Question about Samsung HLN507 50" Rear Projection HDTV-Ready Television
Screen shows only black and white
So, we just got this TV serviced about two weeks ago, because it wouldnt turn on. Now, as of today, it only has a black and white picture! On top of this there is a fairly loud humming coming from the back of the TV? It makes no sense to me. I have read from a few post that it could be the color wheel..?? But why the humming noise? the TV is only five years old, and for the price we paid, it should be lasting much longer than that! Does anyone have any ideas?
Thanks
  • nate beast Apr 04, 2009
    I believe I have the same problem. HLN507W1X never has been serviced. Picture started freezing with black and white negative image of whatever the last image was, along with a loug humming from the rear. Shut off and back on, and it work a little while, then back to the original problem. Please assist. Thank you.
    President:
  • Samsung Master
  • 1,779 Answers
Color wheels do go bad quite frequently, if you got 5 years out of the original, believe me, that's good.
The color wheel is attached be a bearing, like a fan and when the bearing starts to ware out the color wheel on the shaft starts to wobble and that's what you hear, they spin I believe around 3000rpm. Try contacting your servicer again, don't be mad, maybe he'll be kind enough just to charge you for the color wheel. I'm sorry, but that's the best advice I can give you..Good Luck...
Posted on Feb 17, 2009
I have Vizio XVT3D474SV I bought a year ago, in the last week while watching TV, the screen start to flash, display becaome white with 3 black lines and after a while it becomes black (the all time the...
When the picture is dark, show a torch light on the screen from a safe distance. If you can see the picture, the backlight is the problem. Anyhow, it is better to show it to a qualified service technician.
Aug 01, 2012 | Vizio XVT3D474SV 47 in. 3D LCD TV
I have a 65 inch mitsu DLP, replaced the bulb 6 months ago.. Worked fine until this week.. Now the TV will power up, turn on, then show a picture for a second then go black.. It repeats this nonstop.. ...
Sounds like the Lamp is over temperature. Either the fan went out or the filter is clogged! You might check the filter first. I hope this will help you...
Jan 07, 2011 | Mitsubishi Televison & Video
One week ago I purchased a Sony - BRAVIA 32" Class / 1080p / 120Hz / LCD HDTV Model: KDL32EX500 | SKU: 9761147 from Best Buy. When I first turn it on, the picture has flashes of white light that...
If standby red light is blinking on tv front that means tv got some internal problem, since tv is new so would be under warranty, call Best Buy or number written on tv documents and ask warranty cover.
Any attempt to fix tv by yourself will void warranty.
Let me know if you have additional question.
Thanks.
Dec 27, 2010 | Sony BRAVIA KDL52XBR2 Television
Tv not turning on
I have this same problem and I just fixed it today. I'm not sure where the problem really is but when i took everything apart and disconnected everything and put it back together it turned on and is now working! I still have one problem now, when i turn it off, the screen goes a bright white but it says that's it's off. If you ever find a solution to that please e-mail me at bmebme26!yahoo,com
Jun 08, 2010 | Westinghouse SK-19H210S Television
Black screen at startup
could be capacitors, are leaky and need resoldering on board, have a quotation with qualified service tech and compare the new price,..but repairing should be cheaper,....
Oct 25, 2009 | Acer AL2671W 26 in. LCD Television
Sharp aquos hdtv has sound but shows a white screen
yes and no. That particular tv you have is done for, but if you just purchased it 6 months ago, you are still within you 1 year warranty with sharp. they will ask you to take it to a authorized service center and you need to follow through with the process. about a week or 2 will pass and the service center will deem the unit unrepairable and sharp will replace it if they cant solve the problem. give em call..good luck 2u
Dec 24, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Jan 08, 2008 | LG 32LC2R 32 in. HD-Ready LCD Television
Samsung HLN507 50" Rear Projection HDTV-Ready Television Logo
138 people viewed this question
Henry  Thomas
Henry Thomas
