Panasonic Remote Control
Problem for Panasonic Remote Control
Sky Remote Control problem with Panasonic TXW-28R4 Television
By Pasty - usenet poster
Hi.
I have a fairly recent 28" Panasonic TV, model TXW-28R4 and I can't
program my digibox remote control so that the TV button works
properly. Using the 678 code as recommended in the digibox manual
doesn;t work...after programming it, the Help button carries out the
TV function, lol. Does anyone have the programming code to make my
digibox remote work properly with this TV ?
MeKoN
Same Problem
Aug 16, 2008
-   does anyone know the sky remote control code for Panasonic TX 32LZD80F-   Guest
Best Solution
posted on Mar 10, 2008
Very Helpful)
tat4u
Rank: Wiz
Rating: 83%, 388 votes
if you read the manual carefully(and its easily missed)theres a method to find codes that arent list requires pressing ok until code found cant remember sequence but it is in manual.
you can also find codes via sky box.
press interactive,customer service,program remote(number5)press start and follow instructions.just on it now..
theres txw28r4,txw28r4dpand so on ..
ur number txw28r4 is.....0678..let know how u get on
Was this helpful?
Yes
No
Solution #2
posted on Oct 05, 2008
Not Rated)
gretaro
Rank: Apprentice
Rating: 0%, 0 votes
Press tv button once on your sky remote, then press red and select at the same tine until you see two blinks on the remote, after that you should try 678 and notify if your Sky remote blinks twice again. now you should be able to use the remote as your tv remote.
Was this helpful?
Yes
No
Solution #3
posted on Jan 25, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
The comment by Green1 is correct with the Panasonic
TH-42Px70B
Solution #4
posted on Aug 01, 2007
Not Rated)
Phoebe
Rank: Apprentice
Rating: 0%, 0 votes
You *HAVE* got it working correctly! Unlike most other makes pressing
a numeric key will *NOT* drop Panasonics out of AV mode (even on
the original remote control!). You have discovered that the "Help"
key on the Sky remote acts like the "A/V" button on the original remote
so the key sequence is "TV" then "Help" to return to terrestrial TV
reception.
Was this helpful?
Yes
No
Solution #5
Not Rated)
Ranny
Rank: Apprentice
Rating: 0%, 0 votes
Thanks, but I should have mentioned that I tried 0051 as well.. and a
whole bunch of other numbers that Sky Tech Support gave me on the
phone.. none of which work :)
MeKoN
Was this helpful?
Yes
No
Solution #6
Not Rated)
Green1
Rank: Apprentice
Rating: 0%, 0 votes
This might be a stupid response, but have you tried the 0051 code?
I see it says use the 678 code, but in the code box it also has
Panasonic 0051.
Sorry if of no help.
Ron S
Was this helpful?
Yes
No
Popular Solutions for Panasonic Remote Control
Questions and Unsolved Problems for Panasonic Remote Control
Do you recommend Panasonic Remote Control?
Answer
Answer
I have inherited a Panasonic remote EUR571759. I know it works a SJ400 VCR. What else does it... (More)
Answer
I use a DMR-EX768 hard drive recorder and a DMP-BD35 player, usually at the same time. How can I... (More)
Answer
I have been given the Panasonic digibox and remote but no instructions and i don't think I have... (More)
Answer
my voulom button does not work on my virgin remote needs a 4 didget pin to program to my tv which i... (More)
Answer
I have follow comcast instruction to program to tv but still does not work what should i do. i tried... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Remote Control Experts
Top Audio & Video Equipment Repairmen
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
