Question about Sharp AR-235 Copier
AR-235 how to set default to duplex - network printer
Printer installed on a server and shared from there
Need to set duplex to be the default
Anyone know how to do this?
    Scholar:
  • 60 Answers
On the server, go into the 235's properties, click on the advanced tab, click on printing defaults. That's where the clients get their default printer settings from. If that helps, please rate me. Thanks.
Posted on Feb 21, 2009
How to make mp760 wifi
This printer has only an USB connection that connects to your computer and cannot connect to wireless network directly. You can attach this printer to a wireless printer server/router to enable wireless printing.
OR
SET UP A SHARED NETWORK PRINTER
Any printer that is connected to a computer and is connected on a LAN can be configured so all other computers on the same network can print to this printer. This means the computer with the printer attached to it MUST be booted up at all times when other computers want to access the printer. You need to install the printer driver on the computer and configure it as a Shared printer. The other computers on the network need to add this printer to their computer. Follow these steps to set-up a shared network printer :- 1. Connect the printer to the computer and install the printer driver. 2. Open Printers and Faxes - right click on this printer and click Sharing - click Sharing tab and click Share this printer, and then if you wish you could change the Share name, then click OK 3. Right click on the printer - click Properties - click Print Test Page to confirm printer installation. Follow these steps to configure the computers on your network :- 1. Open Printers and Faxes - click Add a printer - Next - select a network printer, or a printer attached to another computer - Next. 2. Select Browser for a printer - Next 3. Click on and expand the Microsoft Windows Network down to the computer with the printer - Next 4. Select Yes for - Use this printer as the default printer - Next - Finish 5. Right click on the printer - click Properties - click Print Test Page to confirm printer installation.
Dec 02, 2012 | Office Equipment & Supplies
Tip
How to connect a wireless printer.
First things first. Make sure that you have the same username and password set up on the machines you want to use as your print server and the machine(s) you are going to print from, the or the "Client".. This is required so that you can communicate with the other machine(s), "Clients".. Once you have the machines’ usernames and passwords set, you can turn to the machine with the printer attached to it. (which we will call the print server). From this machine (The one we have called the print server), we will need to set up the default printer on it. So install the software & drivers for the printer. Test that you can do a "Test Print" . Then we will need to go to Printers and Faxes in the control panel. You need to right click on the printer that you want to share, and choose properties. When you get to the properties page for the printer, click on the tab that says "Sharing". That will enable the client PC to "See" & be able type in the printer’s name. Usually the software will put the "Printers" name in. It will be grayed out until you click the radio button to share it.
Now, when you are ready, go to the "Client" computer you want to print from, wirelessly. When you set up your printer, go to install the printer, and you install a "Networked Printer" you then you "Tell" the installer where the "Printer" "is on the network". So when asked for location you then you can "Browse" for the printer, or type and your IP address OR host name,and Printer name too.. Mine is 192.168.1.64 OR heaven, so I typed 92.168.1.64, OR the Name of the machine. So say: As in my case, 92.168.1.64BrotherD or heavenBrotherD. Anyway, this will then go away, and connect to the "Printer" and do some houskeeping & finish, from then on, you will be able to print. try a test print the same as you did on the "Print Server". If you wish to print from say, Word, do it, by simply choosing the correct printer from the print menu that comes up whaen you try to print. Ensure you right click on the Printer Icon on Client and choose "Default Printer" too. You can also right click on documents and images files, and select "Print".
Also ensure that the print server is set to on, in Services too, on BOTH machines.
on Feb 06, 2010 | Office Equipment & Supplies
Hp deskjet 550c trying to print from network But I am on windows 7. Printer is on xp. Can't find driver or fix to run printer on network
Use my published guide to install the latest drivers for all computers on the network. It is entitled
How to Install the latest drivers for Hewlett Packard Printer!!!
The drivers need to be installed on all computers in the network.
Then once the drivers are installed all you need to do is to navigate to the Windows control panel and double click printers and faxes on the computer that the printer is connected to.
Now right click the your printer and select the option Sharing, this will allow you to share the printer on the network.
Click the lower circle to share the printer.
Then when you print from another computer on the network, be sure to select this shared printer as the printer to print to, or set this shared printer as the default printer by right clicking the printer and selecting the option to set as default printer.
Please be sure to rate this session.
