Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Sony 60" LCD projection TV has yellow screen discoloration
I had had this TV for about 11 months when a yellow spot about 10" in diameter apeared along with a diagonal line to the middle of the bottom of the screen and up to the middle. The yellow lines went away after a few days but the spot remains. The discoloration mostly shows up on white or light colored pictures. Is there anything I can do to fix or help make this problem less noticable. My tv sony wega 50" has a rainbow colors spot about 5" diameter in the top and than i bought a new replacement lamp but still the same as it was...what do you recommended me to do???
    President:
  • Sony Master
  • 1,779 Answers
It sounds like you have a bad Blue Polarizer in the light path. I'm sorry but that is something you will have to contact a service center for. It's not something you'll be able to do yourself, I'm sorry, but that's the best advice I can give you.
Posted on Feb 17, 2009
Yellow spot on sony tv screen
not much you can to it sounds like some magnetic force was next to it IE speakers
Aug 18, 2012 | Sony Grand WEGA KDF-70XBR950 70" Rear...
I replaced the main lamp 6 months ago. Now I have blue on the right, yellow in the middle and normal color on the left. I also have a ghost image of tree branches on the whole screen.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Found it here:http://www.discount-merchant.com/SONY-1-758-484-22-p/1180916.htm Have a blessed one!
Mar 31, 2010 | Sony Grand WEGA KF60XBR800 60" Rear...
Blue spots on sony 65' hdtv
For sony sets with color discoloration: Hi,it seems you are experimenting a light engine problem.This is how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo So basically the 3 Lcd chips that create the colors and image is going bad and thats why you get that color discoloration.Contact Sony or look for your light engine online.God bless you and your house!
Nov 17, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony kdf-e42a10 screen discolor yellow streak on white background. lamp 6 month old.
Unfortunely your optics engine needs replacing, (Light Engine).. The only solution to repairing this problem is to replace the optics engine, One of the LCD Screens has gone bad.
Oct 28, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Hitachi lcd projection tv screen discoloration model 50vs69a
probabally a dust spot on the mirror or the lcd mini panels inside the optical engine.
must be dissembeled to clean.
not for the faint of heart.
Jun 13, 2009 | Hitachi 50VS69 50" Projection HDTV
Large yellow spot in center of tv screen
Sorry, but there is no cheap method of repair for this unless it is in warranty.
This TV will require replacement of the LCD Prism unit.
This Prism blocks and allows colors so that the 3 LCD images may be mixed to produce the final image you see on the screen. When this becomes damaged or defective, it leaks colors (light). This Color Leakage apears as spots on the screens.
Where you see the spots is where the specific spot on the prism that is leaking light, the specific color that is leaking also.
This parts cost alone is normally $500 to $1000 dollars but is usually replaced under warranty.
Good luck.....
May 18, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
60" LG Lcd Projection TV
ok u could have somthing on the lcd srenn and thta is y u have a yellow spot what i would do first is pull out the unit and look at the luc screen and buld to see if u have somthing on it i could be a small pice of papaer or anything it is best if u look at it thru the lens on the inside on the tv when u have it on because u can see i t better i hope this hps marty
Oct 12, 2008 | Hitachi 60V500 60" Rear Projection...
I would suggest to try to get this TV fix while still under warranty. Normally the manufacturers give one year.
In regards to the discoloration, there is not much you do but to let the Sony authorized repair center knows about it so they can fix it. Ask them if their work is guarantee as well for how long.
Good Luck.
Feb 25, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Hitachi 60 in. 60V715 Yellow Haze
I would first check and see if any software updates are out on this set, you can call Hitachi, if not that then it could be the engine assemble having problems.
Jan 02, 2008 | Televison & Video
Yellow Haze
What model of set do you have?
Dec 29, 2007 | Televison & Video
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
1,000 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
