Question about Texas Instruments TI-89 Calculator
The calculator shows busy symbol all the time
I wanted to run the app called tankers but it says it busy straight for 4 days. You can click any key key but nothing happens
  • Texas Instru... Master
  • 7,993 Answers
The calculator is clearly suffering. Maybe not enough memory or too many calculations, or batteries weak. Remove the main batteries, not the backup and restart. Once in a while clean the RAM.
Hope it helps.
Posted on Sep 13, 2009
Multiviewer texas instruments
There is no button for the theta symbol only a common key for variables x,y,z, a,b. It is customary to use the symbol theta to represent an angle, but people may use any symbol they want because the variables are called DUMMY variables.
So if you have some calculation that involves a dummy variable called theta you can use any of the variables available on the calculator to represent it.
Sep 15, 2013 | Texas Instruments ti-30xs multiview...
How do I get my casio fx300es plus to give me square root answers instead of decimal?
To calculate the square root use the square root key, three rows above the "8" key.
If you want to see the result symbolically, press SHIFT MODE 1 to select the MthIO mode. Bear in mind that the calculator can only show some results symbolically.
May 02, 2013 | Casio fx-300ES Calculator
Find theta on TI-30XS MultiView calculator... I can't :(
No, your calculator does not know a variable called theta. But what is theta but a symbol to represent a variable. Usually it is used to represent an angle in polar coordinates. It is just the usage and it is not really essential. You can do conversion from polar to rectangular coordinates and from rectangular to polar coordinates but it does not matter what the angle variable is called.
Go ahead, do all the calculations you want that involve an angle. If the calculator can perform them , they will be evaluated correctly and the name you give the angle value (alpha, beta, theta, iota...) is immaterial.
Apr 26, 2012 | Texas Instruments ti-30xs multiview...
If i press 0.5*0.9524=476.2m and i want it to give me the result of 0.4762
You have turned the Engineering display mode ON. In that mode, the power of 10 that are displayed are multiples of 3. In your case the m stands for milli or (1 thousandth).
To exit the engineering ON mode, press the Mode button, several times (4) until you see EngON, EngOff. Press the corresponding digit key to turn off the Engineering display mode.
Mar 19, 2012 | Casio FX570MS Scientific Calculator
I want to put an angle into degrees and minutes what do i press on the graphics calculator
Here it is
To access the DMS symbols
  1. Turn calculator ON
  2. If you see no icon menus, press the [MENU] key.
  3. Use the arrows to put focus on RUN icon or RUN/MAT for the newer versions, and press [EXE]
  4. Press the [OPTN] key to display tabs in the lower part of the screen.
  5. Use the F6 key to cycle through all the tabs.
  6. Locate the one marked [ANGL] and press the key below it (may be F5).moz-screenshot.png
Here are two screen captures to show you the contents of screen
Oct 24, 2010 | Casio FX-9860G Graphic Calculator
How do you do y equals 2x to the 4th?
Do you want to graph the function? y= (2X)^4 or y= 2*X^4.
If you want to graph it
  1. Open the [Y=] equation editor.
  2. On first line where it says Y1=, type the function using the [X,T,theta, n] key to enter the X symbol (the key is under the [MODE] key and above the [Apps] key.
  3. Press the [GRAPH] key on the top right corner of the keypad.
If you want to do something else, you will have to be more specific, because DO is not precise enough.
Feb 21, 2010 | Texas Instruments TI-84 Plus Silver...
How do you put degrees mins & secs in a ti 84 plus
The DMS symbols are available under the ANGLE menu
Press [2nd][APPS] (ANGLE)
Under that menu you find the degree and minute symbol. To enter the seconds unit you use the key sequence [ALPHA][+] (")
To enter 1deg 15 minutes and 37 seconds
1 [2nd][APPS] [1:deg] 15[2nd][Apps][2:'] 37 [ALPHA] [+]
To enter a number in decimal degrees (eg 15.37)
  1. If angle unit is the degree just enter 15.37
  2. If angle unit is the radian , you must specify the angle unit as degrees: To enter 15.37 degrees you type 15.37 [2nd][Apps][1: degree] [ENTER].
To convert from DMS to DD and from DD to DMS, you use the sequence [2nd][Apps][4:|=>DMS].
Feb 08, 2010 | Texas Instruments TI-84 Plus Calculator
We are graphing more than one line at a time. One
To return your calculator's graphing equation to "Y=", press "MODE" from the home screen, then ensure that the option on the fourth row is set to "Func". Next, to show a hidden graph, access the Y= list, then press the left arrow key until the cursor is over the "=". Press "ENTER" to toggle visibility of that line.
Nov 13, 2009 | Texas Instruments TI-84 Plus Calculator
The Ti-89 titanium shows busy symbol all the time
It's frozen. Hold (at the same time) [←] [→] [2nd] then hit [on]. It clears RAM.
Feb 17, 2009 | Texas Instruments TI-89 Calculator
Ho w to set the date and time
Go to the link below. You need adobe acrobat to read. THere is a section in the manual called "Adjust Date & Time"
For Date:
Put Calculator on RATE SET
Press Time/date key: enter the date using a decimal between the month, day and year (all 4 digits) please the date/time button. It should reset. (Exmple: 01.16.2009)
For time:
Leave Calculator on RATE SET
Press Time/Date key until time shows up. just like date, press the hour then the decimal then the minute. (Example if the time is 10:15 you enter 10 . 15) Press the Time/Date Key and the time is set.
This link is the manual:
Jun 04, 2008 | Sharp EL-1750PIII Calculator
Texas Instruments TI-89 Calculator Logo
170 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
