Question about GE WBSR3140DW Top Load Washer
Washer fills but won't drain or rinse; low humming noise
My wife put two large sheep's wool car seat covers into machine, let 'er rip and everything went south from there. By the time I got there, everything had shut down. We pulled 20 gallons of water out of tub, then about 10 pounds of free wool that had shed from seats she probably should have hand washed. Not that I'm blaming her! Could I have wool jammed somewhere it shouldn't be? Is there a way to try re-setting? Thanks!
  • 172 Answers
Ouch, sounds like a mess.
Let me see if I can help. The washer will need to be cleaned out completely. To do this you will need to dissassemble the machine. First clear the tub of any remaining debris. Then get a flat blade screwdriver and you will be sliding it into the front top panel of the washer. There is two clips that hold the front on. They are located about 4 inches from each side. To find them slide your screwdriver into the slot in the top of the front panel of the washer. Start on the left at the edge and slowly slide it to the right until you bump against the clip. Once you have found the clip push your screwdriver straight into it and pull from the side of the panel and the left side will pop out. Repeat on the right side and the panel will be loose and just lean if forward and lift off. Next you will need to remove the 2 screw that hold the top down. You will see them once the front panel is removed. Once the top us off you will remove the plastic ring around the tub. It just clips around the main tub. Then pull the top of the agitator off. Inside you will see a screw, remove and lift the agitater off. This is very hard to pull off. Once off you will need to remove a large nut that holds the spin basket down. Remove the nut and then lift the spin basket out. you will see the drain hole and probably lots of debris. Clear all debris and reassemble. Then under the tub you will see an electric pump. You will have to remove the hoses and clean out the pump and hoses. Then after that replace the front panel and pull the machine out. You will now need to remove the drain hose and clean it out. It is held on by another 1/4 inch screw once remove you can just pull the drain hose off. Make sure it is clear and then you may want to check the drain in the wall to make sure you have not glogged it. If the wall drain is clogged you machine will pump all the water out onto your floor and then you have a major problem. I hope this will help you. I know this is a large job, and it may require some professional help. This job would cost as followed from my repair center.
$49.95 Home service fee
$60.00 labor.
plus any parts that may have been damaged. pump for example. You should not pay over $110.00 total for labot and home service fee for this job. If someone asks for more money, they are only trying to get you to replace the machine. Good luck and try to hand wash those rugs from now on.
Michael Anderson
Anderson Appliance
(865)945-3808
Posted on Feb 17, 2009
When i close lid it just makes humming noise and wont start
If washer hums but doesn't fill, water isn't getting to washer check screens where fill hoses connect to washer. Screens may be blocked. If washer fills then hums check to make sure belt is on. Tip machine up to view belt underneath.
Sep 26, 2013 | Maytag Ensignia MAV2757AWW Top Load Washer
Hotpoint hswp1000m washer cycle fills with water for large capacity but when it goes to rinse it won't fill anymore than low capacity of water?
It can be due to a faulty water level sensor which evidently is a pressure switch. If the diaphragm is damaged it will require a larger water level to achieve the said pressure to shut the inlet valve in all the cycles.
Jan 12, 2013 | Hotpoint HSWP1000M 3.5 Cu. Ft. Capacity...
Washer won't spin after rinse cycle
Hello Dorothy - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Sep 29, 2012 | Frigidaire FEX831CS Top Load Stacked...
Kenmore washer model 12502100 goes into rinse cycle fills with water turns then stops. won't drain just stops hear humming or buzzing noise.
Try to put it on rinse on another cycle, like normal, heavy duty or delicate. If it works, then your timer is probably bad. If it doesn't work then maybe the pump. Best of luck
Mar 21, 2010 | Washing Machines
My washer fills the tub, but when it goes to next cycle just hums
Your motor has failed.
Remove it from the washer to have it repaired or replaced.
Thanks
:D
Jul 20, 2009 | KitchenAid KAWS850L Top Load Washer
Washer will not start washing cycle. Machine hums like the dryer
Check the drain for clog. If the drain is dirty, the washer won't fill, rinse, or drain.
May 23, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
GE Front Loader Washer
Door latch is sending false signal to control board,first replace the door latch.
May 26, 2008 | GE WSXH208A Front Load Washer
Washer continuously fills but drains at the same time during rinse cycle.
you have the drain pipe too low into tthe house drain pipe, raise the washers drain pipe up , you only need four inches down into the hous drain
also the house drain pipe needs to be as high as the lid of the machine before you put the washer drain tube into the house drain
you have a syphoning effect
Apr 20, 2008 | Washing Machines
GE WBSR3140DW Top Load Washer Logo
180 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
