Question about HEALTHRIDER S600 Treadmill Motor Control Board : 152004
Healthrider r60 stopped working
I was running on the treadmill and heard a pop sound. My breaker was popped and I reset the breaker on my panel and tried to reset the breaker
on the treadmill, but still not working (motor and belt)I have all the lights on the panel and the incline motor works. However; the motor and belt won't turn. How can I check the motor?? or is it the board??
5 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: healthrider r60 stops when it reaches 4mph.
Unplug unit and remove the motor shroud you will have to do DC Amp Measurement.
Measure on the hot DC lead (usually red) going from the controller to the drive motor. If you have a simple multi-meter with a DC amp test setting the best way to test is to put the meter inline on the red motor lead with alligator clips. If you have a more expensive clamp meter, clamp the meter around the red motor wire. Run the machine at 2.5 MPH without a person on the belt. If the motor and drive system are healthy, you should have a reading in the 2-3 amp range. Then walk on the treadmill at the same speed. With a person of average size (around 200 lbs.) you should have a reading in the 6-8 amp range if the belt is good. The readings will fluctuate more with a load but you are looking for an average reading but you shouldn't see spikes above 10 amps. If the amp readings are high without a load, you could have a problem with high resistance in the motor, a bad bearing, or over-tightened belts. Regular readings without a load but high readings with a load indicate a worn belt and/or deck.
Posted on Jun 28, 2010
  • 48 Answers
SOURCE: My Healthrider R65 was in a flood. The treadmill
motor does not start as flood rusted contacts and brush commutators
open it and clean it
Posted on Nov 23, 2010
ercupa190
  • 12223 Answers
SOURCE: my healthrider s300i softstrider treadmill
1)See if flexible cable from display board is bending to lower board.
2)main motor board is faulty by worn deck belt.
3) burn motor faulty.
4) adjust the Potentionmeter from the motor (incline).
5)Defective gear in inclination motor.
Posted on Dec 13, 2011
ercupa190
  • 12223 Answers
SOURCE: The incline on my HEALTHRIDER
1) tight the flexible cord from keypanel vs display board
2)tight the display board vs lower board(main motor board)
3)Test the main motor board(faulty to worn deck belt)
4)INCLINATION motor burn.
5)Adjust Pot from the inclination motor
6) the gear slip adjust or repair.
see the block diagram
I have a Freemotion XTR90 treadmill that stops / resets after 5 min of use.
see the video attached, Lube the rollers bearing too Front+back. However you must test the main motor, measure the input voltage terminal at motor, if there ARE AND THE motor NOT run the motor is faulty. 2) test the output voltage terminal control board, for input voltage motor, if there ARE NOT the board is faulty. see the diagram attached.
Nov 26, 2013 | HEALTHRIDER R60 SoftStrider Treadmill
Stops after 2-5 minutes
Usually this means 1 of 3 things.
Motor problem or
Motor control board
lume
Aug 16, 2013 | HEALTHRIDER R60 SoftStrider Treadmill
How do you check actual mileage on a Healthrider r60 treadmill?
I dont believe it is possible. Not many brands worldwide give you this option.
Jan 02, 2013 | HEALTHRIDER R60 SoftStrider Treadmill
I have a 300I health rider. I have recently had issues with the safety breaker popping on the front of the treadmill. In talking with the Healthrider people they recommended. 1. Replacing Motor 2. ...
DEAR IF YOUR TREADMILL IS OLD AND YOUR WEIGHT IS MORE THAN 80 YOUR MOTOR TREADMILL IS WEAK NOW AND MUST BE REPLACE IT ONLY .
you can countiue contact us with smart phone on wattsapp or telegram by :
+989195116738
Mar 31, 2017 | HEALTHRIDER S300i Treadmill Motor Control...
Healthrider r60 stops when it reaches 4mph.
Jun 28, 2010 | HEALTHRIDER R60 SoftStrider Treadmill
HEALTHRIDER S600 Treadmill Motor Control Board : 152004 Logo
177 people viewed this question
Top HEALTHRIDER Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Shehu Pro
Shehu Pro
mburke3
Are you a HEALTHRIDER Exercise and Fitnes Expert? Answer questions, earn points and help others
