Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Epson CX7450 Black Ink Won't Work...
I changed all ink cartridges today, and I have reloaded them several times trying to fix the problem. The colors work fine. I have realligned, cleaned, etc. etc. And I have gone thru the manufacturers troubleshooter with no success. My daughter has a report due tomorrow, and I can't get the black ink to work.
  • 4 more comments
  • Anonymous Feb 21, 2009
    ditto
  • Anonymous Mar 09, 2009
    Same thing is happening to me.
    The instructions say not to take tape off.
  • Reyalsnik Mar 13, 2009
    I have the same problem and just replaced the cartridge with a brand new one, thinking that was the problem. Black does not print at all in any cleaning or alignment test. It also does not work in the Copy feature. The printer is reading that it is a full cartridge. It was printing fine when I purchased it. This occurred after about a month of not using it.
  • Anonymous Mar 20, 2009
    Same exact problem. Bought new Epson black ink cartridge. Lights flash but won't print or copy.
  • kimiemich Mar 27, 2009
    Exact same problem. Have replaced all cartridges, but the light remains beside the ink drop picture on the printer. I can't find any explanation for why it's not working. It was printing fine before, but I haven't used it in about a month. If ANYONE finds out how to fix this, please chime in!
  • Anonymous Apr 13, 2009
    Same problem here.  Epson has such limited customer service hours that I haven't been able to reach them.  There has to be some fix for this.
I was having the same problem. This fixed it:
Lift up the scanner bed (top part) of the printer to expose the cartridges.
Push the red triangle button once. Wait for the cartridge carrier to move to the middle. On the housing of the printer (the non-moving part), there is an arrow that will point to the empty cartridge.
Push the red triangle button again to see if the next cartridge is empty. Repeat this step, noting which cartridges are empty, until the cartridge carrier moves to the right. Now you can replace each cartridge that is empty.
After replacing the empty cartridges, push the red triangle button again, and the carrier will begin moving back and forth (cleaning itself). Once it stops, it should be positioned on the far right side.
Lower the scanner bed to "close" the printer. The ink light should go off and you should be able to print.
Posted on Jul 31, 2009
  • 31 Answers
GET YOUR SOLUTION FROM EPSON
HERE IS YOUR SOLUTION
http://www.epson.com/printer/prob676ijt65/solution
a12
Posted on May 22, 2009
    Sergeant:
    Champion:
  • 357 Answers
Make sure the tape has been removed from the cartridge.
The cartridge could be defective, the only way to tell is go buy a band new black epson cartridge and see if that solves your problem.
I hope this helped.
Good Luck.
Posted on Feb 22, 2009
I am going to replaced the 3 colors with all black ink...
Any thoughts?
Posted on Mar 24, 2009
My printer wont work..............
Posted on Jun 12, 2009
No ink output from Epson Stylus Color 777
I don't have an answer for you but I have the exact same problem.
I have an Epson Stylus Color 777 and I put in new cartridges (black and color) that I bought yesterday (03/05/10).
I pulled the tape off the cartridges and inserted them in their carriages. Everything works like usual except that no ink at all prints on the page. Comes out completely blank.
Nov 11, 2009 | Epson Stylus Color 777 InkJet Printer
My Epson cx7450 ran out of ink a while ago. I
Did you remove the cartridges when it went out of ink? If so, the printer head is clogged. Anyway, If you didn't remove the cartridges and the "a while ago" means "Long time ago", is more likely the printer head is clogged. You may need to run the "cleaning printer head" feature from the printer or replace the printer head.
Inkjet printers should be used frequently to avoid this issue.
Sep 06, 2009 | Epson Stylus cx7450 All-In-One InkJet...
Why won't my CX9400F recognize Epson ink cartridges
The Epson CX9400F printer seems to require replacement of all the color ink cartridges, even if only the Black is empty.
I print almost exclusively in Black, but with my first change of Black, I was forced to change all the color. At the time I thought Epson did not provide completely filled color ink cartridges.
Just yesterday, I replaced Black and the printer complained it did not recognize the rest of color cartridges. So I replaced all the other color ink cartridges and now it works fine.
You might want to check out www.clickinks.com for cheaper, mail order alternatives which are Epson ink compatible, if you are not in a hurry.
ew
Feb 23, 2009 | Epson Stylus CX9400 Photo Printer
UNABLE TO USE #88 INK FOR MY EPSON STYLUS PRINTER.
I don't know where you got your #88 cartridges from or who told you that they were compatible with your printer, but they were wrong.
The CX7450 will only work with the #69 type cartridges.
The cartridges themselves may look similar but the chip programming will be different for each.
Hope that helps.
Feb 21, 2009 | Epson Office Equipment & Supplies
Black and white not printing correctly, color is fine
If you are not using Epson ink, your printer will do this. Epson printers hate knock-off ink. Always use Epson ink if you want to keep your printer working properly. To solve the problem you are having, try cleaning the ink tubes. Make sure you re-install them properly. Hope this helps. Charlene
Feb 10, 2009 | Epson Stylus CX3810 All-In-One InkJet...
New black ink cartridge installed, message is "out of ink"
It seems that the printer computer is not getting the signal from the new cartridge. Try looking at the place where the cartridge contacts touch the printer cartridge socket. If nothing is bent out of place try rubbing the contacts a little with a paper towel
Dec 20, 2008 | Epson RX620 All-In-One InkJet Photo...
After cartridge change, the printer will not work
you might not like it, but here it is, it is the truth
Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head. Therefore, once one of the cartridges are expended, the printer signals you to replace the cartridge in order for printing to continue.
Aug 20, 2008 | Epson Stylus Photo R300 InkJet Printer
Color, black ink cartridge error
contact epson support
they may replace your cartridge
Oct 24, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
3,138 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
