Question about Electrolux AOFP061U Blast ChillerFreezer Half Size (6) 12""x20""x2 and a half"" pan capacity rack programmable ...
Elecrrolx air o chill blast chiller
Where do i get a manual on the model no...AOC P061T please, unit rus for a second and cuts out, start button keeps flashing.. thanks
4 Suggested Answers
vanni7
  • 163 Answers
SOURCE: electrostatic chiller doesn't chill anymore
Hi!!! you seem to have a problem with your seal system .go to back and check your compressor and fan condensing motor make sure that they are on if yes..then you have a restriction or a freon leak..Good luckk...
Posted on Jan 04, 2009
SOURCE: thermal coupling in wine chiller
No, I would not recommend putting water into the chill chamber since if there is a "gap" hole in this compartment, the water could get inside the unit's electronics etc.. which could at the very least short the unit and at worst electrocute you as you take the bottle out/touch the unit. That's the problem with this or any other Peltier/thermoelelectric type of chiller. They are only good for maintaining an ALREADY cold bottle's temperature, not for chilling it rapidly. There is no good or inexpensive way to get better chilling from these types of units. It's the law of themodynamics and heat transfer. Water is the best/safest/most inexpensive medium to use, not chilled air or even super cold air. Cold air or even super cold air just does not match the chilling potential of a liquid like water. The reason why 50F air is no problem, for you to be out in for hours, but 50F water you'll get hypothermia in 20-30 mins.
The best unit for chilling a warm wine bottle is the cooper cooler. Go to www.coopercooler.com. It uses ice and water and sprays the ice cold water over the bottle while spinning it to chill it quickly. This unit is great since it can also chill single serve drinks like beer/soda etc so is more versatile than the other chillers. Cheapest is about $59 which is much less than the waring at ~$100
Posted on Apr 14, 2009
  • 47630 Answers
SOURCE: E4 error fault code on a electrolux blast chiller model RBC101. What is it?? Thanks a lot
what is a blast chiller .
Posted on Mar 03, 2016
Display panel on fridge door display flashing from 4 to 7 and beeps 5 times.
the blast chiller fan has prob failed
also check the thermal fuse on the heating elements that are around the chiller elements {used to defrost the chiller section}
and if there is also one on the fan check it
the beeping is prob an error code
you can consult the manual or phone the makers support number
to get more info on the exact error detected
usually there is some reset error like hold in the button etc and power on then let it go
more any more appliances have this
and if you dont know to reset
even if the error is cleared the unit will remain in this error mode
till reset again check the manual
Jun 19, 2014 | Amana SXD524VW Side by Side Refrigerator
I need information ary model chiller fault,low water temperature
Hi,your question is not very clear though.
1Try to check the chilled water sensor(transducer for appropriate resistive values).
2.Check that chilled water is circulating at the correct pressure
Regards,
Adamson (nyauadamson@gmail.com)
May 04, 2014 | Heating & Cooling
The air condition air flow has problems
check blower fan for loose ground and power supply
Jun 23, 2012 | Air Conditioning and Heat for Mercury...
Kitchen selectives rechargeable wine chiller bc-10r 8 minute chill
For the KITCHEN SELECTIVES WINE CHILLER...A box on ebay says: Put bottle inside, add ice to neck of bottle, add water, plug in and set timer for 10-20 minutes. It chills from 77* to 55*or 33* (can't read numbers clearly) in 10 minutes. Can also be used on other drinks and canned drinks. Can be used as an ice bucket as well to keep the opened bottle chilled.
I just bought one at Goodwill for $4 today and was looking for the instructions as well. Hope this helps! 8d55b92a-9870-497d-a9c6-7cda8d40c58a.jpg 11a83201-002b-4f0c-b811-810f4cf0046e.jpg
Dec 16, 2011 | Refrigerators
I need a ladder diagram of a air cooled chiller thats 3 phase
None of my sources know anything about this machine. I am not familiar with it either.
Oct 06, 2011 | Beverage-Air Beverage Air BAC12 Blast...
I am looking for a new lid for a weber chiller model Vestfrost 8-024510095, does anyone know where i can buy one from.
Buy a plastic cutting board, cut it into a 16 inch circle. Put a handle on it. Works better than original, keeps things colder!
Apr 29, 2010 | Weber Chill 05-161 Beverage Cooler
New lid needed for model 45674 Chiller
Buy a plastic cutting board, cut it into a 16 inch circle and put a handle on it. Works better than original, keeps things colder!
Apr 12, 2010 | Weber Chill 05-161 Beverage Cooler
Unit continues to run in emergency heat when shut off.
If you turn tstat off does it still run. If so you have sequencer stuck. Replace sequencer. Also you may ahve abad defrost board out side. When a unit goes into defrost it will bring on heat so you will not get a blast of cold air. Sometimes the defrost board sticks and keps the heat on. Disconnect white wire at outside unit to break circiut. If hat goes off bad defrost board. You can change that yourself. Keep in touch Rus
Dec 08, 2009 | Goodman CPLE24-1 Air Conditioner
Thermal coupling in wine chiller
Feb 01, 2009 | Waring Wine Chiller - Black
Need Owners Manual for Kitchen Selectives Wine Chiller (1 Bottle)
A box on ebay says: Put bottle inside, add ice to neck of bottle, add water, turn on and set timer for 10-20 minutes. It chills from 77* to 55*or 33* (can't read numbers clearly) in 10 minutes. Can also be used on other drinks and canned drinks. Can be used as an ice bucket as well to keep the opened bottle chilled.
Jan 16, 2009 | Kitchen Selectives CM-202 Coffee Maker
Electrolux AOFP061U Blast ChillerFreezer Half Size (6) 12""x20""x2 and a half"" pan capacity rack programmable ... Logo
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
