Question about Sony VAIO VGN-SZ330P/B Notebook
Vgn-sz330p performance mode stuck.
I noticed the other day that my sony vaio was in stamina mode. I switched the switch back to speed mode and nothing happened, i didn't get the little pop up message asking me to restart. I shut down and rebooted anyway and it still started up in stamina mode. Any idea whats causing this. I have read that many are having the same problem, but haven't seen where anyone has figured this out. Thanks in advance.
I'm also running windows XP.
  • 10 more comments
  • wda33 Feb 17, 2009
    The battery is dead and no longer accepting a charge. I have also ran the the vaio recover tool that came with the computer that restores all the settings and files to the way they were when i bought it. Still stuck in the stamina mode.
    nope didin't see anything in there.
    ok so wipe everthing off and start fom scratch?
    k
    make sense
    ok will try that
    k
    alot of good answers.
    will try that first
    nope not a virus
    gonna replace the battery and ac cord, will let ya know how it turns out.
  • wda33 Feb 18, 2009
    hmm thanks for all the advise.
    Genius:
  • 1,226 Answers
Re installation of the system will resolve the issue. However, you begin from scratch again.
Battery and cord can be replace however, you should verify if the either of the two is damage or both. any way you can test by plugging it to the other same laptop model and brand.
anyway this only a suggestion and sometime it will resolve the issue and most of the time it helps.
melnavz
Posted on Feb 18, 2009
  • 121 Answers
You must ask software and electronic expert or go
on the forum.
Posted on Feb 17, 2009
  • 139 Answers
Reset your battery first and then run your laptop on battery to drain your battery completely and check for battery settings in bios
  • 544 Answers
if you try to reboot the unit and still not working you are encountering some hardware problem not a software.
so i prefer to advice you that you need to go and look some technician specialist to open it for you.
we can't just open it specially if we don't have a proper tools to use it.
your unit have a sensitive parts that's why i recommend you to go to a computer shop.
sorry but this is the best solution i can give to you if you want to fix orderly your unit.
hope i gave you a good advice that you will follow.
thanks,
  • 15,935 Answers
I think your switch may be faulty.
To enter-exit stamina mode, you must shut down the PC then switch over.
If it is not doing it, the switch is faulty.
However, if the Laptop does not sense a battery, it will not switch either. So if your battery is "dead" the only way to get it back to speed mode is with a new battery.
Thanks for using FixYa - a FixYa rating is appreciated!!
    Genius:
  • 1,011 Answers
Sir,
I think it may be a virus / malware/ trojan problem. Update the OS and check all the settings
  • 679 Answers
Go Intel website to grab new graphic chips driver. Install the new driver, turn off and turn on your again. upgraded the graphic chips driver, then again turned off and turned on.
Hope this helps.
Thanks
  • 479 Answers
Check with the battery calibration once
first charge the battery fully in shut down mode and then discharge it till system shuts off refix the battery and again charge it in shut down mode till 4 hours.
Checked whether any improvement and also reinstall the energy management software given by sony.
    Genius:
  • 2,035 Answers
This could due the dead battery which preventing the notebook to enter
speed which is running on nvidia drivers which more power ,try to replace
the battery then it may switch to power mode or install the drivers for
Nvidia graphics :Please use this link to download the drivers and install it on your notebook
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNSZ330P&upd_id=2294&os_id=7#
Good luck...
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
The battery being dead is a contributing factor as to why the Vaio is running in Stamina Mode. This mode is specifically designed to/for lesser power consumption by running slower and using the built-in Intel graphics rather than nVidia 7400 when the BIOS senses that the battery is weak and/or fully dead.
While this problem is rather common, the only possible corrective solution would be to:
  • replace the battery and reset CMOS/BIOS to default;
  • flash the BIOS if an updated version is available from the Sony support site;
  • in some instances, it is the AC power/charger that may have issues. The voltage output is not as regulated/consistent as expected. This is especially so when the WiFi is active.
Good luck and thank you for using FixYa.
  • 10,594 Answers
Please check power adapter of Vaio as it seems not supplying power to laptop to charge battery so Vaio shifted to Stamina mode.
  • Shahid Electronics
    Shahid Electronics Feb 17, 2009
    If you do not confirm power adapter of Vaio problem wont be fixed.
  • 126 Answers
The only thing you can do is reinstall windows
if you dont know how to do it
go here and learn step by step instructions for it
thankyou for using fixya and dont forget to rate the solution bye
  • vishal garg
    vishal garg Feb 19, 2009
    ey buddy,
    you are wasting your time here. You will find nothing here if it was that you can find
    answer here till now should have got the answer
    go to the repairing shop with bills and documents of laptops and get it repaired
    stop wasting time
    stop wasting time buddy
    regards
    Master:
  • 848 Answers
Check settings in safe mode ..... in run type msconfig and see the settings.....
