Question about Whirlpool GGX9868J Gas Dryer
Dryr starts to crank up than just stops and wont turn on any more
My dryer is about 6 years old it started making a roaring noise when it would start up now it starts to crank up but after about a 4 seconds of tryint to crank on it shuts off and wont turn on anymore , sometimes it turns over and runs o k but if i try to use it again it shut off and wont turn on again
  • 6,784 Answers
Hi there, this is motor failure. the actual motor windings are in bad condition at this moment. they are separating and this can ultimately start an electrical fire. the automatic shut off prevents the fire form occurring. you will have to remove the motor and tanke it to an electrialc motor shop for a re thread.
Posted on Feb 17, 2009
Started then stop and wont come back on. circuit breakers checked, all wiring checked, door closed. light on inside on, could the start stop switch be defective?? dryer is about 10 years old. DRYER...
yes could be start /stop microswitch...firstly make sure fuse ok in plug also feed ok lastly ensure post to operate door switch has not broken off........hope this lot helps.....
Jan 14, 2011 | Dryers
Maytage neptune dryer wont start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Feb 24, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer makes rumbling noise when drum starts and again when
Sounds like a broken spring or a spring mount.
Jan 17, 2010 | Maytag Dryers
We have a kenmore 90 series dryer. Probably 6-8 years old. When you press the start button it makes a humming noise but won't start. Any ideas what it might be?
chance it could be the motor is to weak to turn the drum or it is bound up by the belt or bad rollers check breakers if half tripped this can keep motor from fully engaging
Nov 13, 2009 | Dryers
90 series dryer wont start
first check and see did any clohes fall down in the blower wheel,,from fillter no...check the belt that its not jammed,,check your idler wheel ...always unp[lug unit first.....now we will check motor ,turn unit on if you get a humming for about 10 to 15 seconds than a click,,replace motor
Dec 25, 2008 | Kenmore 63942 Dryer
Roaring Sound During Operation of Dryer
Does the roaring sound occur after the machine warms up? If so, it could be a bad drum bearing. the heat from the dryer causes it to expand in its housing and, since it may been defective, could start "roaring". If so, The dryer drum shaft/bearing assembly will need to be replaced
If however, the roaring is immediate upon start up then u may have a bearing in your dryer motor. The entire motor may have to be replaced.
Dec 07, 2008 | Whirlpool LER4634J Electric Dryer
Frigidaire Chest 5 cu ft Making Fan noise & will not turn on...6 yrs old.
at 6 years old it certainly aint new!
from what you describe, sounds like a compressor fault
Oct 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Dryer drum will not turn
Try pushing start button while turing drum clock wise and see if drum will start spinning, sounds like bad start winding or relay
Sep 17, 2007 | Estate EED4300SQ Dryer
Whirlpool GGX9868J Gas Dryer Logo
105 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
