Question about Kenmore 24 in. 15142 Built-in Dishwasher
Kenmore Elite Dishwasher clean light ind flashing and won't start
Kenmore Elite Dishwasher model 665.16262402 has the clean light indicator flashing and it won't let me start a new load. Normally the light is on steady when a load is clean. Once the door is opened and shut again, the light normally goes out. It now flashes 7 times, pauses for a few seconds and then starts the 7 flash cycle again. I've tried pressing every button to cancel it out. I've shut off the power for about 10 minutes hoping any stray trons would go away. I did all what you ar saying and it still flashes 7 times and does the initial check for 2 to 3 minutes then it stops. When I succeed to get it started, then it starts at 60 minutes rather than 86 minutes and it gets down to 39 to 40 minutes and then it stops. We have change the water probe for the temperature and the heater is good, so.... can some help me, even the kenmore repair man could not fix it for me.
  • 1 more comment
  • Anonymous May 03, 2009
    I am so impressed. I thought I would have to spend $500+ dollars on a new dishwasher. But, I followed your solution/ directions and you fixed my dishwasher!! Oh, wow, you made my day, week,month,year. Yayyyyy!
  • tiberall May 07, 2009
    i have tried this, and many other combinations of buttons with my elite quiet guard, and nothing seems to reset it. the smart wash button keeps flashing.
  • sandy Dec 28, 2011
    Worked like a charm! Thanks!!
  • 188 Answers
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Posted on Feb 20, 2009
  • 8 more comments
  • hayshoe4 Sep 02, 2010
    thank u so much!!!! we definitely could not afford a repair man right now!!!! i have a dishwasher again!!!!!!!
  • peterrifazio Sep 15, 2010
    Wow this is great. My dishwasher started again and just completed. Let's hope it stays that way. The Manual says to call a technician. I am glad I found this on line first. Thanks so much!!!!
  • Steve Roberts
    Steve Roberts Oct 11, 2010
    I was goin nuts, those dishes don't wash themselves! haha Awesome and easy fix! Thank you...
  • dietcoke13 Feb 10, 2011
    Thank you, thank you. I called the service department today and they were going to charge me a minimum of $125 to come and diagnose the problem. They had no one to answer questions on the phone. Your solution was not only easy, but it worked. Thanks again.
  • ifatrb Apr 03, 2011
    Cannot believe it, but it actually worked! Thank you soooo much!!!
  • tallchristo Jan 25, 2012
    This quick diagnostic self check is well worth doing before calling the service tech out, @ $100. To start. Great tip.
  • Michael Jul 13, 2012
    Thank you very much. Worked like a miracle.
  • triciabasi
    triciabasi Jul 16, 2012
    thank you thank you thank you!! arg... i dont have a user manual so this was great. Can anyone send me a link to download the user manual. I have a kenmore ultras wash quietguard standard
  • Patrice Keryk Johnson
    Patrice Keryk Johnson Dec 24, 2012
    Oh my goodness! I was already shopping for anew dishwasher when I decided to google the problem and see if there was a fix! AND ITS FIXEDDDDDDDD! THANK YOU SO MUCH!!!!!!
  • Mark Monschein
    Mark Monschein Feb 26, 2013
    I have done this to mine also but have to do it everytime. I also found out that you have to run the hot water in your sink at least 120 f before you start wash.
Thanks a lot
thank u
It was so easy
yeeeeeees
Posted on Feb 13, 2010
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
Clean light keeps blinking; dishwaher won't turn on
Hello Brian, welcome to FixYa.
Based on your post I understand your dishwasher is a Kenmore and the clean light is flashing and it won't start, correct ?
If so, this is usually an error code indicating there was a problem in the heating process the last cycle it ran, however if you could provide the complete model number I could speak specifically to whether it applies to your machine and potentially what to do about it.
Thank you for choosing FixYa and I look forward to your reply.
Regards,
Macmarkus :)
Oct 12, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Clean cycle light is flashing
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 22, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Clean light flashing
This is a communication error between the control and motor. Try resetting the control by pressing the following keys with in 5 seconds.
HEATED DRY, NORMAL, HEATED DRY, NORMAL
after about 15 seconds hit cancel then the control should be unlocked. If the problem comes back the problem is most likely with the motor for the pump. Check with your warranty, some of these Kenmore models may be under warranty
May 08, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
K-more elite dishwasher stuck in sensing mode; won't move to wash
Where did you find the sequence to clear the flashing clean light?
Apr 14, 2009 | Kenmore Dishwashers
KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Feb 22, 2009 | Kenmore Dishwashers
That means the control sensed that the heater in the d/w did not operate 3 times in a row. so the unit locks out. First remove the kick plate and you may have to pull the unit out from under the cab, but check your heater. use a meter to see if it reads open, if so order a heater assy it will come with a new control replace it to. If your heater checks good press in sequence normal wash , heat dry ,normal wash,heat dry , normal wash , heat dry three times within 6 sec all the lights will come on then hit cancel. What that did is reset the control and clear that fault. Keep in mind that d/w does not heat it's own water your incoming water temp should be 120. the d/w will maintain that temp. when starting your d/w first turn on your hot water till it gets hot then start your d/w this insures your unit fills with hot water and not cold
Jan 09, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
Kenmore 24 in. 15142 Built-in Dishwasher Logo
3,809 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