  • Sony Master
  • 19,396 Answers
Remove laptop battery or do system restore to reset the laptop.
  • Ginko
    Ginko Feb 17, 2009
    Try first remnoving the laptop battery and leaving power cord unplugged for two minutes. This will drain power from laptop and reset it.
    If that does nto work, do a system restore to a date before you had the trouble.
    If still no luck, go to bios and use the command 'reset to default settings' in bios panel.
  • Ginko
    Ginko Feb 17, 2009
    Even if the battery is dead you need to remove that to rdo an hard reset.
    If you used the recovery tool you do not need system restore.
    Try resetting the bios.
    If all this does not work, the stamina mode is controlled by bios, you can try a bios update, if not even that works then the motherboard is faulty.
Stamina/Speed Switch In Windows 7
Page 104 of the manual says you must reboot between switch changes to install the change.
The manual is here
https://docs.sony.com/release/VGNSZ400_UG_US_F.pdf
Nov 28, 2012 | Sony VAIO VGN-SZ440 Notebook
My sony vaio vgn sz440 is not changing from stamina to speed
Hello try to download the driver from here:
http://esupport.sony.com/US/p/model-home.pl?mdl=VGNSZ440&template_id=1&region_id=1&tab=download#/downloadTab
Here is only drivers for windows vista.
But sometimes it work on windows 7
Aslong it`s a 32 bit system.
Here is no driver for the 64 bit system.
The new nvidia graphic driver is here:
http://www.nvidia.com/object/geforce_notebook_winvista_win7_179.48_beta.html
Good luck
I have another problem with my laptop, I think its about the video card, I had to slide my switch to Stamina, so it would stop making lines on the screen, what do you think could be the problem?
Hi:
Your laptop has 2 seperate video processors. The performance processor and the onboard processor. The stamina video runs from the onboard processor, and the performance video is a seperate card. If you only get lines when running off the performance mode, then most likely that video processor card has issues. It can be replaced, but it isn't cheap!
You can hunt around on ebay for one, but don't faint from sticker shock!
Sep 21, 2010 | Sony VAIO VGN-SZ330P/B Notebook
My problem with my Sony VGN-SZ330P is the fan, it producing some loud noises, sounds like its grinding something
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
Sony Vaio STAMINA/SPEED switch not working correctly
What OS are you running? Have you tried to upgrade drivers of you machine? Also you should try any firmware upgrade before you use the warranty.
Aug 31, 2009 | Sony VAIO VGN-SZ480 Notebook
After Vista Service Pack 2 Install and re-start. My NVIDIA everyt
If you download "driver max" this will find all system hardware, check all driver versions, download the the latest version, or if you want to pick a known good one you can. It looks like, as you have so many OS on your pc. that there may be some conflicts there. But driver max should sort this. Oh and it's free so no worries there.
Jun 05, 2009 | Sony VAIO VGN-SZ430N/B Notebook
Sony vaio stuck in presentation mode
Right click on your desktop, go to display and change your resolution to one that is more pleasing.
Mar 24, 2009 | Sony VAIO VGN-FE770G Notebook
VGN-SZ330P laptop stays on opening VAIO screen after two beeps
Just hold down the F1 key after the two beeps and the computer should continue to boot up as normal
Dec 19, 2008 | Sony VAIO VGN-SZ330P/B Notebook
Stamina/speed switch
This IS very likely a hardware problem. I'm not very sure about your model but I know that many SZ users w/ G84xx/G86xx NVIDIA card out there are having similar problem -- could be due to NVIDIA chip failure.
http://www.theinquirer.net/gb/inquirer/news/2008/07/09/nvidia-g84-g86-bad
Sony had just acknowledged this problem (failed G84/G86 NVIDIA chips) recently but unfortunately SZ series models were not included in the list.
http://www.theinquirer.net/inquirer/news/1528907/sony-admits-failing-nvidia-chips-months-late
In case you're using SZ model and are having G84/G86 nvidia card, just give sony service center a call, at least to let them take your issue into their record.
Oct 01, 2008 | Sony VAIO VGN-SZ480 Notebook
Sony VAIO VGN-SZ330P/B Notebook Logo
157 people viewed this question
Top Sony Computers & Internet Experts
Brian Sullivan
Brian Sullivan
laikexpert
laikexpert
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
