Question about Philips 60PP9352 60" Rear Projection Television
Soft white light on screen when screen should be black
When screen should be black, the right side of the screen has a soft white glow. I am just concerned that something might be going wrong with the TV. It is about 3 years old and I would like to know if there is anything I need to do.
  • Philips Master
  • 3,459 Answers
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directiSoft white light on screen when screen should be b - 2c07611.pngnvergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
of a set that needs the fluid cSoft white light on screen when screen should be b - 2c07611.png/>
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Mar 15, 2009
Tv was cleaned with water yesterday on the screen and today one side is duller and the picture is shaking. When first turning it on the left side of the screen is white and right side is black
I'm afraid you have gotten some water where it never should be; the current controlling the millions of pixels is being bled off.
If you live where heat is now available, place the set (power disconnected) where it is exposed to warm air.
If the sun is shining and you can place the set with the back facing the sun, let it sit for a while and you might try prayer that nothing was damaged by currents flowing where they should not.
A little late for suggestions but LCD screens have many hundreds of electrical contacts around the perimeter of the screen and water (or any other liquid) should never sprayed at the screen.
A clean, soft cloth, sprayed (dampened) and gently wiped on the screen should suffice to remove most contaminants.
If the surface of the screen seems to yield (soft to the touch) use extreme caution with pressure.
Good luck-
Jan 10, 2015 | Samsung UN55H6203 55 Inch 1080p 120Hz
My screen went sideways
How do you mean, "sideways", or "stuck on right side"?
Has the orientation of the picture changed, for instance, from left to right to bottom to top?
More explanation is needed.
Regards.
Jul 06, 2014 | AB Soft MacBook 2.0Ghz Intel Core Duo 13",...
I locked my phone. Every time I unlock it I would have to put my password in. I put my password in, and it said incorrect. I know it was correct, I don't forget my password. So I kept trying it and trying...
You will need to reset the phone for everything to return to normal. I would advice you perform a double soft reset, though it is a bit tactical. Performinga SOFT reset on the BlackBerry device Performing a soft reset stops allapplications on the BlackBerry device by pressing the ALT+RIGHTSHIFT(CAP)+DELETE keys. A soft reset re-establishes communication between theBlackBerry device and the computer.
Performinga DOUBLE-SOFT reset on the BlackBerry device Performing a double-soft reset stopsall applications on the BlackBerry device and is nearly the equivalent of ahard reset. Timing however is critical. Perform a soft reset by pressing theALT+RIGHT SHIFT(CAP)+DELETE keys. The screen will go blank. When the screen isno longer black, press the ALT+RIGHT SHIFT(CAP)+DELETE keys again. You shouldthen see another blank screen followed by an hour glass. HOPE THESE HELPED
Apr 24, 2011 | RIM BlackBerry Storm 9530 Smartphone
Hi there. My P3300 goes dead.After I turn it on the HTC logo comes on for 5 seconds and then like it is made ot of sand the logo disapears and awhite screen remains sometimes with some blue lines. If I...
try soft reset
Use the stylus to press the RESET button found on the lower left side of your device. Your device restarts and displays the Today screen.
if this doesn't help,you can not recover any data.you have to master reset via
  1. Press and hold the Left SOFT KEY and the Right SOFT KEY, and at the same time, use the stylus to press the RESET button at the lower left side of your device.
  2. Release the stylus, but continue pressing the two soft key buttons. Release them only when you see the following message on your device screen: “Press Send to restore manufacturer default, or press other keys to cancel.“
  3. Press on your device. Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have been backed up before a hard reset is performed.
Mar 18, 2010 | HTC P3300 Smartphone
Wont get off tmobile shadow white screen...
the "soft buttons are right below the screen hold both down then turn on the phone this will make the phone ask if you want to reset to default so try removing the batt first as this it the last resort you will lose all changes made to the phone except mem card and sim card stored items worked on my shadow fine good luck peeps
Mar 02, 2009 | HTC Shadow Smartphone
T-mobile dash
youll have to reset it. with the phone turned off, press the two soft keys and hold them down. soft keys are the buttons with the lines on them located below the screen. as youre holding down the soft keys, you need to press the power button. it will start to power up then go to a black screen with white writing. press the send key. the phone will reboot.
careful, because this reset will delete all personal data and set everything to manufacturer default....good luck!
Dec 16, 2008 | T-Mobile Dash Smartphone
Unlock problem
Do a hard reset. To do a hard reset hold down the red and green buttons on the front of the phone and push the reset button on the bottom of the phone at the same time with the stylus. This just fixed my problem
Sep 18, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
Picture flashes and soft images
sounds like poor regulation replace regulator get back too me
Oct 13, 2007 | Sony KP-53HS30 53" Rear Projection...
Keypad light is not glowing intermittently, what will be the problem.
this prob is common in L6,L7,L9 and such phones. There is asender on right hand side near the soft key.dont put ur hand on it . The prob wil be solved
Oct 06, 2007 | Motorola Mobility L6 Cellular Phone
Philips 60PP9352 60" Rear Projection Television Logo
52 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
