Question about LG Electronic Window Air Conditioner
LG Air Conditioner/Heat Unit spits cold air
I have an LG unit that is both our heater and air conditioner. We're currently using it as our heater and it randomly spits freezing cold air out in cycle. The code FP shows up when this happens. I've read the manual cover to cover and can't find any mention of this. How do I shut it off?
  • Anonymous Feb 21, 2009
    It's both electric heat and cooling
  • Mark Egan May 11, 2010
    Is this a heat pump type of unit? Or is it electric heat and cooling?
It's quite simple really.
I live in a dorm which features this very A/C unit, and in the cold winter nights in Santa Fe, it's not the most pleasant feeling in the world, so to solve this problem, we did the most rational thing we could do.
Unplug it
Ahh yes! The kill switch to all modern appliances. If they're doing something you don't like, then just unplug it. When we feel that the room is warm enough and don't want the unit to ruin it with its "Freeze Protection" regiment, we just unplug it until it gets too cold in the room. We haven't had any problems since. :)
Posted on Feb 09, 2013
  • College Student Feb 09, 2013
    Unplug it
    Problem Solver:
  • 10 Answers
I believe the "FP" probably stands for Freeze Protection and it's there to prevent your outside coil from freezing up and causing your head pressure to drop. To do this, it briefly has to reverse the cycle from heating to cooling. This is normal in a heat pump.
Posted on Feb 17, 2009
Using as heater and unit is blowing cold air
A heat pump is an air conditioner that reverses its refrigerant flow. In the cooling mode, the evaporator is cold to the room and its condenser is hot. In the heating mode, a valve reverses the refrigerant flow and makes the evaporator warm and the condenser cold.
Nov 24, 2013 | Soleus 10,000 Btu Portable Ac Air...
Twice the heat went out LG 18000 5 year warranty. 1st time unit sparked inside the unit, Tech came out couldn't repair was given a new unit (2 weeks out of service) had to buy 2 floor heaters at a cost...
was the first unit a different model ? what the repairman said is pretty much right but they should be more ontime and communicate if they want a good name. the unit should work fine after replacing if it doesn't dont pay for the part
Nov 10, 2010 | LG LWHD1807HR Thru-Wall/Window Air...
LG LWHD1800HR window air conditioner/heater does not heat fully.
It's 115volt and is a heatpump, these units work best above 40 degrees. They only put out between 95 and 105 degree air. The colder it gets outside, the less heat ya'll are gonna get.
Nov 06, 2010 | LG LWHD1800HR Wall/Window Air Conditioner
Condensation buildup
Make sure the unit tilts towards the outside. If it's installed level or tilted toward front it will not drain properly.
Jun 25, 2010 | LG Electronic Window Air Conditioner
Air conditioner not cooling
Most likely cause is you have lost your coolant/ freon
These low end unit are generally not worth recharging you can buy a new one for less than a tech will charge you to fix it
Mar 08, 2010 | LG Goldstar GWHD5000 wall/window Air...
Carrier spit type air conditioner 5 blinks
Hi, you should have a error chart on one of the panels of the unit that will tell you what the 5 blinks mean. It will be pasted on the unit inside some where. Let me know what you find and we will go from there. Merry Christmas,
Shastalaker7
Dec 25, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Lots of water in unit spitting all over the floor nd itd not as cold as when i got it last year
how long you last service the unit, when last you cleaned the air filter. Drain pipe might be clogged. If it has been a year it is time to service it
Aug 05, 2009 | LG Goldstar GWHD5000 wall/window Air...
Air not cold
If you are always using it, yes it could be. The heat it produce helps in its normal wear and tear. Corrosion is one and dirt helps. Freon could stay in the system as long as it is not getting any break or hole.
If freon is out of the case. Unit not getting cold, the fault could be dirty air filtter, dirty exchanger, dirt in the system itself, or clog. And also you cannot negate it thermostat, could be its setting or actually faulty. And compressor fault.
May 22, 2009 | LG LB8000ER Air Conditioner
LWHD1200HR - LG 12000 BTU Heat / Cool Window Air Conditioner
i have a lg lwhd 1200hr window ac the heating system dont work . it blow cold air out not heat. can you help me
May 28, 2008 | LG Heat cool Window Air Conditioner
No heat
1.check heatar of unit.
2.wireing of heater.
heater not workink.
thermostate also check
Feb 21, 2008 | Amana PTH153B50AJ Heat Pump Air...
LG Electronic Window Air Conditioner Logo
371 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