Take care!
damnor01
Jun 01, 2011 | HP DeskJet 550c InkJet Printer
Wifi printer and 1 laptop wont work
Check your setup against this install guide.First things first. Make sure that you have the same username and password set up on the machines you want to use as your print server and the machine(s) you are going to print from, the or the "Client".. This is required so that you can communicate with the other machine(s), "Clients".. Once you have the machines’ usernames and passwords set, you can turn to the machine with the printer attached to it. (which we will call the print server). From this machine (The one we have called the print server), we will need to set up the default printer on it. So install the software & drivers for the printer. Test that you can do a "Test Print" . Then we will need to go to Printers and Faxes in the control panel. You need to right click on the printer that you want to share, and choose properties. When you get to the properties page for the printer, click on the tab that says "Sharing". That will enable the client PC to "See" & be able type in the printer’s name. Usually the software will put the "Printers" name in. It will be grayed out until you click the radio button to share it. Now, when you are ready, go to the "Client" computer you want to print from, wirelessly. When you set up your printer, go to install the printer, and you install a "Networked Printer" you then you "Tell" the installer where the "Printer" "is on the network". So when asked for location you then you can "Browse" for the printer, or type and your IP address OR host name,and Printer name too.. Mine is 192.168.1.64 OR heaven, so I typed 92.168.1.64, OR the Name of the machine. So say: As in my case, 92.168.1.64BrotherD or heavenBrotherD. Anyway, this will then go away, and connect to the "Printer" and do some houskeeping & finish, from then on, you will be able to print. try a test print the same as you did on the "Print Server". If you wish to print from say, Word, do it, by simply choosing the correct printer from the print menu that comes up whaen you try to print. Ensure you right click on the Printer Icon on Client and choose "Default Printer" too. You can also right click on documents and images files, and select "Print".
Feb 18, 2010 | Belkin (F6D3230-4) Router (F6D32304)
Can't get Oki to duplex
some of the oki's & hp's wont duplex on the network without a print server, know it's a shot in the dark but is it connected to a print server or directly to the network.does it give any errors or just fail duplex and comes out single sided?
Jul 28, 2009 | Office Equipment & Supplies
Sharp ar-287 network password reset
Try deleting the printer in control panel. delete the drivers and reinstall software and drivers.
Jun 13, 2009 | Sharp AR-235 Copier
Wireless printing
I assume you have a wireless network set up with a wireless router, since you said you have a wireless laptop.
You need to share the printer on the desktop. You also need to set up both computers to be on the same network (for example, WORKGROUP or MSHOME, or a name of your choosing).Once shared and on the same network, you can go to the laptop and add a printer--just tell it that it is a network printer.
A caution--to work without further hassle, both computers need to be running the same version of Windows. If not, you'll need the driver disk for the system on your laptop.
Jan 16, 2009 | Computers & Internet
Printer connected to more than one computer.
Hello
I gonna try to help you.
1. you need all the computers connected to same network.
2. you need to share your printer from the computer where the printer is connected to.
to share
a. go to control panel->printers and rightclick on your printer click sharing.
b. then share that printer and give it a share name and then OK.
click here to see pictures exact information about sharing.
c. you also need to know what your computer that shares the printer is named.
to find out go to control panel->system settings and tab computer name. write that down
a shortcut to this windows is "windows button flag" + Pause Break button.
3. go to the computer you want to install the printer on.
this computer need to be in the same network as the one with the printer.
4. click start menu then ->run and write "\\computername" and press enter. computer name is that name you write down in c.
5. then a window should appear and you can now double click on your printer that you shared, then it should auto install. done.
6. if you can find your computer with the printer, check your firewall settings on the computer that shares the printer so the connection doesn't been blocked.
good luck, if you need more help don't be afraid to get in contact with me. true fixya forum or fixya live chat
good luck
Dell-Net
Oct 15, 2008 | Office Equipment & Supplies
Auto duplex disappeared in HP Business Inkjet 1200
The default in Vista seems to be the duplexer is not installed. You will need to tell the driver the duplexer is present. This would be found in the (control panel)printers folder, doubleclick on the 1200d, printer, properties, device settings, installable options, then select "installed" for Duplex Unit.
Aug 14, 2008 | HP Business Inkjet 1200dtn Printer
We need to print from wireless laptop .help please
I am assuming that:
1. There is installed a shared printer in one of the other computers in your network; or
2. The shared printer is connected to a Wireless USB Printer Server;
3. The laptop can connect to the network and is authorized to access/use shared resources.
Procedure would be identical to installing a printer. Follow on screen instructions. Click on Start, Printers & Faxes, Add a Printer, Next, tick "A network printer....", tick "Browse for a printer", Next, Select printer choice, Next, OK, make default, print test page. It might take a bit of time while drivers are copied from the printer server to your laptop. In some printer that is directly connected to the network, you need to pop in the CD that came with that printer and install. Thereafter, you need to change the port setting in the Printer Properties to TCP/IP and point to the assigned IP address of the printer.
Hope this be of some help/idea. pls post gain how things turned up or should you need additional information.
Good luck and kind regards.
Jan 30, 2008 | Computers & Internet
Sharp AR-235 Copier Logo
405 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
