Question about RCA P52937 52" Rear Projection Television
My RCA Rear Projection wont change from channel 3.
I know im supposed to go into the Menu setup Guide Plus but when it says Press ok to start set up i do this and nohing happens. The tv doesnt freeze but it just wont go anywhere or start the set up process. Any ideas?
  • 1 more comment
  • nickge36 Feb 17, 2009
    Thanks,
    I did this but the TV is stuck on channel 3. It says its changing channels but its channel #3. I read about someone else who had this problem and the solution was to reset Guide Plus. So Im stuck on what to do.
  • nickge36 Feb 18, 2009
    Thank you for all your help but somehow my mom came up with the wrong Model number. The model number for our tv is P60920BL. I hope this doesnt affect any solutions you have for me. On our TV there is no Factory setting or empty cap. I did unplug it and let it be and still the same problem it wont allow me to start Guide Plus+ setup. If you have any more ideas please let me know. If not thank you for your time and effort.
    Thanks
    Also, do you know if there is any way to remove the Guide Plus+ system that would help with the problem?
    Thanks
  • 75 Answers
Use the remote that came with it when you bought it and go into channel menu and rescan your tv channels
Posted on Feb 17, 2009
  • Stan Moffett Feb 17, 2009
    look through the menu and find a master reset that say factory or something like that and perform that reset and let me know if that fixes it
  • Stan Moffett Feb 18, 2009
    have you uplugged the tv for 5 to 10 minutes while unpluged push the power button and empty cap. and then plug it bck up
    some rear pojection tvs hav a reset button on the back to where you will need a small item to push it with
RCA Projection P52937SG Continually changes channels and wont respond to controller
This is an older set but I have two questions:
Is the set actually changing channels up or down or are the number for the channel doing that while set remains on same channel?
Two possible problems, some of these also had the Guide Plus Logo on the front of the set.
If I know which issue you have I can help.
SD TECH
Oct 25, 2011 | RCA P52937 52" Rear Projection Television
Where is the auto convergence button
Hello
From it menu option, suf through and come to automatic convergence display option and press Ok button on the remote control.
The List & Labels part of the setup lets you edit your channel list and choose or create a
personal six-character label for each channel.
Note: Changing List and Labels can be time consuming. You can change these at a later time by accessing the
Setup menu.
1. Press the left or right arrow to scroll through the available channels and choose the
channel you want to edit.
2. Press the down arrow to highlight the In channel list option. Press the left or right arrow
button to add (the box is checked) or remove (the box is unchecked) the channel from the
list.
3. Press the down arrow to highlight the Channel label option. Press the left or right arrow
button to scroll through the available list of 25 most common labels. The last option in
the list allows you to create your own six-character label for the channel (the first letter of
the label is highlighted).
4. Press the 1 or 2 number button to change the first letter of the label.
5. Press the right arrow to highlight the second letter, then press the 1 or 2 number button
to change the second letter, etc...
6. When you are finished creating your label, press OK. For model D34W20, your TV tunes to
the last channel available in your channel list. For models D40W20 and D52W20 only, the
Auto Convergence menu appears next.
Auto Convergence (for models D40W20 and D52W20 only)
Your TV's picture tubes might have been disturbed during delivery or after you moved the TV,
causing the color in your TV to be out of alignment. The colors adjust by starting auto
convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu appears. The
cross in the middle of the screen should be yellow. If it is not, use the arrow buttons to
move the red cross to overlap the green cross. Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle of the screen. If
it is not, use the arrow buttons to move the blue cross to overlap the green cross. Press OK
(the TV tunes to the last available channel in the channel list).
Ok
Mar 16, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Black and white tv
Hello
Your RCA, system setup has changed I thinks.To change this you have to go to the Menu option surf for system settings, and change the system reception to "AUTO".
Setup
The Setup menu allows you to access the GUIDE Plus+ system setup information. To access the
Setup option:
1. If the GUIDE Plus+ system isn't on your screen, press GUIDE on your remote control.
2. Press MENU to select the Menu Bar.
3. Use the right arrow to highlight the Setup menu selection.
4. Use the up and down arrows to select Change system settings, Review options, or
View demo.
