Question about Sanyo PLV-Z2 Multimedia Projector
Projector problem sanyo pvl-z2 wont shut down all the time lamp wont shut down
  • 21 Answers
I had this happen too. Occasionally, you will press the power button, but it won't shut down, everything else seems to work. I was forced to unplug it a few times which is a bad deal. I finally traced it to some kind of strange power loop from my DVD player. If you have multiple sources, I'd try it for a while without them (one at a time) and see if you can isolate it, or better yet, if you have a way to swap them all out temporarily and add them back 1 at a time, you may be able to isolate it. It didn't seem to help to unplug or disconnect the DVD player before powering off the projector. It had to have never been connected. Took me quite a while to figure it out. It's pretty obscure, hope it helps.
Posted on Mar 11, 2010
Sanyo PLv - Z2 projector flashes multiple times on start up and then shuts down
Clean the unit, it maybe clogged with dust inside and the air can't get to the lamp.
Oct 16, 2014 | Office Equipment & Supplies
Sanyo PLV-Z2 flashing then off
1,the fans is good , is ok
there is not an overheating situation ,only 5-10 minutes,
2,seems that the lamp ballast is defective
you need a new lamp ballast, unit price is USD80
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Feb 16, 2014 | Sanyo PLV-Z2 Multimedia Projector
I have a Sanyo PLC-EX20 projector which shuts down after five minutes, what could cause this?
There are 2 possible causes.
The first may be due to overheating. Most projectors have a "air filter" that can be removed and cleaned. If it gets clogged with dust over time, the projector can't breathe and shuts down.
The second cause may be your lamps life hour clock. Most projectors keep track of the amount of time that their bulbs have been active. Once a preset # of hours has passed the projector will limit functionality until a new bulb has been installed AND the lamp life clock reset. Most projectors do not automatically reset the lamp life clock after a new bulb is inserted.
There should be instructions on how to reset the lamp clock in your users manual, and info on cleaning the air filter. Unfortunately I went to the Sanyo website and was unsuccessful in locating a PDF of the user manual for you.
Mar 04, 2011 | Sanyo PLC-XE20 (Chassis XE2000)...
What is the lamp life on a sanyo plv-z2 bulb and how to read the bulb life there are 3 numbers that come up when i check it
If I remember correctly, you hold down either the power or the menu button for 30 seconds... I believe it is the power button, and it will briefly display it on the screen, but this assumes it was reset at the time the lamp was installed. The counter counts up on this model, and the lamp replace light will come on at 3000 hours. I have 2 of these units, and I have gotten at least 5000 hours out of each lamp. Toward the end of the lamp life, it may start getting dim and/or have difficulty starting, but I probably wouldn't replace it until you either notice the dimming or the lamp fails, although I've heard some say they can damage the projector when they fail, I have not had any problems.
Dec 03, 2009 | Sanyo PLV-Z2 Multimedia Projector
PLV-Z2 Won't come on.
Hi There,
Yup you definatly have a temp sensor issue. But dont worry, Its not a major issue. Ive had a plv-z3, and a plc-sw35,And both projectors gave me a temp sensor issue at one time or another. Its just a sanyo thing...
Heres what happend.. The ambient temp inside the projector shouldnt reach more than 100 degrees celcius, when it does the temp sensor (which looks like a small black pot, with a shaft, and a ceramic white tip) Opens up, and cuts off the high voltage supply to the projector, A fail safe to prevent any major damage. What essentially should happen is, that once the projector has cooled, the temp sensor should return to normal possition, and allow normal operation... BUT... sometimes it doesnt. And until you manually push the shft back down, You projector wont work again.
What you need to do, Is take off the top cover, Locate the sensor (its normally mounted next to, or on the lamp housing) And push on the white tip with a pen or small screwdriver to close the circut again.
Here it a full service manual for a plv-z3, which is almost identical to your unit.http://yama.co.za/forum/index.php?topic=147.0
Hope Ive helped in some way. :)
good luck
May 16, 2009 | Sanyo PLV-Z2 Multimedia Projector
New Sanyo PLV-Z2 not bright
is this original lamp or refurbished one or compatible some thing.
how was performance of previous lamp when you pull out it? if it is still working for few minutes, you can confirm projector by reinstalling it.
Sep 04, 2008 | Sanyo PLV-Z2 Multimedia Projector
Starts up but turns onto standby straight away
There could be a problem with the flip down iris protector. If the Sanyo is on and you flip the protector down manually then the projector will go into standby mode. This is obviously to protect the system incase it ever gets flipped down accidently and the system is on. There could be a faulty switcher inside the protector mechanism which is not working properly and the machine thinks that the screen is down when in fact it is open!
Switch off the entire projector at the mains and open and close the screen a few time manually. If you feel comfortable doing so try and force the screen up a little bit past its stopping point when it is supposed to be fully open. Be careful and don't break it. Now keeping it open plug it back in a see if that works and don't touch the protector ever again! If it doesn't try opening and closing a few more times to try and release the triggering button that is inside the projector screen.
I had the same problem and that worked for me.
Sep 27, 2007 | Sanyo PLV-Z2 Multimedia Projector
Sanyo PLV-Z2 Multimedia Projector Logo
258 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
