Question about Bosch Axxis WFL 2060 Front Load Washer
Where can we buy a door seal for Bosh Axxis in Toronto? Thanks!
Part of the door seal has been detached.
  • Bosch Master
  • 744 Answers
This video will show you how to change a door seal on this Bosch front loader washing machine
we have all bosch repairs in our channel
You can get seals on eBay
Posted on Jul 23, 2013
  • 6,784 Answers
You can find all the parts you need at this link. Click here for the online store for your part.
Please rate my solution if you can. thx for using fix ya and have a great evening:)
Posted on Feb 17, 2009
Bosh Axxis WFL 2060 operates only on quick wash and warm water!
If you cannot switch cycles then the selector switch board or main circuit board can have faulty componenents and will need to be tested with a multi-tester
Jun 03, 2012 | Bosch Axxis WFL 2060 Front Load Washer
How do I go about replacing the door seal on a Bosh SHX46B02UC/21 dish washer.
If you mean door gasket then the assembly diagram is on this site. see item 6. Follow the drawing and see how it is attached to the cabinet.
If it is the lower door seal which is at the bottom of the door then see this diagram. see item 4.
Aug 20, 2011 | Dishwashers
Bosh axxis filter. how do i clean it? soap and
First of all the item I referred to in my question is actually a heat exchanger located below the dryer drum.
The maintenance man in the condo said remove it and clean it with soap and water. I did have a garden hose with a sprayer so I used the bath tube to give it a good cleaning.
It now looks clean and I cleaned the housing where this part is located with vaccuum and wet cleaning.
jtoolan 6-12-09 7:45 AM
Jun 11, 2009 | Bosch Axxis WTA4400 Dryers
How to un-stack Bosh Washer WFL 2060/Dryer WTL 5410
Did you ever get an answer? I have the same problem...
Mar 21, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Is used Bosch Axxis WFL 2060 with door replaced a safe bet
not a bad price (poss a little bit high) but i would want to see it running on a warm wash first.
Mar 18, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 washer leaks
Hi. Check the doorseal by lifting the folded lip which faces toward the drum opening. Use a torch and carefully examine the doorseal. It may have a small hole which is hard to see at first.
If door seal is ok remove top of machine and check inlet valve. Turn power off and with your hand examine the inlet water valve. If it feels damp on the solenoid then it leaks from there and finds its way around to the front of the machine though the frame work. This leak happens due to to much water pressure at your laundry taps. If so install a pressure reducing valve before the water inlet hose and replace the water inlet valve in the machine as it is now faulty.
0417362396 Melbourne metro area
Regards Sam
Mar 08, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch wfl 2060 front load washing machine
this is joyce
Do this go to Bosh.com and put in your model # and download your manuel to your machine and find out about your machine, but it sounds like you have a bad switch. it is fixing to go out on you. hope not but just in case call your rep in your area who sells your bosh parts and see how much to replace. at least you will have scamatics on machine and will know how to fix. if you need any help with this let me know. I will try to get the instructions on how to take switch off and replace if you have problem with it.
thanks
joyce
Feb 11, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axiss washer front door seal replacement
Remove the top of the machine(screws are at the back).
Look down the side of the front door on the inside of the machine.
You will see a metal wire band holding the rubber on.
You usually only need a screwdriver to loosen the screw which holds it tight.
Try it out and get back to me if you get problems
good luck
Jan 31, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Oven Door will not close properly
Don't buy Bosh. This is a common problem with them and they are not interested in a fix (ie a thinner door seal would help or adjustment to springs...
Feb 11, 2008 | Ovens
Washing machine replacement door seal
This video will show you how to change a door seal on this bosch Axxis WFL 2060
Oct 26, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
175 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
