Question about Blanco 511-620 supreme 2 One-Piece Undermount Stainless Steel Kitchen Sink
Deep scratches on blanco granite sink
Please help me fix my sink it is scratched and chiped from a glass coffe mug that shattered in the sink. Some of the scratches are small and white and two are deep and a little chiped. Please help me to make it look new and smooth again.
    President:
  • 2,976 Answers
The only way to fix scratshes and chips from a granite surface is to use a sander. You would be safer to have the company thet installed it, resurface it. They have the proper equipment.
Posted on Feb 17, 2009
Scratched computor screen
How deep of a scratch is it on the screen? Just on the plastic/glass protective coating over the monitor?
If it is not in the LCD then you could just remove the plastic/glass and replace it if you want.
If the scratch is deep then your LCD is probably scratched. Sadly the cost of replacing the LCD screen within an LCD monitor is more expensive than buying an entirely new screen. Your best bet is either dealing with the scratch or getting an entirely new monitor. I would recommend visiting www.newegg.com where there are many cheap monitors there.
please rate my solution
Jul 20, 2010 | Acer AL2016W 20" LCD Monitor
Need new stainless steel top.
  • Firstly clean with DeBruce Polish to clarify area.
  • you may have to "re-grain" those finely scratched areas.
  • Blend or "scratch out" the misdirection scratch's with new "controlled" scratching, useing a 3M scotch brite #7447 you get at auto parts store (Nappa). Use medium very firm pressure.
  • -Re-clean with DeBruce Polish. Touch ups are now a breeze
  • DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. NO NEED TO REPLACE. We buy DeBruce at debrucepolish.com.
    Feb 16, 2010 | Tappan TGF657 Gas Kitchen Range
    How do I get scratches off the smooth cook top on my range?
    DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. . We buy DeBruce at debrucepolish.com.
    This IS the answer for cleaning an maintaining. Will not remove the heavy scratching in glass.
    Jan 16, 2010 | Amana ACF4215 Electric Kitchen Range
    I have scratches on my stove top, what can I do to erase them?
    DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. We buy DeBruce at debrucepolish.com.
  • Dec 23, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    Scratches on granite kitchen worktop
    yes...believe it or not, T-CUT car polish...it really does work, even removes scratches from cd's, and scratches on the plastic wind deflectors on car windows
    Sep 06, 2009 | Stone Clearance: Black Granite Vanity ...
    Document feed Scanner Glass Scratched
    If the scratch is not to deep you can polish it out with lots of  elbow grease and cigarette ashes. Their are also products n the market to polish scratches out of glass. A really light rubbing compound like for 3M might work.
    Jan 14, 2009 | Epson Perfection V200 Flatbed Scanner
    How to repair porcelain/cast iron sink scratches
    You can repair the sink with an epoxy based porcelin kit
    Epoxy will not show brush streaks it will levelitself out do not get any kits from HD or Lowes they do not harden
    Go to Sherwin Williams and ask for an epoxy paint for porcelin
    As for removing the under counter sink
    I would try cutting through the caulk adhesive
    between the bottom of the granite and cast iron
    sink with a hack saw blade
    I have used a diamond blade on a grinder and
    cut through but it was not a granite counter top
    Be extremely areful to suport the underside of the sink with 2x4 blocks to prevent stressing the granite as you cut through
    Good luck
    Dec 31, 2008 | Home
    SCRATCHED STAINLESS STEEL SINK
    Have you tried a really fine steel wool? I don't know if this would work. I have stainless steel farmhouse sink, front exposed all stainless steel. My contractor scratched it up horribly when he was putting it into the kichen. he fixed it amazingly with a fine steel wool pad. I don't know if your scratch is too deep for that but it couldn't hurt. The scratches on our sink were surface but very noticeable. Hope this helps.
    Feb 08, 2008 | Kitchen Ranges
    Blanco 511-620 supreme 2 One-Piece Undermount Stainless Steel Kitchen Sink Logo
    1,049 people viewed this question
    Top Blanco Home Experts
    J.D. Browning
    J.D. Browning
    uggachucka
    Level 1 Expert
    VsaToronto
    Level 1 Expert
    Are you a Blanco Home Expert? Answer questions, earn points and help others