Change system settings Confirms the settings you completed in the GUIDE Plus+
system setup are correct.
Review options Displays the GUIDE Plus+ system auto display options.
On Automatically displays the GUIDE Plus+ system when you press the ON•OFF
Off Disables the GUIDE Plus+ system from being displayed when you press the
ON•OFF button on the remote control.
View demo Runs the GUIDE Plus+ system demonstration
Note: If you have not completed your GUIDE Plus+ system setup, these options will not be available. A
screen will prompt you to complete your setup.
Getting In & Out of the GUIDE Plus+ System
To enter the GUIDE Plus+ system:
• Press GUIDE on the remote.
• Press and hold MENU for 2 seconds on the front panel.
To exit the GUIDE Plus+ system:
• Highlight a program and press OK to exit the GUIDE Plus+ system and tune
to the channel.
• Press GUIDE to exit the GUIDE Plus+ system and tune to the channel
displayed in the video window.
• Press CLEAR to exit the GUIDE Plus+ system and return to the original
channel
OK.
Dec 04, 2010 | RCA 32V420T 32" TV
Channel wont change. the numbers change but the picture remains the same. always on channel 3. help
Look to see if "GUIDE PLUS" logo is on front of set, if so it is your problem.
Go into customer menu and setup for Guide Plus and enter area code 99999 and when it asks if you have cable box or vcr answer/select NO, the guide plus is your problem.
Try and if this resolved your problem rate this solution as VERY HELPFUL as I do this here for free.
SD TECH
Sep 21, 2010 | RCA P52926 52" Rear Projection Television
Rca hdtv channel changed by mistake
RCA channel setup and selection is not easy to understand. You may try to add channel 3 on the add/remove channel section. If that doesn't work try pressing the input button. Good Luck.
Feb 28, 2010 | RCA HD52W56 52" Rear Projection HDTV
RCA F13137--Have direct connection from cable (basic only) to TV. Autoprogram only finds 16 channels. Same set up with another TV in same jack finds 75 channels.
Make sure to check in the guide plus setup for the question "Do you have cable?" and answer it yes. Be sure that you answer the question "Do you have a cable box?" NO. It sounds like it is in antenna mode. Thanks
Oct 17, 2009 | RCA P61939 61" Rear Projection Television
Using RCA P61939 without Guide Plus
Guide plus still works even if you don't have the wand hooked up. In the setup section of the guide plus there are several questions that must be answered properly or it won't function as you would like. It maybe labeled as options as well. Thanks
Oct 02, 2009 | RCA P61939 61" Rear Projection Television
I WENT TO CHANNEL GUIDE AND NOW I CANT GET ANY CHANNEL ON THE TV
when you went to guide, you cleared your auto programming menu. Go back to setup and reprogram the set
Sep 05, 2009 | RCA HD52W56 52" Rear Projection HDTV
Rca guide plus gold 32'
pull the ac plug for about 5 min and start your set up again paying atention to the features you want and don;t.set the menu to suite your requirements.
Jan 16, 2008 | RCA 32F531T 32" TV
RCA TV won't change channels
Your set uses the 195 series chassis and you have something set wrong in your guide plus. Go into the TV's menu and do a complete set-up. Take the remote and press MENU, then "8" to enter setup, then press "1" for "begin setup now" and then press "1" for English, and so on. You must enter "set up guide plus+", then press OK on the remote to choose "setup", select "USA", enter your zip code, and then if you choose "yes" for "do you have cable?" you MUST then choose "no" for "do you have a cable box" If you choose "yes" for that choice, your tuner will lock on one channel no matter what channel you try entering. After choosing "no" for "do you have a cable box", choose "no" for "do you have a VCR?", exit the guide plus menu and then skip the rest of the steps by pressing "2", and then exit the main menu by pressing "0". Your channels will then work normally.
Aug 29, 2007 | RCA P52937 52" Rear Projection Television
RCA P52937 52" Rear Projection Television Logo
130 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
