give me a blue screen background (not BSOD). The laptop' working fine when it's running on battery powe
It sounds as if you need a new charger. Try removing the battery and start the machine with just the charger. If that works then it may be a new battery you need. Some toshiba notebooks have a 'power saver tool' preinstalled, which is used to monitor battery performance. You can download a copy here:
http://eu.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=EU
Not sure if it will be compatible with your machine, but maybe worth a try as it could be a corrupt program causing the problem.
Mar 29, 2012 | Toshiba Satellite Pro L300-EZ1004X...
I had recording on my Toshiba but can not record anything. I have had the Laptop for a month and bought it at Joyce Mayne in Oz but have lost the recording abillity. Took it back but they (Joyce Mayne were...
Go to Control panel
Click "Sound"
A popup sound utility will come
Click on "Recording" tab
Plug your line in or microphone now
Make sure a green Tick Mark comes.
Select "Properties"
make sure in Device usuage,it display "Use this device enable" and Controller information should display your sound card vendor name.
Click "Listen" tab
and tick "Listen to this device " and Select your soundcard.
Click "Level" and increase the volume.
Check Windows Audio services is started by typing "services.msc" in "Run" prompt.
Use any sound recording software and check if it works.
Hope this will solve your problem.
Jan 01, 2010 | Toshiba Satellite A135-S2276 Notebook
Machine freeze every so often. Checked HD and
Does you machine produce any error messages?
One of the programs you installed is probably causing the freezes.
Try to identify any programs that freeze when you try to run them.
Uninstalling the program should help solve the problem.
You can not rule out viruses though
Dec 30, 2009 | HP Compaq nc6220 Notebook
Microphone Help
Go to your sound properties and make sure it's not muted. Also, the recordind device should be the mic. Then open a recording application and give it a try.
Nov 30, 2009 | Toshiba Satellite PSAG0U-02D00M Notebook
Toshiba Recovery Disc Creator isn't working
hello lazerr_man,
Try to use another freeware burnprogram like burnatonce to create an
other CD, just to check if the Combo-drive is writing properly.
If you don't get any error messages like the ones from Toshiba program, then the problem is the toshiba software.
If other burn programs find difficulties in accessing CDs or DVD-Rs
then the drive itself giving you a hard time and might seek for replacement.
You may find the toshiba exchange parts too expensive and the internal drive is still reading disks properly, then think about an external dvd-rw drive, but make sure to buy a highspeed USB one (or even firewire, if the laptop has the port), else it will run rather slowly.
good luck
Sep 07, 2009 | Computers & Internet
Rotating the volume wheel on my laptop freezes Windows
My toshiba satellite l300-1aq laptop is freezing within a minute of start up? How can I root cause the issue?
Apr 02, 2009 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite A215-S7437 Notebook Logo
43 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
