Question about Toshiba Tecra M2-S630 Notebook
AC connection is no longer recognized on laptop.
I have a Toshiba Tecra m2 s630. worked great for the past three years. It recently stopped charging/reading the AC connection. The AC cord is fine, the connection is plugged properly - no loose ends. Any suggestions?
    President:
  • 2,992 Answers
One common problem is that the adapter output wire breaks inside the insulation near the plug from flexing. You can't see the break, but sometimes wiggling the cord will cause the power indicator on the laptop to come on and verify the trouble. Or you can test the output with a voltmeter if one is available. This trouble can be fixed by cutting back the wire a couple of inches and soldering on a new plug, or by purchasing a replacement adapter.
Another frequent problem is for the power jack connections to break loose at the circuit board inside the laptop, again from flexing the connection. This is also a repairable problem (most of the time), but involves removing the system board from the laptop and resoldering the connections. If you don't know someone who is willing to try the repair, a service shop in your area could give you an estimate. Note that occasionally the board becomes damaged from heating and arcing at the bad connections, and is too badly burned for reliable repair. In these cases, the board needs to be replaced.
Please take a moment to rate this solution if it's what you needed, and thanks for asking here!
Posted on Feb 17, 2009
    Problem Solver:
  • 15 Answers
Might be problem with AC jack please checkout with multi metre whether current is proceeding further or not.
jrpitale
I have a cracked screen (toshiba tecra m2) and have an opportunity to buy a replacement screen from a tecra m2 S630 that is broken. Are the screens interchangeable?
Can't answer your screen question, but I can propose a workaround - your Toshiba laptop has a
monitor port on the back - you can plug in a standard monitor, and ignore the cracked screen
temporarily until you can replace it. hope this helps
The monitor port is the 15-pin analog VGA D-shell (female) port.
The online User's Guide for your Toshiba Tecra m2-S630
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=596874&rpn=PTM20U&modelFilter=M2-S630&selCategory=2756709&selFamily=1073768664
Apr 17, 2011 | Toshiba Tecra M2-S630 Notebook
Is it possible to run windows 7 on a Tecra M2-S630?
yea you can run windows 7 but you will need to delet your old windows under f2 or f12 what ever your lap tops boot setting is.
Feb 27, 2011 | Toshiba Tecra M2-S630 Notebook
Trying to install missing driver for the ethernet controller for a toshiba tecra m2 s630... what should I download and how do I install it? thanks for the help
“To locate the "Ethernet Drivers, "install, "update, and "Apply configurations.” Go to, Control Panel, select “Hardware and Sound” or select Device Manager, Next, click to open Network Adapters (Properties), perform all the steps to “reinstall Ethernet Drivers.” “Toggle through the categories. In the Advanced (block) check to see if, “Device” is (Enabled)?” “ Apply" to all, and click OK! Restarting the Computer finalize, and identify changes made to configurations. “I hope this helps Ya”
Jan 30, 2010 | Toshiba Tecra M2-S630 Notebook
Upgrading memory on Tecra M2
the other memory chip is under the keyboard.
Oct 20, 2009 | Toshiba Tecra M2-S630 Notebook
Driver required NETWORK CONTROLLER for Toshiba tecra m2
i can not find the wireless lan driver for tecra m2
Oct 05, 2008 | Toshiba Tecra M2-S730 Notebook
Toshiba Tecra M2-S630 Notebook Logo
126 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
