Question about Vizio L32 32 in. LCD HDTV
Change in color, computer problem inside TV
Today we turned on our Vizio hdtv to see a lilac color screen instead of the royal blue. The image is there but really swirled with a rainbow of pastel colors, like light blue, lime green, pink, yellow. You can make out the commercial or show, and the sound is working, but crazy coloring within the image (swirly). We tried to reset it with the vizio tech, to no avail. Any comments??
  • Anonymous Feb 18, 2009
    I am having the same problem with whites coming through as yellow and the blue screen has alot of darkish blue color with vertical static bars. I was told by a tech that it was the Level 1 capacitor which controls the color. About $100 repair. I will find out today.
  • Anonymous Mar 25, 2014
    the color is blured and has pink and blue like a rainbow
    New Friend:
  • 56 Answers
For "thechances", The LVDS cable has gone bad. This cable connect between the mainboard and the panel. The replace the cable will fix the problem.
Posted on Feb 19, 2009
Color problems vizio lcd hdtv
If your tv has a custom settings area, first turn all color down on set so picture looks black and white. Now in color settings look for red blue and green color bars. Use the bars until the picture looks as true to black and white as possible. Also, try changing color temp.
Dec 21, 2013 | Vizio VW37L 37 in. LCD HDTV
Vizio p50hdtv10a Has inverted colors wen you turn the TV on, the image shows like the colors have been inverted, the picture looks like a negative. Havent cracked the case yet, would like to know where to...
may be a faulty lead to the screen driver or the screen drive has a fault. would need to check the cables to the screen driver board on the back of the screen
Oct 01, 2013 | Vizio P50HDTV10A 50 in. Plasma HDTV
Today my 55" vizio screen popped and then turned red. I unpluged and restarted everything and now the audio is on, the chanels change, but the screen is completely read. some images are readable.
If this is a VO47LFHDTV20A TV set, the problem is most likely your LVDS(cable from the main board to the t-con)cable is faulty. When you turn the set on, do you have a red screen instead of the standard blue screen? Do you also have red tints on all images on all inputs? If this is the case, your LVDS cable is bad. If you are comfortable opening up your set, track down where the LVDS cable goes into the t-con board. Turn on the set, and wiggle the cable, if the red tinting goes away, you will need a LVDS cable, about $24 part.
Dec 09, 2012 | Vizio VO47L 47 in. LCD TV
Vizio start blue/yellow flickering screen
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jul 01, 2017 | Vizio VW42LF 42 in. LCD HDTV
When I turn our tv off the vizio emplem stays orange
According to the manual. It says The Vizio lights white when powered on and orange when powered off.
Mar 03, 2010 | Vizio VW42LF 42 in. LCD HDTV
Converging problem
This is a rear projection TV that uses three color "guns" in a cathode ray tube . They are no longer converging at the screen. The convergence problem is usually a sign of something else gone wrong with the high voltage.
Do NOT attempt to open this set yourself. This type of TV can have LETHAL voltages inside for WEEKS after it is unplugged. The repair and convergence calibration will require a qualified service technician.
Jan 09, 2010 | RCA HD52W59 HDTV Projection Television
Vizio 32'' VO320E Image Distortion
I hope not but:
this is probably a failure from the screen or the electronic parts that control the videosignals.
i think having a specialist or the tecnical service from vizio taking a look at it will be best and safest.
Hope this is helpful, and greetings,
Olivier.
Oct 21, 2009 | Vizio VO320E LCD TV
Vizio L32 32 in. LCD HDTV Logo
536 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
