Question about GE Profile Advantium SCB2001KSS Stainless Steel Electric Single Oven
Need to replace halogen bulb that illuminates Advantium interior
I found a description of how to replace the bulb on an Advantium, but it's not the same model as mine. The instructions I found were for an under-the-cabinet advantium that has exterior screws that allow you to remove the grill to get to the lightbulb. Mine is a built-in unit (model SCB1001KSS) that has no apparant way to remove the control panel to get to where I believe the bulb sits. I imagine you need to pull the unit out, but that won't be too easy. I'd appreciate any help.
  • Anonymous Mar 01, 2009
    I have same problem....GE Owner's Manual is NO HELP which makes no sense because one would assume that the light bulb will be the first thing to fail (Seems like GE would know this since they make light bulbs)
    President:
  • 1,273 Answers
Mine is installed also, and I've had to replace the bulb twice. I wised up the second time and installed an access hole where I can pull my microwave out about 6" and access the bulb. I use a 35 watt 120v halogen bulb, with a GY 8.6 base, Lowe's part number 15797. If your's is different, the specs will be stamped on the metal beside the reflector when you remove the sheetmetal. You have to remove the microwave completely from the cabinet and remove the sheetmetal case that surrounds the entire unit. You can then access the lamp socket by looking in from the top. The first time, I took out the reflector with the socket. The bulb can be replaced by removing the two small screws adjacent to the socket on top of the reflector. My access port is a hole cut into the top. I cover the hole with a piece of sheetmetal and two sheetmetal screws. Seems to work just fine. If you do decide to cut a hole, do so with the metal enclosure off and away from the microwave to avoid getting any metal shavings into the machine!
Regards! --W/D--
Posted on Jul 17, 2009
Advantium--removing lower halogen cover
you need a torx/star screwdriver
Dec 31, 2013 | GE Ovens
Replace light in KEMC378KSS microwave
The oven lights are 12-volt, 5-watt maximum halogen bulbs. They
will come on when the oven door is opened. On double oven
models, both upper and lower lights will come on when either
door is opened. The oven lights will not work during the Self-
Cleaning cycle. When the oven door is closed, press OVEN
LIGHT to turn them on or off.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
Feb 04, 2013 | KitchenAid KEMC378KSS Electric Double Oven
My GE oven isn't lighting but the electrics work...What should I do? Please help
Bulb required: Manufactured by Aglaia for GE, 130V 35W Halogen bulb
There is a grille above the door and clock/cooking controls that extends the width of the unit. You need to remove this to get to the light receptacle. With the power to the unit off (unplug if you have access to it), get on a chair with a Phillips head screwdriver. Look down from the top and you will see two screws about 6" in from the ends. If you don't see the screws, open the cabinet doors above the unit (mine were blocking the screw heads). Remove the screws and set aside. Pull girlle towards you at the top being careful not to break the tabs at the position where the screws you just removed are located. After the tabs are out the grille should lift up (there are three hook-tabs along the bottom). Set it aside. Over toward the right you will see a smaller vertical grille. Just to the left of this there is a void with a Phillips head screw facing you. Remove the screw from the receptacle tab. Lift up the receptacle tab on the right. When the receptacle is clear on the right, move the receptacle to the right to release it from the tabs on the left. Lift the receptacle up until it clears the housing it just came from. Pull it gently toward you, rotate it bottom-toward you, and you will see the bulb to be replaced. My bulb was lightly held in using white silicone and removed easily by pulling it in the direction it was pointing. A word of caution about Halogen bulbs: When handling new bulbs be careful not to get any grease on them and handle them with clean cotton gloves or a clean t-shirt. Grease and oils from even clean hands will cause the bulb to burn out quickly. Replace the receptacle being careful to make sure the electrical wires are not pinched by the receptacle housing. Replace the screw; replace the grille; return power to the unit. You're done!
Lamp Halogen ranging in price from $8.10 to $10.71.
Jan 05, 2011 | GE Profile JTP18 Electric Single Oven
I am getting arching in the oven when the only thing is themetal pan (rotating) the white dish and any food on the white dish What is happening?
Hello, thank you for posting your question on Fixya. I will be helping you with your Advantium oven. From your description it sounds like your having problem with the oven arcing. While you are using your microwave you can only have arcing occur while you are using the microwave or speedcook feature. While in either mode attention must be given to any mental in the oven. When microwaving place food and containers on the white ceramic tray only. The metal pan should be used during speedcook.
Happy Holidays!
Please rate "4 thumbs" if this was helpful.
Dec 23, 2010 | GE ZSC2001FSS Advantium Electric Single...
GE Advantium SCA1000DBB03 handle replacement
open door look at side there some are some screws remove them the outer door part will come off now don t be afraid to use screwdriver to help take it off good luck later
Apr 01, 2009 | GE SCA2001FSS Advantium Electric Single...
Need to replace light bulb in kitchen aid microwave
KitchenAid wants $58 for the replacement bulb. I bought it for $1.99 from www.lightbulbsdirect.com and it works just fine. The Item number is Q5G412V. It is a halogen 5-watt, 12-volt bipen G-4. Replacing the bulb requires some dismantling of the microwave. At first I was nervous about removing so many parts to get to the bulb but in the end it really wasn't so bad. The only tool I needed was a Phillips screwdriver. I surfed the net a eventually found instructions left by a friendly Blogger that guided me through the whole process. KitchenAid engineers were so STUPID when they designed this microwave. It takes two hours to replace a bulb that should take 5 minutes. Oddly enough, replacing the bulb in the normal oven below the microwave oven is a piece of cake.
Jan 19, 2009 | KitchenAid KEMC308 Electric Double Oven
How to replace lower halogen light assembly, also, replacing turntable shaft
item 1474 is the turntable shaft and is GE # WB02X10624
You should be able to remove item 1476 and lift out the shaft to replace it..then reinstall item 1476 to lock it in place, Hope this helps ...
Sep 12, 2008 | GE SCA2001FSS Advantium Electric Single...
Ge profile advantium 120, scb1001 oven, display panel out
My GE Profile Advantium120 interior lighting it out .What do i do to replace these bulbs.
Jun 29, 2008 | GE ZSC2001FSS Advantium Electric Single...
I need to replace the outer glass on my Advantium oven
contact GE; they should have replacement glass in stock.
Apr 28, 2008 | GE ZSC2001FSS Advantium Electric Single...
GE Profile Advantium SCB2001KSS Stainless Steel Electric Single Oven Logo
435 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
