Question about Haba Schiller AT1 Interpretive Ekg, Each
Schiller AT-1 Trouble . It did not accept any order such us print
The AC indicator is enable, not the same for Battery indicator, Paper, Filter, in spite of filter key is pushed. Also paper keep OFF always no matter changes at paper condition.
When ON pushed it seems no changes in the equipment state. In spite patient cable is connected at simulator the keyboard seems to be disable.
Pablo Rodriguez V.
  • 71 Answers
You need a new battery. Contact R& D Battries
Posted on Aug 31, 2009
    Problem Solver:
  • 13 Answers
I got the manual for AT1 Schiller if you are intrested in buy it contact me at: sales@biomedtechpr.com
www.biomedtechpr.com
Posted on Dec 05, 2009
The ekg machine light of filter is flickering and when printing only prints one line out of three appears as if no ink
HI,
Here i added a link which will help you to rectify the problem. Its seems to be the battery of your ECG machine is faulty.
Schiller AT 1 Support
Jun 25, 2012 | Schiller Welch Allyn Cardiovit At 2...
AT2+ doesn't print
HI,
Its a common problem with Schiller ECG machine. The battery of your ECG machine is faulty. Even if you are using the machine in AC it uses the battery power. The AC power is only used for charging the battery.
When the machine starts to print the battery will drop down and the printing will stop. This is happening with the machine. It will eject the first paper without printing. its normal. Because the machine starts printing on a fresh page only. In your case the machine is ejecting the first paper. When the machine starts its printing in the second page it will draw a large amount of current from the battery for its thermal printing head. If the battery is not proper then it will suddenly drop the printing. The square box you see is not printed by your ECG machine. Its already printed in the paper of Schiller. With this mark the Machine sense the page.
Its a 12 volt 2.3 AH battery. You will not be able to replace the battery from out side any where. For replacing the same you have to open the machine by removing the screws on its bottom. Be care full with the paper tray while removing the top cover. Also do not use any force to open the top cover because there are connections on the top cover.
Here i have added a link to the battery for Schiller AT2 PLUS
Battery
Ajin
Apr 27, 2012 | Schiller Welch Allyn Cardiovit At 2...
The Schiller AT-1 is not printing, when the patiente cable is conected the unit start to print and stop after 1 second and turn off. If I disconec the cable the unit keep printing
The Schiller AT1 is a battery powered unit. A common symptom of weak/defective battery's is that it will stop printing after 1-2 seconds of run. As to whether the patient cable effects this, I honestly don't know, It really shouldn't, baring some very weird internal short in the cable. The battery in the AT1 is beyond the average user to safely replace. Before anything else insure that the AC indicator light illuminates when the unit is plugged in. If not, you device might have a defective power supply. In either case, the unit needs repair in a Qualified shop.
Oct 28, 2011 | Schiller Welch Allyn Cardiovit At 2...
Just ordered a schiller at1 ekg machine, just realized it is 3 channel, does it have a 1 channel mode where just one tracing will print?
hi,
u can make it single channel one by changing its setup. it will print single trace in the same paper. when u select this option it use more paper than the three trace.
ok
Dec 06, 2010 | Schiller Cardiovit At 1 Ecg Machine
The schiller at-1 ran out of paper, I put some more in. Now it will not print any suggetions?
HI,
check the paper u have inserted. it should be Schiller original paper with page marking. also clean the paper sensor. u can see the paper sensor near the side of printing head. a small square portion. clean it with an ear bud, don't use any solution for cleaning only ear bud.
ok
Nov 14, 2010 | Schiller Cardiovit At 1 Ecg Machine
Schiller AT-1
check paper alignment
maybe papermark sensor problem also
Oct 16, 2009 | Schiller Cardiovit At 1 Ecg Machine
Schiller cardiovit at-1 not printing clearly
hi clean the thermal head of the printer with the tissue paper
Zubair
0091-9849156725
Jun 19, 2009 | RTO Schiller CARDIOVIT AT-1...
Hello LV792727, Disconnect the AC & battery power and proceed with caution. Open the case to aquire access to the thermal print head. Clean the print head with a white eraser, the type used for cleaning ink prints not the #2 pencile eraser. Test the printing function. If necessariy use a Q-Tip with a light touch of Aceatone to whip the print head. The next step is replacing the printing element. Please inform me of the results. Good luck.
Oct 22, 2008 | Schiller Welch Allyn Cardiovit At 2...
Haba Schiller AT1 Interpretive Ekg, Each Logo
187 people viewed this question
Top Haba Medical Experts
Electro Med Services...
Are you a Haba Medical Expert? Answer questions, earn points and help others
