Question about Samsung HCL4715W 47" Rear Projection Television
P4 motherboard power pin configuration
I want to know the power pin configuration of p4 motheboard (specialy switch on pin to mother board
  • Samsung Master
  • 5,138 Answers
Order you a schematic online for your TV.Cost $45.00 and some cost as much as $150.00
Posted on Feb 17, 2009
I have mercury mother board and its having nine pinsocket for reset switch,power switch,hd led ,etc but i dont know their proper connections. there are some nos besides but not understandable . can you...
Hi Rajen samani!
Most mercury motherboards with a nine pin front panel connection use the following configuration.
You may want to double check to make sure that your motherboard follows this configuration. Just go to http://www.mercury-pc.com/downloads.php, enter your model number, and you'll be able to download the manual for your board. The jumper configuration should be in a section labeled "Front Panel Connection" or something similar.
Hope that Helps!
Mar 07, 2011 | Mercury Computers & Internet
My mother board is intel 845gvsr,it not coming any display,before days it's working properly.but now it's not working,even bios settings also not showing.some times it's working but only 5 to 10 min only...
just a thought have you checked that its not shorting out on the case? when you installed the motherboard did you put in the spacers?
if you have then i would suspect the psu check that the fan it running when you switch it on
John
Feb 07, 2011 | Intel D845GVSR Motherboard
Dear sir my motherboard not display i will cheack ram, bois,smps
does ur processor fan and smps fan work if both are working then the problem is in the motheboard if both are not working check ur smps by shorting the green pin with black if it doesnt work change ur smps and it works the problem is in ur motherboard ur power supplysection in ur motherboard has been fried take the mother board to a qulified chiplver service personal
Sep 27, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Machine is not booting
  • I know what is your problem?May be problem on your HDD you change it then solve your problem.If you are not fix,You need Fox con MX PK g31 chip mother board.It is very adjustable motherboard for pin less p4 HT processor.
Mar 19, 2010 | Intel D946GZIS Motherboard
I have a pc3500g motherboard and need to know where to plug wires
Dear... Mr.A. Ganesh
From Chennai(India)
pin configurations are printed in the mother board.watch carefully .it may be just few inches away from the front panel connector.
Even u cant find it...
you dont worry about it.You just assemble the
Cpu ,SMPS
then switch on the main .
then short a moment( 1second ) at any two pins which is in the front panel connector ( using tester/sqrew driver);continiously cheak like this one by one pair of pin(Verticaly and Horizontaly).
when you short the corrrect pin,then system on.so you can find it like this.then connect the power button easily.
I am 5 years Experienced Engineer. Mother Board should not get any problem doing like this.
Thank you
Feb 12, 2010 | Computers & Internet
My PC is connected to UPS.Whenever I switch on my UPSthe PC start
On the mother board at the front are 2 rows of pins to which wires are attached, going to switch(power) and the manual reset and the LED's. Usually the first 2 sets of wires--pairs of Green&White and red/black&white are for power and reset. Once u pull out the jumper-like attachments u will be able to see whats written on them. Isolate the power & reset wires. Remove them fron the pins on the motherboard. Switch on ur UPS and by simply shorting 2 pins, starts the PC. Now that u have identified the power pins, put them back after cleaning the dust,etc. If the PC behaves as before but works perfectly when the power switch connections are opened & PC works normally after just touching the 2 oins, then the switch need to be replaced......sodeep
Mar 31, 2009 | Intel D915GLVG Motherboard
HDD and reset light on intel p4 82845 mother board
Hi pc_ski,
Download the manual for your board, click on this PDF link.
http://download.intel.com/support/motherboards/desktop/D845GLLY/ADLY_English.pdf
See page 64 first for the layout of the front panel header. The block you need to refer to is letter C. Here you'll see where pin one is located at.
Go to page 65. Table 32 shows the pin assignments for the front panel header. Pin-1 & pin-2 is for the HDD & pin-7 & pin-8 for reset switch.
Have more questions? Post here.
Good luck pc_ski!
Mike
Mar 22, 2009 | Intel Desktop Board D845GLAD Motherboard
Power and reset switch and hdd led layout on P4Vmm2 mother board
[10][ 9] Pin 1 = +HDD pin 3 = -HDD LED
[ 8][ 7] Pin 2 = + POWER pin 4 = - power LED (SPD)
[ 6][ 5] Pins 5 & 7 = reset
[ 4][ 3] Pins 6 & 8 = Power switch
[ 2][ 1]
Hope you find this Useful
Dave
Nov 19, 2008 | EliteGroup P4VMM2 Motherboard
Motherboard
To download you're manual for the D815EEA2, please click the link below.
ftp://download.intel.com/support/motherboards/desktop/D815EEA2/EA2FV_English.pdf
You need to go to page 85.
7482c11.jpg Starting at Pin 1 (Hard drive LED) is positive + & pin 3 is ground -. Next, Power LED, Pin 2 is + & pin 4 is ground - .
Letter C, is for the reset switch, Pin 5 is + & pin 7 is - .
Power on/off switch, pin 6 is + & pin 8 is - .
The letter I is used for the internal speaker. The positive pin number 16 & ground pin number 10, letter G
Good Luck!
Have more questions? Please feel free to ask.
Mike
Jun 02, 2008 | Intel Desktop Board D815EEA2 Motherboard
P4T-E PSU
your connector is of two part.it has total of 24 pin, can be divided into 20 and 4 pins.connect  20 pin  in your mother board .switch on ur psu and connect 4 pins to another port.
Jan 19, 2008 | Powmax 400 Watt ATX Switching Power Supply...
Samsung HCL4715W 47" Rear Projection Television Logo
81 people viewed this question
Henry  Thomas
Henry Thomas
